    Trouble getting Background Image to Show
    27 Posts 2 Posters 10.1k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17 @sdetweil
      @sdetweil I’m just saying that the file address is good as entered.
      In main.css you have
      html {
        cursor: none;
        overflow: hidden;
        background: var(--color-background);
        user-select: none;
        font-size: var(--font-size);
      set for background. Is that causing issues? custom.css should override that, shouldn’t it?
        sdetweil @ankonaskiff17
        @ankonaskiff17 where is your background set… body, there is an z-order too…
        i use fullscreen_background position for my background images
        if u look at the developer window elements tab to find your background, where is in the the css stack?
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
          @sdetweil Right at the top just below html. The way I understand is that it will load html first, then body. My html is an abbreviated version of main.css html
          custom.css
          main.css
            @ankonaskiff17 body supercedes
            html.
            u should look in the developers window, elements tab to see the actual css tree
            ctrl-shift-i, select elements tab.
              @sdetweil I’ve been doing that.
                @ankonaskiff17 so u can turn off things with a click in front. so disable the background color
                  @sdetweil I’ve wrestled with this all morning and exhausted every combination I could imagine, I decided to try sticking a color in as shown below. Not sure if anything can be inferred if it will accept a background color but not a background image. I am ignorant of the vagaries of js but is it possible that background: var(--color-background); in is locking me i n to only color options since the default is set in
                  :root {
                  --background-color #000
                  body {
                  background: red;
                    @ankonaskiff17 possibly… disable it in the dev window… uncheck it… right side, near the bottom (that is closest to main.css while top is closest to latest css.
                      @ankonaskiff17 so I added a body with a background image, using the MM web server in my custom.css
                      body {
                        background-image: url("http://localhost:8090/modules/images/testimage.jpg")
                      and then started MM
                      and got
                      u can see the two body clauses on the right, top is custom.css (if u hover over the name it tells u where it came from)
                        sdetweil
                        then I added a root entry to custom.css
                        root: {
                          background-color: black;
                        html {
                        /*  cursor: none; */
                        body {
                        and got
                        notice border around pic
                        then turned it off in the dev window
                        border gone
                        • 3 / 3
