    Client wont keep Modules up-to-date
    21 Posts 3 Posters 7.2k Views 3 Watching
      sdetweil @karsten13
      @karsten13 so I have to restart the container after making config changes?
      • C Offline
        codac @sdetweil
        @sdetweil yes, you should do that.
        • C Offline
          codac
          I have still not fixed this.
          Servers IP: 192.168.0.23 (local Port 8036, container-port: 8080)
          On the client I get the following error:
          Unable to connect to server: (Error: Unable to read config from server (http://192.168.0.23:8036/config/ (connect ECONNREFUSED 192.168.0.23:8036)
          The servers config is set to:
                  address: "0.0.0.0",
          	port: 8080,
          	basePath: "/",
          	ipWhitelist: ['0.0.0.0/0', '127.0.0.1', '::ffff:127.0.0.1', '::1', '192.168.0.0/24', '172.17.0.0/24'],
          Any ideas why the client wont get the servers config?
          S karsten13K 2 Replies Last reply Reply Quote 0
            sdetweil @codac
            @codac first, remove the ipWhitelist , set to []
            then try
            .and the IP address used is the docker host IP address, right.
            never use the containers direct address for any code not running ON the docker host machine
            where is client running?
            if mm rejected the connection due to whitelist you should have seen it in the mm messages
            i see a message like this
            Access denied to IP address: 192.168.2.106
            my config
            	address: "192.168.2.106", 	// Address to listen on, can be:
            	port: 8090,
            	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
            	ipWhitelist: ["127.0.0.1"],
            • karsten13K Offline
              karsten13 @codac
              @codac
              may you must open the additional port in the docker setup and add the line with 8036 (untested) in your docker-compose.yml:
                  ports:
                    - "8080:8080"
                    - "8036:8036"
                sdetweil @karsten13
                @karsten13 said in Client wont keep Modules up-to-date:
                ports:
                  - "8080:8080"
                  - "8036:8036"
                why wouldn’t
                     ports:
                           "8036:8080"
                be enough?
                  karsten13 @sdetweil
                  @sdetweil think you are right …
                    sdetweil @karsten13
                    @karsten13 actually I think you were closer…
                    I know a module that uses the port number in a url it presents…
                    (MMM-Config in the QR code)
                    8080 won’t work, but if the mapping was added
                    so
                         ports:
                               "8036:8080"
                               "8080:8080"
                    would be needed
                    and if u need to do that, then 8080 on the docker host needs to be used, so then no need for 8036
                         ports:
                               "8080:8080"
                    but can’t run two container instances
                      @sdetweil also, my MM uses 8090 not to collide with another app.
                        karsten13 @sdetweil
                        @codac
                        if I read this correctly your setup is
                        ports:
                          - "8036:8080"
                        So mm should be reachable under 192.168.0.23:8036.
                        If not the client ip is may not white listed, I would try ipWhitelist: [], in the server config for testing.
                        Another question: Is 192.168.0.23:8036 not reachable in general (e.g. in a browser) or only not reachable running the clientonly command?
                        • 2 / 3
