    MMM-Remote-Control can not turn ON monitor
    23 Posts 3 Posters 5.7k Views 3 Watching
      sdetweil @anaghd
      @anaghd mine too!
        anaghd @sdetweil
        @sdetweil See if this gives you any ideas. I couldn’t figure it out.
        https://githubmemory.com/repo/Jopyth/MMM-Remote-Control/issues/178?page=1
          sdetweil @anaghd
          @anaghd vcgencmd turns off the hdmi port… not the monitor… and then I get an ugly no input message
            anaghd @sdetweil
            @sdetweil I was wondering if we can do something similar to what they have done but modify it for cec utilities, especially in regards to the status command.
              sdetweil @anaghd
              @anaghd sorry don’t understand
              if we could do something??
                anaghd @sdetweil
                @sdetweil can we modify this to include cec-utility commands instead of the vcgencmd?
                monitorStatusCommand: ‘if vcgencmd display power | grep 1 >/dev/null 2>&1; then echo true; else echo false; fi’
                  sdetweil @anaghd
                  @anaghd oh… I don’t know the module internals or config at all…
                    anaghd @sdetweil
                    @sdetweil I finally have a solution that worked for me.
                    In the node_helper.js file, there is a function with the name “monitorControl”. In there, I used 2 things as shown below. Essentially, we want it to execute both, vcgen and cec, when we turn the monitor on and off. So I added the cec command to the already existing vcgencmd command. Now it looks like this.
                    this.thisConfig.customCommand.monitorOnCommand:
                    “vcgencmd display_power 1 && sudo echo 'on 0 | cec-client -s -d 1”;
                    this.thisConfig.customCommand.monitorOffCommand:
                    “vcgencmd display_power 0 && sudo echo 'standby 0 | cec-client -s -d 1”;
                    I did not change anything in the statusCommand part.
                    After that, I removed the customCommands from my config so that the module uses the default commands above for turning monitor ON and Off. That worked for me. See if it works for you.
                    S S 2 Replies Last reply Reply Quote 0
                      sdetweil @anaghd
                      @anaghd no, but you could have put the same strings in your custom commands
                        anaghd @sdetweil
                        @sdetweil I tried doing that initially but that did not work for me.
                        • 2 / 3
