    How do I delete a module?
    2 Posts 2 Posters 793 Views 2 Watching
      r3d6
      How do I delete a module? Please explain to me like I’m 3 YO. I know nothing about coding
        sdetweil @r3d6
        @r3d6
        open a terminal window
        ctrl-alt-t
        cd ~/MagicMirror/modules
        rm -rf   xxxxx
        where xxxxx is the module you have installed and now want to delete.
        exact letter case matters
        foo is not the same as Foo on Linux
        then do
        cd ~/MagicMirror/config
        nano config.js
        use the arrow keys on the keyboard to move up and down, left and right
        find the entry
        module:"xxxxx`,
        where xxxxx is the module u want to delete
        move the cursor to the right end of that line
        hit the enter key
        type
         disabled:true,
        hit Ctrl-o
        hit enter
        hit ctrl-x
        you will be back at the terminal window prompt
        do
        cd ~/MagicMirror
        you can now restart MagicMirror however you do that
        npm start
        or
        pm2 restart
        read the two links in my signature below
        we did the disable approach cause it’s the easiest to do, and requires the least amount of content format knowledge.
