    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.8k Views 23 Watching
      joanaz @Gunwoody
      @Gunwoody sorry to hear that. This is quite advanced as you have to setup AWS IoT, Lambda and Alexa skill, so it does need you to have some experiences with programming and using AWS services. I’m thinking about how to simplify this and get it to work with multiple users, but thanks for trying.
      G 1 Reply Last reply
      • zman3Z
        zman3
        I do not get why this is not working the src.zip has a layout of folders and in the root of zip I have index.js MirrorMirror.js and package.json
        but i still get
        START RequestId: dbde411d-ecaa-11e6-8bd7-9b2096d559c7 Version: $LATEST
        20:28:46
        Unable to import module 'index': Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/index.js:23:14) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (
        at Module.load (module.js:343:32)
        at Function.Module._load (module.js:300:12)
        which looks like what it’s not finding index.js ?
        J 1 Reply Last reply
        • G
          Gunwoody @joanaz
          @joanaz I haven’t really had much of an issue with Lambda, IOT etc. It’s more the local install on the pi. I think because your instructions jump from area to area it’s easy to miss or misintrepet a step. I might just do a full clean install and start from scratch. It’s just a shame because MagicMirror itself runs perfectly with any module i try. It’s just your that is determined to thwart me lol :)
            joanaz @zman3
            @zman3 you don’t have certs and node_modules?
              joanaz @Gunwoody
              @Gunwoody i’ve never seen another mirror module which works with a Alexa skill
              • zman3Z
                zman3
                yes i have those folders in the zip
                  joanaz
                  For people struggling with setting up Lambda and Alexa Skill, here’s a good visual instructions for a different Skill. Use your judgment when dealing with differences with my skill.
                  https://github.com/alexa/skill-sample-nodejs-calendar-reader
                  Here’s Amazon’s instructions for setting up a AWS IoT device, it’ll also be slightly different when you setup your own device, but it’s good enough.
                  http://docs.aws.amazon.com/iot/latest/developerguide/iot-console-signin.html
                    savage_gr1nd
                    So exactly which files need to be in the zip?
                    And also, when testing on the lambda site I get an error about alexa-sdk not being detected… are there other steps for installation? I’ve hit a wall
                      savage_gr1nd
                      So redid everything. Same thing. When I test with my device and try to invoke it says there was a problem with the requested skills response…
                        joanaz @savage_gr1nd
                        @savage_gr1nd you need to include node_modules in the src folder. run ‘npm install’ inside src folder.
                          savage_gr1nd
                          Yea I did that. Then made the zip. The zip was too large and my page kept crashing so I used s3. Or will that not work?
                            savage_gr1nd
                            And one more thing I’m confused on and it might be why, when putting the path to certs to keys.json is it the FULL path /home etc…?
                              @savage_gr1nd the zip shouldn’t be too large, mine was 5.1MB. I’m not sure what you are saying about path to certs and keys.json. have a look of my folder structure
                                savage_gr1nd
                                I figured out the path problem.
                                But every module ever is in my folder. Which are required so I can delete the rest.
                                  savage_gr1nd
                                  I’m sorry lol
                                  More specific in my node_modules folder
                                    savage_gr1nd
                                    Okay I’m really sorry for bugging.
                                    But literally got everything figured out except why my file is too large. I deleted node_modules and redid npm installs on all 4 dependencies. The node folder alone is 69mb…
                                    How is yours 5.1mb…?
                                    Since mine is so big. The only error I get now in lambda is time out. I just don’t understand why mine is so large.
                                      savage_gr1nd @Journeytojah
                                      @Journeytojah did you ever get yours to work? That’s about the same error I was getting
                                        @savage_gr1nd my node_modules is 24.2MB. How are you testing the lambda function? try something simple, like the hello intent first
                                          savage_gr1nd @joanaz
                                          @joanaz that’s what I was doing.
                                          Also testing after uploading the code from the console.
                                          After work I want to try npm depues to see if that helps.
                                          But I also see you have latest define for the dependencies. What versions do you have installed so I can’t edit my package.json to install those smaller versions?
