    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.8k Views 23 Watching
      joanaz
      For people struggling with setting up Lambda and Alexa Skill, here’s a good visual instructions for a different Skill. Use your judgment when dealing with differences with my skill.
      https://github.com/alexa/skill-sample-nodejs-calendar-reader
      Here’s Amazon’s instructions for setting up a AWS IoT device, it’ll also be slightly different when you setup your own device, but it’s good enough.
      http://docs.aws.amazon.com/iot/latest/developerguide/iot-console-signin.html
        savage_gr1nd
        So exactly which files need to be in the zip?
        And also, when testing on the lambda site I get an error about alexa-sdk not being detected… are there other steps for installation? I’ve hit a wall
        J 1 Reply Last reply
          savage_gr1nd
          So redid everything. Same thing. When I test with my device and try to invoke it says there was a problem with the requested skills response…
            joanaz @savage_gr1nd
            @savage_gr1nd you need to include node_modules in the src folder. run ‘npm install’ inside src folder.
              savage_gr1nd
              Yea I did that. Then made the zip. The zip was too large and my page kept crashing so I used s3. Or will that not work?
                savage_gr1nd
                And one more thing I’m confused on and it might be why, when putting the path to certs to keys.json is it the FULL path /home etc…?
                  @savage_gr1nd the zip shouldn’t be too large, mine was 5.1MB. I’m not sure what you are saying about path to certs and keys.json. have a look of my folder structure
                    savage_gr1nd
                    I figured out the path problem.
                    But every module ever is in my folder. Which are required so I can delete the rest.
                      savage_gr1nd
                      I’m sorry lol
                      More specific in my node_modules folder
                        savage_gr1nd
                        Okay I’m really sorry for bugging.
                        But literally got everything figured out except why my file is too large. I deleted node_modules and redid npm installs on all 4 dependencies. The node folder alone is 69mb…
                        How is yours 5.1mb…?
                        Since mine is so big. The only error I get now in lambda is time out. I just don’t understand why mine is so large.
                          savage_gr1nd @Journeytojah
                          @Journeytojah did you ever get yours to work? That’s about the same error I was getting
                            @savage_gr1nd my node_modules is 24.2MB. How are you testing the lambda function? try something simple, like the hello intent first
                              savage_gr1nd @joanaz
                              @joanaz that’s what I was doing.
                              Also testing after uploading the code from the console.
                              After work I want to try npm depues to see if that helps.
                              But I also see you have latest define for the dependencies. What versions do you have installed so I can’t edit my package.json to install those smaller versions?
                                @savage_gr1nd this is my npm list
                                ├─┬ alexa-sdk@1.0.6
                                │ ├─┬ aws-sdk@2.9.0
                                │ │ ├─┬ buffer@4.9.1
                                │ │ │ ├── base64-js@1.2.0
                                │ │ │ ├── ieee754@1.1.8
                                │ │ │ └── isarray@1.0.0
                                │ │ ├── crypto-browserify@1.0.9
                                │ │ ├── jmespath@0.15.0
                                │ │ ├── querystring@0.2.0
                                │ │ ├── sax@1.1.5
                                │ │ ├─┬ url@0.10.3
                                │ │ │ └── punycode@1.3.2
                                │ │ ├── uuid@3.0.0
                                │ │ ├── xml2js@0.4.15
                                │ │ └─┬ xmlbuilder@2.6.2
                                │ │   └── lodash@3.5.0
                                │ ├── i18next@3.5.2
                                │ └── i18next-sprintf-postprocessor@0.2.2
                                ├─┬ aws-iot-device-sdk@1.0.14
                                │ ├── crypto-js@3.1.6
                                │ ├── minimist@1.2.0
                                │ ├─┬ mqtt@1.11.2
                                │ │ ├─┬ commist@1.0.0
                                │ │ │ └── leven@1.0.2
                                │ │ ├─┬ concat-stream@1.6.0
                                │ │ │ ├─┬ readable-stream@2.2.2
                                │ │ │ │ ├── buffer-shims@1.0.0
                                │ │ │ │ ├── process-nextick-args@1.0.7
                                │ │ │ │ └── util-deprecate@1.0.2
                                │ │ │ └── typedarray@0.0.6
                                │ │ ├─┬ end-of-stream@1.1.0
                                │ │ │ └─┬ once@1.3.3
                                │ │ │   └── wrappy@1.0.2
                                │ │ ├── help-me@0.1.0
                                │ │ ├── inherits@2.0.3
                                │ │ ├─┬ mqtt-connection@2.1.1
                                │ │ │ ├── reduplexer@1.1.0
                                │ │ │ └── through2@0.6.5
                                │ │ ├── mqtt-packet@3.4.7
                                │ │ ├── pump@1.0.2
                                │ │ ├─┬ readable-stream@1.0.34
                                │ │ │ ├── core-util-is@1.0.2
                                │ │ │ ├── isarray@0.0.1
                                │ │ │ └── string_decoder@0.10.31
                                │ │ ├── reinterval@1.1.0
                                │ │ ├─┬ split2@2.1.1
                                │ │ │ └─┬ through2@2.0.3
                                │ │ │   └── readable-stream@2.2.2
