    MMM-Scenes
    12 Posts 5 Posters 6.4k Views 5 Watching
    • doctorwhenD
      doctorwhen
      Very cool. Thanks for the excellent module, i’m integrating it into my mirror without much difficulty. The only problem I’ve run into thus far is with the example config which I had to modify slightly to get it working on my setup.
      All I changed was the weather apikey but that didn’t work (blank screen, electron exits). I then changed the declaration of config from const to var and the example config works:
      const config = {
      to
      var config = {
      Otherwise, wow!
        MMRIZE @MMRIZE
        UPDATED
        1.1.0 (2021-11-01)
        • ADDED : MMM-TelegramBot commandable. (Thanks to @doctorfree)
        • N
          Norder
          Hello! Thank you for the amazing work you’ve done. The scenes module was exactly what I needed to pop my MM up a notch. I do have some questions, however.
          How do you apply an expel/admit animation to specific modules only and not the whole scene?
          Can you do this for transitions between specific scenes? i.e. pageDown animation if arriving from scene 2, pageUp if arriving from scene 3?
          I’m wondering if there is a simple way to accomplish this, like an extra class tag within a module itself to call the animation type? My end goal is to have swipe gestures change scenes and have the animations change based upon the previous scene.
          Thanks again!
          M 3 Replies Last reply
            MMRIZE @Norder
            @Norder Thanks for your interesting. I’m on the holidays so cannot look inside deeply.
            After return, I’ll reply you sorry.
              MMRIZE @Norder
              @Norder
              You can do it with “custom animation function” https://github.com/MMRIZE/MMM-Scenes#--custom-animation-function
              You can define specific animation and module which you want to apply, then describe it in the “scenario”. Ideally it’s all, but real-world sample i will show you in a week (after my return)
                MMRIZE @Norder
                @Norder
                To assign specific animation to the specific module, you can use “custom animation function” in your “scenario”.
                To specify the module, you can use module property in animation function. For example, you can use module.name , module.data.classes or module.data.position (or whatever you want) (https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties)
                  scenario: [
                      expelAnimation: ({ module, moduleWrapper, duration }) => {
                        if (module.name === 'clock') {
                          return new Promise((resolve, reject) => {
                            moduleWrapper.animate([
                              { transform: 'scale(1,1)', opacity: 1 },
                              { transform: 'scale(10, 10)', opacity: 0 }
                            ], { duration }).onfinish = resolve
                        } else {
                              { transform: 'scale(1, 1)', opacity: 1 },
                              { transform: 'rotate(-360deg) scale(0, 0)', opacity: 0 }
                Well, this example looks not so simple, I hope you can follow it.
                S N 2 Replies Last reply
                  sdetweil @MMRIZE
                  @MMRIZE said in MMM-Scenes:
                  javascript programming question
                  why do you use {} around the function parms? usually this creates an object, which same labeled properties
                  but you don’t use them like properties of an object in the function
                  what extra value did u get from the braces?
                  M 1 Reply Last reply
                    MMRIZE @sdetweil
                    let x = {
                      foo: 123,
                      bar: 456,
                      baz: "please don't touch me"
                    function A (obj) {
                      console.log(obj.foo)
                      console.log(obj.bar)
                      // obj.baz = 'oops I did it again"
                    function B (Foo, Bar) {
                      console.log(Foo)
                      console.log(Bar)
                      // safe for .baz or object itself
                      // However, you must keep the order and number of parameters.
                    function C ({bar, foo}) {
                      console.log(foo)
                      console.log(bar)
                      // You don't need to keep the order and number of parameters.
                    function C2 (obj) {
                      let {bar, foo} = obj
                      console.log(foo)
                      console.log(bar)
                      // obj.baz = 'oops I did it again'
                    A(x)
                    B(x.foo, x.bar)
                    C(x)
                    C2(x)
                      sdetweil @MMRIZE
                      @MMRIZE thanks, I had not seen anonymous object before., or the hidden object property
                      • N
                        Norder @MMRIZE
                        @MMRIZE
                        Thank you for your quick reply!
                        I really appreciate you taking the time to provide an example for me to work with. Most of this makes sense, despite my lack of programming skills.
                        Can I use the predefined PageDown animation within the custom definition? I’d like to avoid having to remake animations you’ve already provided.
                        My other question is how do I set temporary identifiers to the modules so the correct animation gets pulled? I don’t think module name or classes alone will work since I need the identifier to change based upon scene selection. Nor do I want to load multiple instances of the modules as I’m already pushing the heat up a bit. Please forgive my ignorance here, I’m sure it’s already well documented, I just don’t know where to begin.
