    MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
    184 Posts 25 Posters 404.8k Views 23 Watching
      savage_gr1nd @Journeytojah
      @Journeytojah did you ever get yours to work? That’s about the same error I was getting
        joanaz @savage_gr1nd
        @savage_gr1nd my node_modules is 24.2MB. How are you testing the lambda function? try something simple, like the hello intent first
          savage_gr1nd @joanaz
          @joanaz that’s what I was doing.
          Also testing after uploading the code from the console.
          After work I want to try npm depues to see if that helps.
          But I also see you have latest define for the dependencies. What versions do you have installed so I can’t edit my package.json to install those smaller versions?
          J 1 Reply Last reply
            @savage_gr1nd this is my npm list
            ├─┬ alexa-sdk@1.0.6
            │ ├─┬ aws-sdk@2.9.0
            │ │ ├─┬ buffer@4.9.1
            │ │ │ ├── base64-js@1.2.0
            │ │ │ ├── ieee754@1.1.8
            │ │ │ └── isarray@1.0.0
            │ │ ├── crypto-browserify@1.0.9
            │ │ ├── jmespath@0.15.0
            │ │ ├── querystring@0.2.0
            │ │ ├── sax@1.1.5
            │ │ ├─┬ url@0.10.3
            │ │ │ └── punycode@1.3.2
            │ │ ├── uuid@3.0.0
            │ │ ├── xml2js@0.4.15
            │ │ └─┬ xmlbuilder@2.6.2
            │ │   └── lodash@3.5.0
            │ ├── i18next@3.5.2
            │ └── i18next-sprintf-postprocessor@0.2.2
            ├─┬ aws-iot-device-sdk@1.0.14
            │ ├── crypto-js@3.1.6
            │ ├── minimist@1.2.0
            │ ├─┬ mqtt@1.11.2
            │ │ ├─┬ commist@1.0.0
            │ │ │ └── leven@1.0.2
            │ │ ├─┬ concat-stream@1.6.0
            │ │ │ ├─┬ readable-stream@2.2.2
            │ │ │ │ ├── buffer-shims@1.0.0
            │ │ │ │ ├── process-nextick-args@1.0.7
            │ │ │ │ └── util-deprecate@1.0.2
            │ │ │ └── typedarray@0.0.6
            │ │ ├─┬ end-of-stream@1.1.0
            │ │ │ └─┬ once@1.3.3
            │ │ │   └── wrappy@1.0.2
            │ │ ├── help-me@0.1.0
            │ │ ├── inherits@2.0.3
            │ │ ├─┬ mqtt-connection@2.1.1
            │ │ │ ├── reduplexer@1.1.0
            │ │ │ └── through2@0.6.5
            │ │ ├── mqtt-packet@3.4.7
            │ │ ├── pump@1.0.2
            │ │ ├─┬ readable-stream@1.0.34
            │ │ │ ├── core-util-is@1.0.2
            │ │ │ ├── isarray@0.0.1
            │ │ │ └── string_decoder@0.10.31
            │ │ ├── reinterval@1.1.0
            │ │ ├─┬ split2@2.1.1
            │ │ │ └─┬ through2@2.0.3
            │ │ │   └── readable-stream@2.2.2
            │ │ └── xtend@4.0.1
            │ └─┬ websocket-stream@3.3.3
            │   ├─┬ duplexify@3.5.0
            │   │ ├── end-of-stream@1.0.0
            │   │ ├── readable-stream@2.2.2
            │   │ └── stream-shift@1.0.0
            │   ├─┬ through2@2.0.3
            │   └─┬ ws@1.1.1
            │     ├── options@0.0.6
            │     └── ultron@1.0.2
            ├─┬ google-images@2.0.0
            │ └─┬ got@6.7.1
            │   ├─┬ create-error-class@3.0.2
            │   │ └── capture-stack-trace@1.0.0
            │   ├── duplexer3@0.1.4
            │   ├── get-stream@3.0.0
            │   ├── is-redirect@1.0.0
            │   ├── is-retry-allowed@1.1.0
            │   ├── is-stream@1.1.0
            │   ├── lowercase-keys@1.0.0
            │   ├── safe-buffer@5.0.1
            │   ├── timed-out@4.0.0
            │   ├── unzip-response@2.0.1
            │   └─┬ url-parse-lax@1.0.0
            │     └── prepend-http@1.0.4
            └─┬ youtube-node@1.3.0
              ├── colors@1.0.3
              ├─┬ prompt@0.2.14
              │ ├── pkginfo@0.4.0
              │ ├─┬ read@1.0.7
              │ │ └── mute-stream@0.0.7
              │ ├── revalidator@0.1.8
              │ ├─┬ utile@0.2.1
              │ │ ├── async@0.2.10
              │ │ ├── deep-equal@1.0.1
              │ │ ├── i@0.3.5
              │ │ ├─┬ mkdirp@0.5.1
              │ │ │ └── minimist@0.0.8
              │ │ ├── ncp@0.4.2
              │ │ └─┬ rimraf@2.5.4
              │ │   └─┬ glob@7.1.1
              │ │     ├── fs.realpath@1.0.0
              │ │     ├── inflight@1.0.6
              │ │     ├─┬ minimatch@3.0.3
              │ │     │ └─┬ brace-expansion@1.1.6
              │ │     │   ├── balanced-match@0.4.2
              │ │     │   └── concat-map@0.0.1
              │ │     └── path-is-absolute@1.0.1
              │ └─┬ winston@0.8.3
              │   ├── colors@0.6.2
              │   ├── cycle@1.0.3
              │   ├── eyes@0.1.8
              │   ├── pkginfo@0.3.1
              │   └── stack-trace@0.0.9
              └─┬ request@2.53.0
                ├── aws-sign2@0.5.0
                ├── bl@0.9.5
                ├── caseless@0.9.0
                ├─┬ combined-stream@0.0.7
                │ └── delayed-stream@0.0.5
                ├── forever-agent@0.5.2
                ├─┬ form-data@0.2.0
                │ └── async@0.9.2
                ├─┬ hawk@2.3.1
                │ ├── boom@2.10.1
                │ ├── cryptiles@2.0.5
                │ ├── hoek@2.16.3
                │ └── sntp@1.0.9
                ├─┬ http-signature@0.10.1
                │ ├── asn1@0.1.11
                │ ├── assert-plus@0.1.5
                │ └── ctype@0.5.3
                ├── isstream@0.1.2
                ├── json-stringify-safe@5.0.1
                ├─┬ mime-types@2.0.14
