    Voice Control on MagicMirror Synology Docker
    14 Posts 3 Posters 4.5k Views 4 Watching
    • E Offline
      Egnos @sdetweil
      @sdetweil said in Voice Control on MagicMirror Synology Docker:
      esign assumes the hardware is near
      To solve the PIR problem I could wire the sensor to the GPIO of the Raspberry connected to the monitor (away from the Raspberry Server on the Synology) and turn the monitor off / on using a few lines of code (something I should find on the internet … do you have any advice ?) that run externally to the MM.
      For voice commands I would like to use GoogleHome/EchoDot Alexa (better quality of voice recognition, integrated speaker, google/alexa functions, etc …) to send commands to the MM Server.
      This last part is still being studied … I see that someone on the forum has tried the GH-MM combination but I don’t see many results …
        sdetweil @Egnos
        @egnos alexa, use MMM-AlexaControl, but it sends to the server side.
        so you could run FULL MM on synology and view on pi same as before.
        PIR … quick search turns up lots of python based solutions
        • E Offline
          Egnos @cyberphox
          @cyberphox said in Voice Control on MagicMirror Synology Docker:
          I run mine in Docker on my Synology. Use a pi behind the mirror for viewing with PIR hooked up to it.
          Very Good
          As for voice, yeah you might be outta luck there.
          I know it! Someone on the forum has done something … but there is no feedback !
          • C Offline
            cyberphox @sdetweil
            @sdetweil yes that’s right
