    MMPM gui
    6 Posts 3 Posters 2.7k Views 3 Watching
      mayfield
      Hi all
      I’m having some trouble with the mmpm module, I have installed it as per the instructions and I can issue commands from the terminal line like - mmpm mm-ctl --hide compliments clock and it works however I can’t seem to get the gui to work.
      When I run mmpm env i get
        "MMPM_MAGICMIRROR_ROOT": "/home/pi/MagicMirror",
        "MMPM_MAGICMIRROR_URI": "http://192.168.1.24:8080",
        "MMPM_MAGICMIRROR_PM2_PROCESS_NAME": "",
        "MMPM_MAGICMIRROR_DOCKER_COMPOSE_FILE": "",
        "MMPM_IS_DOCKER_IMAGE": false
      I have added the module to config.js
      I have whitelisted the ip address of the laptop
      When I type http://192.168.1.24:8080 I get the magicmirror I don’t see the mmpm gui
      I’m not sure what I’ve missed
        mayfield
        This is a screen shot when I run the mmpm install --gui
        alt text
        swvalentiS 1 Reply Last reply Reply Quote 0
        • swvalentiS Offline
          swvalenti Project Sponsor @mayfield
          @mayfield
          sudo systemctl status nginx
          You can try and reload and run that mmpm command again
          sudo systemctl reload nginx
            mayfield @swvalenti
            @swvalenti said in MMPM gui:
            @mayfield
            Hi thanks for the tip
            I have a feeling now that the problem may be Citadel server, Some time back before I found Magicmirror I was playing with Citadel email server. When I type http://192.168.1.24:8080 when MM is off the Citadel login web page shows up.
            I’m wondering if that would cause a conflict and I’m not sure how to remove citadel from the rpi
              sdetweil @mayfield
              @mayfield u can move mm to a different port also
                mayfield @sdetweil
                @sdetweil Thanks for the tip
                I was reading through the command line options information and noticed when I ran mmpm list --gui-url in my terminal it returned http://127.0.1.1:7890 so I then changed the 8080 to 7890 and presto the mmpm web gui poped up not sure why?
                alt text
