    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 393.3k Views 23 Watching
    • Z Offline
      zman3
      well just went through the whole thing again she still says there was a problem with the requested skills response and when i type hello into the service simulator the output is
      The remote endpoint could not be called, or the response it returned was invalid.
      • Z Offline
        zman3
        this is in the logs
        START RequestId: cc7bfdd1-ebfd-11e6-8d16-b56e041c9162 Version: $LATEST
        23:49:57
        Unable to import module ‘index’: Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/index.js:23:14) at Module._compile (module.js:409:26) at Object.Module._extensions…js (module.js:416:10) at Module.load (
        23:49:58
        2017-02-05T23:49:58.043Z cc7bfdd1-ebfd-11e6-8d16-b56e041c9162 connect
        • G Offline
          Gunwoody @joanaz
          @joanaz Hi, when i zip all those files and folders up and try to upload them to Lambda i get "The deployment package of your Lambda function “xxxxxxxxx” is too large to enable inline code editing. However, you can still invoke your function right now. any ideas - it’s driving me mad. I thought it must be that i shouldn’t include the node_modules folder - can you confirm exactly what should be in the zip. Thanks
            joanaz @Gunwoody
            @Gunwoody you should definitely include node_modules, but my zip file is 5.1MB, I think the limit is 50MB. it’s not an error, you can ignore it.
            • G Offline
              Gunwoody @joanaz
              @joanaz Hi - thanks for the super quick reply :). Yes, my zip is also 5.1mb. I’ve tried several times but still get the same message.
              “The deployment package of your Lambda function “xxxxxxxxxxx” is too large to enable inline code editing. However, you can still invoke your function right now.”
              You say i can ignore it - but how do i know if the zip has uploaded ok?
                joanaz @Gunwoody
                @Gunwoody it says you can invoke your function right now. if it’s not ok, it would give you a red error message. Anyways, you can click on the test button, see whether your function works. but before that, you need to setup a test case
                • G Offline
                  Gunwoody @joanaz
                  @joanaz Thanks again. I think it’s uploaded ok - not that it’s helped me get it working. I can get just about any other module running on MagicMirror but not this one. I think it’s just a case of i’m not sure what folders should be where. When i run it with the module in the config file i just get a white screen and can’t ‘alt’ out of it - Pi seems to crash. I think i’ll just have to give up as i’ve been trying for 3 days to get this running :(
                    joanaz @bartalluyn
                    @bartalluyn is your code on Github? I’m quite interested in your Alexa Java client, it’d be great if it was a Mirror Module, so Alexa and Mirror can communicate directly without going through AWS IoT.
                      joanaz @Gunwoody
                      @Gunwoody sorry to hear that. This is quite advanced as you have to setup AWS IoT, Lambda and Alexa skill, so it does need you to have some experiences with programming and using AWS services. I’m thinking about how to simplify this and get it to work with multiple users, but thanks for trying.
                      • Z Offline
                        zman3
                        I do not get why this is not working the src.zip has a layout of folders and in the root of zip I have index.js MirrorMirror.js and package.json
                        but i still get
                        START RequestId: dbde411d-ecaa-11e6-8bd7-9b2096d559c7 Version: $LATEST
                        20:28:46
                        Unable to import module 'index': Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/index.js:23:14) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (
                        at Module.load (module.js:343:32)
                        at Function.Module._load (module.js:300:12)
                        which looks like what it’s not finding index.js ?
                        • G Offline
                          Gunwoody @joanaz
                          @joanaz I haven’t really had much of an issue with Lambda, IOT etc. It’s more the local install on the pi. I think because your instructions jump from area to area it’s easy to miss or misintrepet a step. I might just do a full clean install and start from scratch. It’s just a shame because MagicMirror itself runs perfectly with any module i try. It’s just your that is determined to thwart me lol :)
                            joanaz @zman3
                            @zman3 you don’t have certs and node_modules?
                              joanaz @Gunwoody
                              @Gunwoody i’ve never seen another mirror module which works with a Alexa skill
                              • Z Offline
                                zman3
                                yes i have those folders in the zip
                                  joanaz
                                  For people struggling with setting up Lambda and Alexa Skill, here’s a good visual instructions for a different Skill. Use your judgment when dealing with differences with my skill.
                                  https://github.com/alexa/skill-sample-nodejs-calendar-reader
                                  Here’s Amazon’s instructions for setting up a AWS IoT device, it’ll also be slightly different when you setup your own device, but it’s good enough.
                                  http://docs.aws.amazon.com/iot/latest/developerguide/iot-console-signin.html
                                    savage_gr1nd
                                    So exactly which files need to be in the zip?
                                    And also, when testing on the lambda site I get an error about alexa-sdk not being detected… are there other steps for installation? I’ve hit a wall
                                      savage_gr1nd
                                      So redid everything. Same thing. When I test with my device and try to invoke it says there was a problem with the requested skills response…
                                        joanaz @savage_gr1nd
                                        @savage_gr1nd you need to include node_modules in the src folder. run ‘npm install’ inside src folder.
                                          savage_gr1nd
                                          Yea I did that. Then made the zip. The zip was too large and my page kept crashing so I used s3. Or will that not work?
                                            savage_gr1nd
                                            And one more thing I’m confused on and it might be why, when putting the path to certs to keys.json is it the FULL path /home etc…?
                                            • 10
                                            • 3 / 10
