    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 383.2k Views 23 Watching
    • G Offline
      Gunwoody
      Hi Savage, that’s what i figured. I need to figure out a way to test connectivity between all the different elements.
      Do you know where the wake word is set?
        savage_gr1nd @Gunwoody
        @Gunwoody there too many moving parts I think to see it all in one spot. But could be wrong lol
        And where wake word runs depends on which program/version of alexa-sdk you’re using. Like I use alexa-avs-sample-app so mine runs in its own terminal. But that’s soon to change. Gonna run Alexapi so it runs right off of boot instead. That’s my project for tonight lol
        • G Offline
          Gunwoody
          I’m using the same. You’ll have to let me know how it goes with AlexaPi - might be an easier route to take :)
            @Gunwoody will do :)
            • zman3Z Offline
              zman3
              holy crap I finally got the skill part working. took me doing the whole install npm and everything and uploading the zip all from windows instead of the raspberry. weird
              • zman3Z Offline
                zman3
                of course now i have the problem of it not doing anything with the mirror :/
                • G Offline
                  Gunwoody
                  Exactly the same here
                    @Gunwoody @zman3 while you were running npm install on the skills dependencies you didn’t sudo npm install right? That blocks amazons access.
                    • zman3Z Offline
                      zman3
                      Nope just regular pi usr
                        savage_gr1nd @zman3
                        Hmm. Add MMM-mirrormirror I to MagicMirror config.js? And also have it installed in the magicmirror/modules folder?
                        • zman3Z Offline
                          zman3
                          Yes and yes I’ll try again tonight ,I’m at work which interferes with my play time
                          • zman3Z Offline
                            zman3
                            tried it from the start again the skill its self works but when she says closing module it doesnt close ,no text gets displayed or if I search for snow white images she says displaying but i never see anything.
                              artifactdev
                              @joanaz Can you provide a how to or screencast how to get this working with an echo dot? For me it’s not clear how to connect the module with the lambda function which will be triggered by the skill.
                                joanaz @zman3
                                @zman3 you copied your certs folder to the mirror module folder? check your terminal to see any error messages
                                  joanaz @artifactdev
                                  @artifactdev that’s what AWS IoT device gateway is for. Just setup the skill and the mirror module as instructed
                                  • zman3Z Offline
                                    zman3
                                    went through redid the awsiot set up did the start.sh copied the certs to the certs folder in the magic mirror module put those in the skill and re uploaded the zip to lambda still get nothing showing on the mirror
                                    lucallmonL 1 Reply Last reply Reply Quote 0
                                    • lucallmonL Offline
                                      lucallmon @zman3
                                      @zman3 It’s because there’s no guide. It’s just figure it out yourself. You know this isn’t a well-organized module when you look at how many posts/replies are in it.
                                        joanaz @lucallmon
                                        @lucallmon lol, what do you mean there’s no guide? my guides have a total of 250 lines. anyways, I tried to help you guys setup and figuring out your errors, but clearly my module is out of your league. so come back when you have more dev skills.
                                        lucallmonL 1 Reply Last reply Reply Quote -1
                                          joanaz
                                          I just made another Alexa skill and Magic Mirror module for simple note taking, you can find them here: https://forum.magicmirror.builders/topic/1824/mmm-notetaker-a-module-that-displays-your-notes-stored-by-the-alexa-skill-note-taker
                                            d3r
                                            Hey @joanaz thanks for the awesome module. The module works pretty well. Also tried the image search and youtube which work very well. Main issue so far is I can’t turn off the video without closing all modules. I’ll look into that tomorrow.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 8 / 10
