    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.9k Views 23 Watching
      bartalluyn
      I’ve succeeded in succesfully linking Alexa to the smart mirror. When I issue a command, the mirror responds automatically. It has automatic wake word detection, audio feedback, automatic authentication using a refresh token, connection through a mirror interface. In the background it uses Alexa Skills kit and DynamoDB to make the communication happen. Read about it on my blog :
      [http://smartmirrorprojectblog.wordpress.com/](link url)
      Go ahead and follow the blog to find out on the progression and further development.
      Tips and suggestions welcome of course.
      J 1 Reply Last reply
        joanaz @bartalluyn
        @bartalluyn really nice work! but since you have to change the Alexa Java client app to get it to work, it wouldn’t work for our application, since we need to get it to work with off-the-shelf Alexa or Alexa Echo. Right now my Alexa skill can only be used by one user, so I’m thinking about how to get it to work with multiple users so I can publish this skill, so people don’t need to worry about setting up Lambda and Alexa skill.
        B 1 Reply Last reply
          bartalluyn @joanaz
          @joanaz That’s indeed something that wouldn’t work in that case.
          It sounds like you would need something like account linking. What if the smart mirror would publish a service that takes and gives account credentials to hook on using the account linking functionality of a custom skill?
          Thinking out of the box right now?
          Also, suppose it works. When people start to install your module, and use your skill, your 1 million free lambda calls might expire sooner than you think? That’s one of the reasons why I’m not considering putting any of my skills out there.
          • zman3Z
            zman3
            well just went through the whole thing again she still says there was a problem with the requested skills response and when i type hello into the service simulator the output is
            The remote endpoint could not be called, or the response it returned was invalid.
            • zman3Z
              zman3
              this is in the logs
              START RequestId: cc7bfdd1-ebfd-11e6-8d16-b56e041c9162 Version: $LATEST
              23:49:57
              Unable to import module ‘index’: Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/index.js:23:14) at Module._compile (module.js:409:26) at Object.Module._extensions…js (module.js:416:10) at Module.load (
              23:49:58
              2017-02-05T23:49:58.043Z cc7bfdd1-ebfd-11e6-8d16-b56e041c9162 connect
              • G
                Gunwoody @joanaz
                @joanaz Hi, when i zip all those files and folders up and try to upload them to Lambda i get "The deployment package of your Lambda function “xxxxxxxxx” is too large to enable inline code editing. However, you can still invoke your function right now. any ideas - it’s driving me mad. I thought it must be that i shouldn’t include the node_modules folder - can you confirm exactly what should be in the zip. Thanks
                  joanaz @Gunwoody
                  @Gunwoody you should definitely include node_modules, but my zip file is 5.1MB, I think the limit is 50MB. it’s not an error, you can ignore it.
                  G 1 Reply Last reply
                  • G
                    Gunwoody @joanaz
                    @joanaz Hi - thanks for the super quick reply :). Yes, my zip is also 5.1mb. I’ve tried several times but still get the same message.
                    “The deployment package of your Lambda function “xxxxxxxxxxx” is too large to enable inline code editing. However, you can still invoke your function right now.”
                    You say i can ignore it - but how do i know if the zip has uploaded ok?
                      joanaz @Gunwoody
                      @Gunwoody it says you can invoke your function right now. if it’s not ok, it would give you a red error message. Anyways, you can click on the test button, see whether your function works. but before that, you need to setup a test case
                      • G
                        Gunwoody @joanaz
                        @joanaz Thanks again. I think it’s uploaded ok - not that it’s helped me get it working. I can get just about any other module running on MagicMirror but not this one. I think it’s just a case of i’m not sure what folders should be where. When i run it with the module in the config file i just get a white screen and can’t ‘alt’ out of it - Pi seems to crash. I think i’ll just have to give up as i’ve been trying for 3 days to get this running :(
                          joanaz @bartalluyn
                          @bartalluyn is your code on Github? I’m quite interested in your Alexa Java client, it’d be great if it was a Mirror Module, so Alexa and Mirror can communicate directly without going through AWS IoT.
                            joanaz @Gunwoody
                            @Gunwoody sorry to hear that. This is quite advanced as you have to setup AWS IoT, Lambda and Alexa skill, so it does need you to have some experiences with programming and using AWS services. I’m thinking about how to simplify this and get it to work with multiple users, but thanks for trying.
                            • zman3Z
                              zman3
                              I do not get why this is not working the src.zip has a layout of folders and in the root of zip I have index.js MirrorMirror.js and package.json
                              but i still get
                              START RequestId: dbde411d-ecaa-11e6-8bd7-9b2096d559c7 Version: $LATEST
                              20:28:46
                              Unable to import module 'index': Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/index.js:23:14) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (
                              at Module.load (module.js:343:32)
                              at Function.Module._load (module.js:300:12)
                              which looks like what it’s not finding index.js ?
                              • G
                                Gunwoody @joanaz
                                @joanaz I haven’t really had much of an issue with Lambda, IOT etc. It’s more the local install on the pi. I think because your instructions jump from area to area it’s easy to miss or misintrepet a step. I might just do a full clean install and start from scratch. It’s just a shame because MagicMirror itself runs perfectly with any module i try. It’s just your that is determined to thwart me lol :)
                                  joanaz @zman3
                                  @zman3 you don’t have certs and node_modules?
                                    joanaz @Gunwoody
                                    @Gunwoody i’ve never seen another mirror module which works with a Alexa skill
                                    • zman3Z
                                      zman3
                                      yes i have those folders in the zip
                                        joanaz
                                        For people struggling with setting up Lambda and Alexa Skill, here’s a good visual instructions for a different Skill. Use your judgment when dealing with differences with my skill.
                                        https://github.com/alexa/skill-sample-nodejs-calendar-reader
                                        Here’s Amazon’s instructions for setting up a AWS IoT device, it’ll also be slightly different when you setup your own device, but it’s good enough.
                                        http://docs.aws.amazon.com/iot/latest/developerguide/iot-console-signin.html
                                          savage_gr1nd
                                          So exactly which files need to be in the zip?
                                          And also, when testing on the lambda site I get an error about alexa-sdk not being detected… are there other steps for installation? I’ve hit a wall
                                            savage_gr1nd
                                            So redid everything. Same thing. When I test with my device and try to invoke it says there was a problem with the requested skills response…
                                            • 10
                                            • 3 / 10
