    Weather Forecast - Inver min max
    5 Posts 3 Posters 1.3k Views 3 Watching
      Bira
      Hello everyone.
      I’ve been slowly getting my mirror to my taste and now have a pet peeve that I’m unable to get rid of.
      To me it feels kinda weird read left to right as max temp and min temp. I was able to inspect the page and find those classes and change font, padding and whatnot but I don’t know how to swap those information.
      P.S.: I’m using the old weather forecast module because I’m afraid I’ll have to redo some styling if I update.
      Thank you.
      mumblebajM S 2 Replies Last reply Reply Quote 0
      • mumblebajM Offline
        mumblebaj Module Developer @Bira
        @bira Unfortunately it is defined in the MMM-weatherforecast.js when the table is built.
          sdetweil @Bira
          @bira as @mumblebaj says, this is hard coded
          but could be easily changed
          edit the file
          MMM-WeatherForecast.js and swap (cut/paste) these two sections of code
          starting on lines 166 and 171
          				var maxTempCell = document.createElement("td");
          				maxTempCell.innerHTML = forecast.maxTemp.replace(".", this.config.decimalSymbol) + degreeLabel;
          				maxTempCell.className = "align-right bright max-temp";
          				row.appendChild(maxTempCell);
          				var minTempCell = document.createElement("tr");
          				minTempCell.innerHTML = forecast.minTemp.replace(".", this.config.decimalSymbol) + degreeLabel;
          				minTempCell.className = "align-right min-temp";
          				row.appendChild(minTempCell);
          and u have to remember that u did this to the module and any update would revert it
            mumblebaj Module Developer @sdetweil
            @sdetweil Yeah, I didn’t want to advise that for exactly that reason.
              Bira
              Thanks @mumblebaj and @sdetweil. Guess I’ll try what you guys suggested since I don’t plan on updating things often. I thought there could be a way to do so without changing the code.
