    Calendar events showing on wrong day.
    66 Posts 3 Posters 35.8k Views 3 Watching
      sdetweil @Coolie1101
      @coolie1101 ok, got it…
      I had one more fix…
      comment out line 101
      //					adjustHours = 24;
      Coolie1101C 1 Reply Last reply Reply Quote 0
      • Coolie1101C Offline
        Coolie1101 @sdetweil
        @sdetweil Genius!, that did it, do I still need to leave the other 4 lines commented out?
          @coolie1101 yes
          you can remove the ,“DEBUG” from the logLevel entry in config.js
          no point generating all the debug every cal refresh cycle
            @sdetweil Did, thanks.
            I hope @flyedge was able t get his sorted, and sorry for hijacking the post, hopefully it helps someone else.
            • F Offline
              flyedge
              Sorry to bring up an old thread, but I ended up getting to busy to finish dealing with that issue back when I started the thread. I think I ended up just creating an individual event for each item on the calendar if memory serves.
              I have run into the issue again though. I went through the responses of the person with the same issue, and was about to try and add in those same fixes however it appears that they are part of the main program now.
              I pulled the ICS file, and the debug file from the event and will attach them here, but from my very basic understanding, it almost appears that it is changing the time zone on the recurring event even when that isn’t appropriate, I am assuming that is where the issue is arising from.
              ics:
              BEGIN:VEVENT
              DTSTART;TZID=America/Edmonton:20220510T190000
              DTEND;TZID=America/Edmonton:20220510T210000
              RRULE:FREQ=WEEKLY;UNTIL=20220713T055959Z
              DTSTAMP:20220504T175603Z
              UID:E273826A-0F74-4F0D-BA17-A59824B3D8AC
              CREATED:20220216T184435Z
              DESCRIPTION:
              LAST-MODIFIED:20220216T184435Z
              SEQUENCE:0
              STATUS:CONFIRMED
              SUMMARY:Class
              TRANSP:OPAQUE
              END:VEVENT
              Debug:
              {"type":"VEVENT","params":[],"start":"2022-05-11T01:00:00.000Z","datetype":"date-time","end":"2022-05-11T03:00:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"tzid":"America/Edmonton","dtstart":"2022-05-11T01:00:00.000Z","freq":2,"until":"2022-07-13T05:59:59.000Z"},"options":{"freq":2,"dtstart":"2022-05-11T01:00:00.000Z","interval":1,"wkst":0,"count":null,"until":"2022-07-13T05:59:59.000Z","tzid":"America/Edmonton","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[2],"bynweekday":null,"byhour":[1],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2022-05-01T23:21:41.000Z","uid":"E273826A-0F74-4F0D-BA17-A59824B3D8AC","created":"2022-02-16T18:44:35.000Z","description":"","lastmodified":"2022-02-16T18:44:35.000Z","location":"Canada","sequence":"0","status":"CONFIRMED","summary":"Class","transparency":"OPAQUE","method":"PUBLISH"}
              [01.05.2022 17:21.45.608] [DEBUG] start: Tue May 10 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.610] [DEBUG] end:: Tue May 10 2022 21:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.629] [DEBUG] duration: 7200000
              [01.05.2022 17:21.45.633] [DEBUG] title: Class
              [01.05.2022 17:21.45.637] [DEBUG] Search for recurring events between: Sun May 01 2022 17:21:45 GMT-0600 (Mountain Daylight Time) and Wed Jun 29 2022 23:59:59 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.654] [DEBUG] Title: Class, with dates: ["2022-05-11T01:00:00.000Z","2022-05-18T01:00:00.000Z","2022-05-25T01:00:00.000Z","2022-06-01T01:00:00.000Z","2022-06-08T01:00:00.000Z","2022-06-15T01:00:00.000Z","2022-06-22T01:00:00.000Z","2022-06-29T01:00:00.000Z"]
              [01.05.2022 17:21.45.656] [DEBUG] event.recurrences: undefined
              [01.05.2022 17:21.45.659] [DEBUG]  recurring date is Tue May 10 2022 19:00:00 GMT-0600 (Mountain Daylight Time) offset is 360
              [01.05.2022 17:21.45.663] [DEBUG]  recurring date is Tue May 10 2022 19:00:00 GMT-0600 (Mountain Daylight Time) offset is 6 Hour is 19
              [01.05.2022 17:21.45.665] [DEBUG] new recurring date2 is Wed May 11 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.666] [DEBUG] Corrected startDate: Wed May 11 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.666] [DEBUG] initial tz=America/Edmonton
              [01.05.2022 17:21.45.667] [DEBUG] corrected tz=America/Edmonton
              [01.05.2022 17:21.45.668] [DEBUG] start date/time=Tue May 10 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.669] [DEBUG] start offset=-360
              [01.05.2022 17:21.45.672] [DEBUG] start date/time w tz =Tue May 10 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.674] [DEBUG] event date=Wed May 11 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.675] [DEBUG] event offset=-360 hour=19 event date=Wed May 11 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.676] [DEBUG] adjustHours=0
              [01.05.2022 17:21.45.676] [DEBUG] duration: 7200000
              [01.05.2022 17:21.45.678] [DEBUG] saving event: false
              [01.05.2022 17:21.45.680] [DEBUG]  recurring date is Tue May 17 2022 19:00:00 GMT-0600 (Mountain Daylight Time) offset is 360
              [01.05.2022 17:21.45.681] [DEBUG]  recurring date is Tue May 17 2022 19:00:00 GMT-0600 (Mountain Daylight Time) offset is 6 Hour is 19
              [01.05.2022 17:21.45.683] [DEBUG] new recurring date2 is Wed May 18 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.684] [DEBUG] Corrected startDate: Wed May 18 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.685] [DEBUG] initial tz=America/Edmonton
              [01.05.2022 17:21.45.688] [DEBUG] corrected tz=America/Edmonton
              [01.05.2022 17:21.45.694] [DEBUG] start date/time=Tue May 10 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.696] [DEBUG] start offset=-360
              [01.05.2022 17:21.45.697] [DEBUG] start date/time w tz =Tue May 10 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.698] [DEBUG] event date=Wed May 18 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.699] [DEBUG] event offset=-360 hour=19 event date=Wed May 18 2022 19:00:00 GMT-0600 (Mountain Daylight Time)
              [01.05.2022 17:21.45.700] [DEBUG] adjustHours=0
              [01.05.2022 17:21.45.700] [DEBUG] duration: 7200000
              [01.05.2022 17:21.45.702] [DEBUG] saving event: false
                sdetweil @flyedge
                @flyedge great info, thank you…
                I see the issue, but don’t yet know why it is behaving this way (compared to previous releases) and don’t know how to fix it yet.
                luxon (which returns the dates matching a repeating rule RRULE) might have fixed their bad behavior…
                where they jammed the non UTC date onto the UTC time
                in this old case it would have been
                2022-02-5-10T01:00:00Z
                where I was correcting the mangled event date
                • 4 / 4
