    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.8k Views 23 Watching
    • lucallmonL
      lucallmon
      Setting up the AWS IoT service… what support plan to choose? Basic is free right? I’m not paying $30 for developer. Is this even required?
      J J 2 Replies Last reply
        joanaz @lucallmon
        @lucallmon yes you must setup an AWS IoT device, it should be free, I don’t know where you are seeing basic or developer whatever.
        You should see something like this
        J 1 Reply Last reply
          Journeytojah @lucallmon
          @lucallmon afaik you get 12 months for free, you just need to use a credit card to register, and they “use” 1$ to confirm its your account, kinda like PayPal does.
            Journeytojah @joanaz
            @joanaz Now i get this error for the Lambda function… tried 3/10/15 seconds.
              "errorMessage": "2017-02-04T20:11:41.538Z 1b87c832-eb16-11e6-a281-33f14ad1f615 Task timed out after 15.00 seconds",
              "errorType": "Error"
            This is the error in the Amazon Skill :
            Lambda Response
            The remote endpoint could not be called, or the response it returned was invalid.
            Cloud watch log
            20:46:58
            START RequestId: 11e4a442-eb1b-11e6-a7b3-3361f5194998 Version: 1
            20:46:58
            Unable to import module 'index': Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object.<anonymous> (/var/task/index.js:24:22) at Module._compile (module.js:409:26) at Object.Module._extensions..js (module.js:416:10) at Module.load (
            20:46:58
            2017-02-04T20:46:58.805Z	11e4a442-eb1b-11e6-a7b3-3361f5194998	connect
            20:47:13
            END RequestId: 11e4a442-eb1b-11e6-a7b3-3361f5194998
            20:47:13
            REPORT RequestId: 11e4a442-eb1b-11e6-a7b3-3361f5194998	Duration: 15003.64 ms	Billed Duration: 15000 ms Memory Size: 128 MB	Max Memory Used: 26 MB
            20:47:13
            2017-02-04T20:47:13.618Z 11e4a442-eb1b-11e6-a7b3-3361f5194998 Task timed out after 15.00 seconds Error
            at Module.load (module.js:343:32)
            at Function.Module._load (module.js:300:12)
              Journeytojah
              By the way, I was unable to upload the .zip from the RPi, it would just say “must not exist”, so i did it from my laptop, could this be the issue?
              I ran the .sh script and downloaded dependencies on the raspberry, archived the src folder contents and used my laptop to upload them.
                joanaz @Journeytojah
                @Journeytojah it usually happens when you zip the src folder, you have to go inside the src folder, and select all the files and folder, including node_modules, and certs, and compress them to a zip file.
                J G 2 Replies Last reply
                  @joanaz Thats what I did… I will try again.
                  • lucallmonL
                    lucallmon
                    Ok. So, I’ve decided to give up on this. The Readme files are not user-friendly. There is no step-by-step guide for install. I originally got very excited about this and if I could see it working, I might still again. However, I’m no programmer; I’m just the end user. So, good luck and let me know if you ever put out a video demo of it working and create a more user-friendly step-by-step install guide.
                      bartalluyn
                      I’ve succeeded in succesfully linking Alexa to the smart mirror. When I issue a command, the mirror responds automatically. It has automatic wake word detection, audio feedback, automatic authentication using a refresh token, connection through a mirror interface. In the background it uses Alexa Skills kit and DynamoDB to make the communication happen. Read about it on my blog :
                      [http://smartmirrorprojectblog.wordpress.com/](link url)
                      Go ahead and follow the blog to find out on the progression and further development.
                      Tips and suggestions welcome of course.
                        joanaz @bartalluyn
                        @bartalluyn really nice work! but since you have to change the Alexa Java client app to get it to work, it wouldn’t work for our application, since we need to get it to work with off-the-shelf Alexa or Alexa Echo. Right now my Alexa skill can only be used by one user, so I’m thinking about how to get it to work with multiple users so I can publish this skill, so people don’t need to worry about setting up Lambda and Alexa skill.
                        B 1 Reply Last reply
                          bartalluyn @joanaz
                          @joanaz That’s indeed something that wouldn’t work in that case.
                          It sounds like you would need something like account linking. What if the smart mirror would publish a service that takes and gives account credentials to hook on using the account linking functionality of a custom skill?
                          Thinking out of the box right now?
                          Also, suppose it works. When people start to install your module, and use your skill, your 1 million free lambda calls might expire sooner than you think? That’s one of the reasons why I’m not considering putting any of my skills out there.
                          • zman3Z
                            zman3
                            well just went through the whole thing again she still says there was a problem with the requested skills response and when i type hello into the service simulator the output is
                            • zman3Z
                              zman3
                              this is in the logs
                              START RequestId: cc7bfdd1-ebfd-11e6-8d16-b56e041c9162 Version: $LATEST
                              23:49:57
                              Unable to import module ‘index’: Error at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Object. (/var/task/index.js:23:14) at Module._compile (module.js:409:26) at Object.Module._extensions…js (module.js:416:10) at Module.load (
                              23:49:58
                              2017-02-05T23:49:58.043Z cc7bfdd1-ebfd-11e6-8d16-b56e041c9162 connect
                              • G
                                Gunwoody @joanaz
                                @joanaz Hi, when i zip all those files and folders up and try to upload them to Lambda i get "The deployment package of your Lambda function “xxxxxxxxx” is too large to enable inline code editing. However, you can still invoke your function right now. any ideas - it’s driving me mad. I thought it must be that i shouldn’t include the node_modules folder - can you confirm exactly what should be in the zip. Thanks
                                  joanaz @Gunwoody
                                  @Gunwoody you should definitely include node_modules, but my zip file is 5.1MB, I think the limit is 50MB. it’s not an error, you can ignore it.
                                  G 1 Reply Last reply
                                  • G
                                    Gunwoody @joanaz
                                    @joanaz Hi - thanks for the super quick reply :). Yes, my zip is also 5.1mb. I’ve tried several times but still get the same message.
                                    “The deployment package of your Lambda function “xxxxxxxxxxx” is too large to enable inline code editing. However, you can still invoke your function right now.”
                                    You say i can ignore it - but how do i know if the zip has uploaded ok?
                                      joanaz @Gunwoody
                                      @Gunwoody it says you can invoke your function right now. if it’s not ok, it would give you a red error message. Anyways, you can click on the test button, see whether your function works. but before that, you need to setup a test case
                                      • G
                                        Gunwoody @joanaz
                                        @joanaz Thanks again. I think it’s uploaded ok - not that it’s helped me get it working. I can get just about any other module running on MagicMirror but not this one. I think it’s just a case of i’m not sure what folders should be where. When i run it with the module in the config file i just get a white screen and can’t ‘alt’ out of it - Pi seems to crash. I think i’ll just have to give up as i’ve been trying for 3 days to get this running :(
                                          joanaz @bartalluyn
                                          @bartalluyn is your code on Github? I’m quite interested in your Alexa Java client, it’d be great if it was a Mirror Module, so Alexa and Mirror can communicate directly without going through AWS IoT.
                                            joanaz @Gunwoody
                                            @Gunwoody sorry to hear that. This is quite advanced as you have to setup AWS IoT, Lambda and Alexa skill, so it does need you to have some experiences with programming and using AWS services. I’m thinking about how to simplify this and get it to work with multiple users, but thanks for trying.
                                            • 10
                                            • 3 / 10