                                            @savage_gr1nd this is my npm list
                                            ├─┬ alexa-sdk@1.0.6
                                            │ ├─┬ aws-sdk@2.9.0
                                            │ │ ├─┬ buffer@4.9.1
                                            │ │ │ ├── base64-js@1.2.0
                                            │ │ │ ├── ieee754@1.1.8
                                            │ │ │ └── isarray@1.0.0
                                            │ │ ├── crypto-browserify@1.0.9
                                            │ │ ├── jmespath@0.15.0
                                            │ │ ├── querystring@0.2.0
                                            │ │ ├── sax@1.1.5
                                            │ │ ├─┬ url@0.10.3
                                            │ │ │ └── punycode@1.3.2
                                            │ │ ├── uuid@3.0.0
                                            │ │ ├── xml2js@0.4.15
                                            │ │ └─┬ xmlbuilder@2.6.2
                                            │ │   └── lodash@3.5.0
                                            │ ├── i18next@3.5.2
                                            │ └── i18next-sprintf-postprocessor@0.2.2
                                            ├─┬ aws-iot-device-sdk@1.0.14
                                            │ ├── crypto-js@3.1.6
                                            │ ├── minimist@1.2.0
                                            │ ├─┬ mqtt@1.11.2
                                            │ │ ├─┬ commist@1.0.0
                                            │ │ │ └── leven@1.0.2
                                            │ │ ├─┬ concat-stream@1.6.0
                                            │ │ │ ├─┬ readable-stream@2.2.2
                                            │ │ │ │ ├── buffer-shims@1.0.0
                                            │ │ │ │ ├── process-nextick-args@1.0.7
                                            │ │ │ │ └── util-deprecate@1.0.2
                                            │ │ │ └── typedarray@0.0.6
                                            │ │ ├─┬ end-of-stream@1.1.0
                                            │ │ │ └─┬ once@1.3.3
                                            │ │ │   └── wrappy@1.0.2
                                            │ │ ├── help-me@0.1.0
                                            │ │ ├── inherits@2.0.3
                                            │ │ ├─┬ mqtt-connection@2.1.1
                                            │ │ │ ├── reduplexer@1.1.0
                                            │ │ │ └── through2@0.6.5
                                            │ │ ├── mqtt-packet@3.4.7
                                            │ │ ├── pump@1.0.2
                                            │ │ ├─┬ readable-stream@1.0.34
                                            │ │ │ ├── core-util-is@1.0.2
                                            │ │ │ ├── isarray@0.0.1
                                            │ │ │ └── string_decoder@0.10.31
                                            │ │ ├── reinterval@1.1.0
                                            │ │ ├─┬ split2@2.1.1
                                            │ │ │ └─┬ through2@2.0.3
                                            │ │ │   └── readable-stream@2.2.2
                                            │ │ └── xtend@4.0.1
                                            │ └─┬ websocket-stream@3.3.3
                                            │   ├─┬ duplexify@3.5.0
                                            │   │ ├── end-of-stream@1.0.0
                                            │   │ ├── readable-stream@2.2.2
                                            │   │ └── stream-shift@1.0.0
                                            │   ├─┬ through2@2.0.3
                                            │   └─┬ ws@1.1.1
                                            │     ├── options@0.0.6
                                            │     └── ultron@1.0.2
                                            ├─┬ google-images@2.0.0
                                            │ └─┬ got@6.7.1
                                            │   ├─┬ create-error-class@3.0.2
                                            │   │ └── capture-stack-trace@1.0.0
                                            │   ├── duplexer3@0.1.4
                                            │   ├── get-stream@3.0.0
                                            │   ├── is-redirect@1.0.0
                                            │   ├── is-retry-allowed@1.1.0
                                            │   ├── is-stream@1.1.0
                                            │   ├── lowercase-keys@1.0.0
                                            │   ├── safe-buffer@5.0.1
                                            │   ├── timed-out@4.0.0
                                            │   ├── unzip-response@2.0.1
                                            │   └─┬ url-parse-lax@1.0.0
                                            │     └── prepend-http@1.0.4
                                            └─┬ youtube-node@1.3.0
                                              ├── colors@1.0.3
                                              ├─┬ prompt@0.2.14
                                              │ ├── pkginfo@0.4.0
                                              │ ├─┬ read@1.0.7
                                              │ │ └── mute-stream@0.0.7
                                              │ ├── revalidator@0.1.8
                                              │ ├─┬ utile@0.2.1
                                              │ │ ├── async@0.2.10
                                              │ │ ├── deep-equal@1.0.1
                                              │ │ ├── i@0.3.5
                                              │ │ ├─┬ mkdirp@0.5.1
                                              │ │ │ └── minimist@0.0.8
                                              │ │ ├── ncp@0.4.2
                                              │ │ └─┬ rimraf@2.5.4
                                              │ │   └─┬ glob@7.1.1
                                              │ │     ├── fs.realpath@1.0.0
                                              │ │     ├── inflight@1.0.6
                                              │ │     ├─┬ minimatch@3.0.3
                                              │ │     │ └─┬ brace-expansion@1.1.6
                                              │ │     │   ├── balanced-match@0.4.2
                                              │ │     │   └── concat-map@0.0.1
                                              │ │     └── path-is-absolute@1.0.1
                                              │ └─┬ winston@0.8.3
                                              │   ├── colors@0.6.2
                                              │   ├── cycle@1.0.3
                                              │   ├── eyes@0.1.8
                                              │   ├── pkginfo@0.3.1
                                              │   └── stack-trace@0.0.9
                                              └─┬ request@2.53.0
                                                ├── aws-sign2@0.5.0
                                                ├── bl@0.9.5
                                                ├── caseless@0.9.0
                                                ├─┬ combined-stream@0.0.7
                                                │ └── delayed-stream@0.0.5
                                                ├── forever-agent@0.5.2
                                                ├─┬ form-data@0.2.0
                                                │ └── async@0.9.2
                                                ├─┬ hawk@2.3.1
                                                │ ├── boom@2.10.1
                                                │ ├── cryptiles@2.0.5
                                                │ ├── hoek@2.16.3
                                                │ └── sntp@1.0.9
                                                ├─┬ http-signature@0.10.1
                                                │ ├── asn1@0.1.11
                                                │ ├── assert-plus@0.1.5
                                                │ └── ctype@0.5.3
                                                ├── isstream@0.1.2
                                                ├── json-stringify-safe@5.0.1
                                                ├─┬ mime-types@2.0.14
                                                │ └── mime-db@1.12.0
                                                ├── node-uuid@1.4.7
                                                ├── oauth-sign@0.6.0
                                                ├── qs@2.3.3
                                                ├── stringstream@0.0.5
                                                ├─┬ tough-cookie@2.3.2
                                                │ └── punycode@1.4.1
                                                └── tunnel-agent@0.4.3
                                            • 10
                                            • 4 / 10