                │ └── mime-db@1.12.0
                ├── node-uuid@1.4.7
                ├── oauth-sign@0.6.0
                ├── qs@2.3.3
                ├── stringstream@0.0.5
                ├─┬ tough-cookie@2.3.2
                │ └── punycode@1.4.1
                └── tunnel-agent@0.4.3
              @joanaz awesome!
              I’m sure between the two methods I can shrink it down enough. At least I hope i can haha
              I’m way too excited to get this running and play with it. Thank you!
                @savage_gr1nd yeah, i was really excited when i got it working. :) let me know when you do!
                S 3 Replies Last reply
                  @joanaz it’s seriously been 3 days after work. Of playing with code for 7 hours each day. It’s kicking my ass but I’ll get it lol
                    @joanaz so I was thinking, the mirrormirror module, can it be configured to play “next up” in the YouTube api? Instead of loop? :/
                      @joanaz okay. Finally. Got a response. Now. The mmm.
                      Everytime I touch the config.js doesn’t load up. Can you give me a few more details for setting up the module?
                      IE. Where to run npm install for aws-iot-device-sdk lol
                        @savage_gr1nd erhhh, inside the module folder. you also need to copy the certs folder over
                          @joanaz I’m sorry I’m being retarded. I’ve been staring at json too long. In the magic mirror module folder or the mirrormirror folder?
                            @savage_gr1nd ?? to run npm install? in the magic mirror module folder, where package.json is
                            S 2 Replies Last reply
                              @joanaz okay. Like I said I’m sorry. This is my first pi project AND my first module for magicmirror.
                              When putting mirrormirror in the config.js, does it matter where in the list? I put inew the config info and then it says I screwed up the config.js.
                                @joanaz soooo close. On/off modules. Check. But no text on screen.
                                Find a video? Text on screen. No video. And how do you close my supposed video?
                                Any help? I’m so close I can taste victory!
                                Update - google developer console says success connection with api on that command. So I’m guessing it’s a player launch failure or missing a folder for youtube-node?
                                  @savage_gr1nd there’s no text on screen when you turn on/off module. can you get display text or display image commands to work? right now the text/image/video will remain on the screen, the video will be played in a loop, but you can simply add a timeout to hide this module after few seconds. The ‘next up’ Youtube video idea is also cool, do you think you can implement it yourself?
                                    joanaz
                                    Just out of curiosity, which cities are you guys in? I’m in New York.
                                      @joanaz I’m in California.
                                      And I could try if I can ever figure out why I can’t get video to pop up in the first place lol and no I can’t get images to work either. That tests error in alexa skill Console so I’m digging into you tube first. Which tests positive.
                                      I say find a video of… and she responds and puts the text on screen. But the url window doesn’t show.
                                        Journeytojah
                                        I still didn’t get mine to work, I haven’t tried again to be honest…
                                        I am in Spain, if that makes a difference.
                                        I was trying out other options for voice control like Jasper, etc; no luck so far.
                                        I might come back to this module tonight and try to get it running.
                                        Should I try to set it up for the European region that supports Alexa skills? (which is Ireland afaik)
                                          joanaz @Journeytojah
                                          @Journeytojah I think the region is why some people couldn’t get it to work. Right now, Lambda only works with US East regions. So better use US East for every AWS services needed here.
                                            Journeytojah @joanaz
                                            @joanaz said in MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images:
                                            I had US East selected, but maybe because I am not physically located in the US it somehow gets blocked by some ISP somewhere along the way.
                                            To me thats what it looked like, a connectivity issue.
                                            And I know Alexa Skills with Lambda are only supported in some regions, but that includes one European one, the one in Ireland, so ill try that one.
                                            Anyway, after seeing how impossible it is to work with Jaster/So.nus and so on, I will go back and give this another try…
                                            S J 2 Replies Last reply
                                            • 10
                                            • 5 / 10