                                │ │ └── xtend@4.0.1
                                │ └─┬ websocket-stream@3.3.3
                                │   ├─┬ duplexify@3.5.0
                                │   │ ├── end-of-stream@1.0.0
                                │   │ ├── readable-stream@2.2.2
                                │   │ └── stream-shift@1.0.0
                                │   ├─┬ through2@2.0.3
                                │   └─┬ ws@1.1.1
                                │     ├── options@0.0.6
                                │     └── ultron@1.0.2
                                ├─┬ google-images@2.0.0
                                │ └─┬ got@6.7.1
                                │   ├─┬ create-error-class@3.0.2
                                │   │ └── capture-stack-trace@1.0.0
                                │   ├── duplexer3@0.1.4
                                │   ├── get-stream@3.0.0
                                │   ├── is-redirect@1.0.0
                                │   ├── is-retry-allowed@1.1.0
                                │   ├── is-stream@1.1.0
                                │   ├── lowercase-keys@1.0.0
                                │   ├── safe-buffer@5.0.1
                                │   ├── timed-out@4.0.0
                                │   ├── unzip-response@2.0.1
                                │   └─┬ url-parse-lax@1.0.0
                                │     └── prepend-http@1.0.4
                                └─┬ youtube-node@1.3.0
                                  ├── colors@1.0.3
                                  ├─┬ prompt@0.2.14
                                  │ ├── pkginfo@0.4.0
                                  │ ├─┬ read@1.0.7
                                  │ │ └── mute-stream@0.0.7
                                  │ ├── revalidator@0.1.8
                                  │ ├─┬ utile@0.2.1
                                  │ │ ├── async@0.2.10
                                  │ │ ├── deep-equal@1.0.1
                                  │ │ ├── i@0.3.5
                                  │ │ ├─┬ mkdirp@0.5.1
                                  │ │ │ └── minimist@0.0.8
                                  │ │ ├── ncp@0.4.2
                                  │ │ └─┬ rimraf@2.5.4
                                  │ │   └─┬ glob@7.1.1
                                  │ │     ├── fs.realpath@1.0.0
                                  │ │     ├── inflight@1.0.6
                                  │ │     ├─┬ minimatch@3.0.3
                                  │ │     │ └─┬ brace-expansion@1.1.6
                                  │ │     │   ├── balanced-match@0.4.2
                                  │ │     │   └── concat-map@0.0.1
                                  │ │     └── path-is-absolute@1.0.1
                                  │ └─┬ winston@0.8.3
                                  │   ├── colors@0.6.2
                                  │   ├── cycle@1.0.3
                                  │   ├── eyes@0.1.8
                                  │   ├── pkginfo@0.3.1
                                  │   └── stack-trace@0.0.9
                                  └─┬ request@2.53.0
                                    ├── aws-sign2@0.5.0
                                    ├── bl@0.9.5
                                    ├── caseless@0.9.0
                                    ├─┬ combined-stream@0.0.7
                                    │ └── delayed-stream@0.0.5
                                    ├── forever-agent@0.5.2
                                    ├─┬ form-data@0.2.0
                                    │ └── async@0.9.2
                                    ├─┬ hawk@2.3.1
                                    │ ├── boom@2.10.1
                                    │ ├── cryptiles@2.0.5
                                    │ ├── hoek@2.16.3
                                    │ └── sntp@1.0.9
                                    ├─┬ http-signature@0.10.1
                                    │ ├── asn1@0.1.11
                                    │ ├── assert-plus@0.1.5
                                    │ └── ctype@0.5.3
                                    ├── isstream@0.1.2
                                    ├── json-stringify-safe@5.0.1
                                    ├─┬ mime-types@2.0.14
                                    │ └── mime-db@1.12.0
                                    ├── node-uuid@1.4.7
                                    ├── oauth-sign@0.6.0
                                    ├── qs@2.3.3
                                    ├── stringstream@0.0.5
                                    ├─┬ tough-cookie@2.3.2
                                    │ └── punycode@1.4.1
                                    └── tunnel-agent@0.4.3
                                  @joanaz awesome!
                                  I’m sure between the two methods I can shrink it down enough. At least I hope i can haha
                                  I’m way too excited to get this running and play with it. Thank you!
                                    @savage_gr1nd yeah, i was really excited when i got it working. :) let me know when you do!
                                    S 3 Replies Last reply
                                      @joanaz it’s seriously been 3 days after work. Of playing with code for 7 hours each day. It’s kicking my ass but I’ll get it lol
                                        @joanaz so I was thinking, the mirrormirror module, can it be configured to play “next up” in the YouTube api? Instead of loop? :/
                                          @joanaz okay. Finally. Got a response. Now. The mmm.
                                          Everytime I touch the config.js doesn’t load up. Can you give me a few more details for setting up the module?
                                          IE. Where to run npm install for aws-iot-device-sdk lol
                                            @savage_gr1nd erhhh, inside the module folder. you also need to copy the certs folder over
                                            • 10
                                            • 4 / 10
