    MMM-Scenes
    12 Posts 5 Posters 4.8k Views 5 Watching
      sdetweil @MMRIZE
      @MMRIZE thanks, I had not seen anonymous object before., or the hidden object property
      • N Offline
        Norder @MMRIZE
        @MMRIZE
        Thank you for your quick reply!
        I really appreciate you taking the time to provide an example for me to work with. Most of this makes sense, despite my lack of programming skills.
        Can I use the predefined PageDown animation within the custom definition? I’d like to avoid having to remake animations you’ve already provided.
        My other question is how do I set temporary identifiers to the modules so the correct animation gets pulled? I don’t think module name or classes alone will work since I need the identifier to change based upon scene selection. Nor do I want to load multiple instances of the modules as I’m already pushing the heat up a bit. Please forgive my ignorance here, I’m sure it’s already well documented, I just don’t know where to begin.
