    Strange behavior TV / Browser & MMM-Carousel Slides are being ignored
    12 Posts 4 Posters 2.1k Views 3 Watching
    • W Offline
      wageck Project Sponsor
      i test mm-pages and duplicate the MMM-Todo and the calendar but the calendar modul is not showing something, on the page where i set todo to right it is to see ?
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * !! ACHTUNG Die config.js.template muss bearbeitet werden !!
       * Link zur CSS Aufteilung: https://forum.magicmirror.builders/topic/286/regions
      var config = {
      	address: "0.0.0.0", 	// Address to listen on, can be:
      	port: 8080,					// Default 8080
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: [], 	// Set [] to allow all IP addresses ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.0/24"]
      	language: "de",
      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      	timeFormat: 24,
      	units: "metric",
      	// serverOnly: true/false/"local" ,
      	// starts serveronly and then starts chrome browser
      // Beginn: Modul um die Aktuelle Page in der Übersicht anzuzeigen
       module: "MMM-page-indicator",
       //pages: {all: "bottom_center"},
      		position: "bottom_center",
      		carouselId: 510
      // Ende: Modul um die Aktuelle Page in der Übersicht anzuzeigen
      // Beginn: Motivationstext
      	module: "helloworld",
      	//pages: {"all": "top_center"},
      	position: "top_center",
      		carouselId: 520 ,
      		text: "Motivation juhu"
      // Ende: Motivationstext
      // Begin: Modul zur Wetter INformation:
      	module: "currentweather",
      	header: "Heute",
      		carouselId: 530 ,
      		locationID: "2891480", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      		appid: "daf92bc5adeb64ee90406481ab2289b0",
      		units: "metric",
      		degreeLabel: true,
      		timeFormat: "24",
      		lang: "de"
      	module: "weatherforecast",
      	header: "Vorhersage",
      		carouselId: 540 ,
      		units: "metric",
      		degreeLabel: true,
      		timeFormat: "24",
      		lang: "de"
      // Ende: Modul zur Wetter INformation:
      // Begin: Modul um RSS Feeds einzubinden: alle Seiten
      	module: "newsfeed",
      	//pages: {all: "bottom_bar"},
      	position: "bottom_bar",
      	header: "News",
      		carouselId: 550 ,
      		showSourceTitle: true,
      		showPublishDate: true,
      		showAsList: true,
      		maxNewsItems: 4,
      		ignoreOldItems: true,
      		ignoreOlderThan: 604800000,
      			feeds: [
      					title: "Weierhof",
      					url: "https://www.weierhof.de/feed/"
      					title: "Webindividualschule",
      					url: "http://fetchrss.com/rss/6146348142e4574b423ea3c26146346d1410593c18432932.xml"
      // Ende: Modul um RSS Feeds einzubinden: Alle Seiten
      // Begin: Modul um Tasks per webcal auszulesen für die nächsten 1 Tage
      			module: "MMM-ToDo10",
      			header: "Familie Heute",
      			//pages: {FamilieHeute: "top_left"},
      				carouselId: 10 ,
      				maximumEntries: 14,
      				maximumNumberOfDays: 1,
      				broadcastEvents: false,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				fetchInterval: 150000,
      				hidePrivate: false,
      				hideCompleted: true,
      				showLocation: false,
      				fade: false,
      				colored: false,
      				coloredSymbolOnly: false,
      				displaySymbol: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/familie.ics",
      			module: "MMM-ToDo11",
      			header: "Papa Heute",
      			//pages: {PapaHeute: "top_left"},
      				carouselId: 11 ,
      				maximumEntries: 14,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/papa.ics",
      			module: "MMM-ToDo12",
      			header: "Aufgaben Mama Heute",
      			//pages: {MamaHeute: "top_left"},
      				carouselId: 12 ,
      				maximumEntries: 14,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/mama.ics",
      			module: "MMM-ToDo13",
      			header: "Aufgaben Leon Heute",
      			//pages: {LeonHeute: "top_left"},
      				carouselId: 13 ,
      				maximumEntries: 14,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/leon.ics",
      			module: "MMM-ToDo14",
      			header: "Aufgaben Silas Heute",
      			//pages: {SilasHeute: "top_left"},
      				carouselId: 14 ,
      				maximumEntries: 14,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/silas.ics",
      			module: "MMM-ToDo15",
      			header: "Aufgaben Samuel",
      			//pages: {SamuelHeute: "top_left"},
      				carouselId: 15 ,
      				maximumEntries: 14,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/samuel.ics",
      			module: "MMM-ToDo16",
      			header: "Offene Aufgaben",
      			//pages: {Offen: "top_right"},
      				carouselId: 16 ,
      				maximumEntries: 14,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/offen.ics",
      			module: "MMM-ToDo17",
      			header: "Offene wichtige und dringende Aufgaben",
      			//pages: {Offen: "top_left"},
      				carouselId: 17 ,
      				maximumEntries: 14,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/offen-wichtig.ics",
      // Ende: Modul um Tasks per webcal auszulesen für die nächsten 1 Tage
      // Begin: Modul um Tasks per webcal auszulesen für die nächsten 7 Tage
      			module: "MMM-ToDo20",
      			header: "Aufgaben diese Woche",
      			//pages: {FamilieHeute: "bottom_left"},
      			position: "bottom_left",
      				carouselId: 20 ,
      				maximumEntries: 11,
      				maximumNumberOfDays: 7,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      			module: "MMM-ToDo21",
      			//pages: {PapaHeute: "bottom_left"},
      				carouselId: 21 ,
      				maximumEntries: 11,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      			module: "MMM-ToDo22",
      			//pages: {MamaHeute: "bottom_left"},
      				carouselId: 22 ,
      				maximumEntries: 11,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      			module: "MMM-ToDo23",
      			//pages: {LeonHeute: "bottom_left"},
      				carouselId: 23 ,
      				maximumEntries: 11,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      			module: "MMM-ToDo24",
      			//pages: {SilasHeute: "bottom_left"},
      				carouselId: 24 ,
      				maximumEntries: 11,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      			module: "MMM-ToDo25",
      			//pages: {SamuelHeute: "bottom_left"},
      				carouselId: 25 ,
      				maximumEntries: 11,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: false,
      				fade: false,
      				colored: false,
      				calendars: 	[
      // Ende: Modul um Tasks per webcal auszulesen für die nächsten 7 Tage
      // Begin: Modul um Termine auszulesen für die nächsten 1 Tage
      			module: "calendar30",
      			header: "Termine Familie Heute",
      			//pages: {FamilieHeute: "top_right"},
      				carouselId: 30 ,
      				maximumEntries: 11,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: true,
      				hideOngoing: true,
      				excludedEvents: ["Abgesagt:"],
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/familie_cal.ics",
      			module: "calendar31",
      			header: "Termine Mama Heute",
      			//pages: {MamaHeute: "top_right"},
      				carouselId: 31 ,
      				maximumEntries: 11,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: true,
      				hideOngoing: true,
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/mama_cal.ics",
      			module: "calendar32",
      			header: "Termine Papa Heute",
      			//pages: {PapaHeute: "top_right"},
      				carouselId: 32 ,
      				maximumEntries: 11,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: true,
      				hideOngoing: true,
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/papa_cal.ics",
      			module: "calendar33",
      			header: "Termine Leon Heute",
      			//pages: {LeonHeute: "top_right"},
      				carouselId: 33 ,
      				maximumEntries: 11,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: true,
      				hideOngoing: true,
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/leon_cal.ics",
      			module: "calendar34",
      			header: "Termine Silas Heute",
      			//pages: {SilasHeute: "top_right"},
      				carouselId: 34 ,
      				maximumEntries: 11,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: true,
      				hideOngoing: true,
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/silas_cal.ics",
      			module: "calendar35",
      			header: "Termine Samuel Heute",
      			//pages: {SamuelHeute: "top_right"},
      				carouselId: 35 ,
      				maximumEntries: 11,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: true,
      				hideOngoing: true,
      				fade: false,
      				colored: false,
      				calendars: 	[
      						url: "http://localhost:8080/modules/MMM-ToDo/nextcloudexport/export/samuel_cal.ics",
      // Ende: Modul um Termine auszulesen für die nächsten 1 Tage
      // Begin: Modul um Termine auszulesen für die nächsten 7 Tage
      			module: "calendar40",
      			header: "Termine diese Woche",
      			//pages: {FamilieHeute: "bottom_right"},
      			position: "bottom_right",
      				carouselId: 40 ,
      				maximumEntries: 12,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: true,
      				hideOngoing: true,
      				fade: false,
      				colored: false,
      				calendars: 	[
      			module: "calendar41",
      			//pages: {MamaHeute: "bottom_right"},
      				carouselId: 41 ,
      				maximumEntries: 12,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: true,
      				hideOngoing: true,
      				fade: false,
      				colored: false,
      				calendars: 	[
      			module: "calendar42",
      			//pages: {PapaHeute: "bottom_right"},
      				carouselId: 42 ,
      				maximumEntries: 12,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: true,
      				hideOngoing: true,
      				fade: false,
      				colored: false,
      				calendars: 	[
      			module: "calendar43",
      			//pages: {LeonHeute: "bottom_right"},
      				carouselId: 43 ,
      				maximumEntries: 12,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: true,
      				hideOngoing: true,
      				fade: false,
      				colored: false,
      				calendars: 	[
      			module: "calendar44",
      			//pages: {SilasHeute: "bottom_right"},
      				carouselId: 44 ,
      				maximumEntries: 12,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: true,
      				hideOngoing: true,
      				fade: false,
      				colored: false,
      				calendars: 	[
      			module: "calendar45",
      			//pages: {SamuelHeute: "bottom_right"},
      				carouselId: 45 ,
      				maximumEntries: 12,
      				maxTitleLength: 50,
      				wrapEvents: false,
      				maxTitleLines: 1,
      				hidePrivate: true,
      				hideOngoing: true,
      				fade: false,
      				colored: false,
      				calendars: 	[
      // Ende: Modul um Termine auszulesen für die nächsten 7 Tage
      // Beginn: Modul für die Fernsteuerung per Webrowser
       module: 'MMM-Remote-Control',
       // uncomment the following line to show the URL of the remote control on the mirror
       // position: "top_bar",
       // you can hide this module afterwards from the remote control itself
      		carouselId: 680 ,
       customCommand: {}, // Optional, See "Using Custom Commands" below
       showModuleApiMenu: true, // Optional, Enable the Module Controls menu
       secureEndpoints: false, // Optional, See API/README.md
       // uncomment any of the lines below if you're gonna use it
       customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
      	// apiKey: "", // Optional, See API/README.md for details
       // classes: {} // Optional, See "Custom Classes" below
      // Ende: Modul für die Fernsteuerung per Webrowser
      // Beginn: Modul das Bewegung über die Kamera erkennt
       module: 'MMM-SleepWake',
      	// pages: {all: "bottom_bar"},
      	config:{
       carouselId: 690 ,
      	 delay: '14', // amount of time with no motion before sleeping, in minutes
       mode: 'PI',
       pi_on: 'wget http://192.168.1.241:8083/fhem?cmd=set%20FamilienplanerTV%20on -O /dev/null',
       pi_off: 'wget http://192.168.1.241:8083/fhem?cmd=set%20FamilienplanerTV%20off -O /dev/null'
      // Ende: Modul das Bewegung über die Kamera erkennt
      // Beginn: Modul zur Nutzung mehrere Pages
              module: 'MMM-pages',
                      modules:
                          [[ "MMM-ToDo10", "MMM-ToDo20", "calendar30", "calendar40"],
                           [ "MMM-ToDo11", "MMM-ToDo21", "calendar31", "calendar41"],
      		     [ "MMM-ToDo12", "MMM-ToDo22", "calendar32", "calendar42"],
      		     [ "MMM-ToDo13", "MMM-ToDo23", "calendar33", "calendar43"],
      		     [ "MMM-ToDo14", "MMM-ToDo24", "calendar34", "calendar44"],
      		     [ "MMM-ToDo15", "MMM-ToDo25", "calendar35", "calendar45"],
      		     [ "MMM-ToDo16", "MMM-ToDo26", "calendar30", "calendar40"]],
                      fixed: ["helloworld", "MMM-page-indicator", "newsfeed", "currentweather", "weatherforecast"],
                      //hiddenPages: {
                      //    "screenSaver": [ "clock", "MMM-SomeBackgroundImageModule" ],
                      //    "admin": [ "MMM-ShowMeSystemStatsModule", "MMM-AnOnScreenMenuModule" ],
      		rotationTime: 10000,
      // Ende: Modul zur Nutzung mehrere Pages
      // Ende: aller Module
        sdetweil @wageck
        @wageck I do not know…
        but I would test by disabling every module (add disabled: true, after the module: … line ) but one
        and test to make sure that the one module u want works… for each such module
        then turn back on pages,
        u could also do this in another copy of MM (copy the folder and edit there)
        or use the default config in the copy and add your one definition, copy that folder from your full config
