    Google Calendar
    17 Posts 3 Posters 4.4k Views 3 Watching
    • L Offline
      louise @sdetweil
      No events showed up. npm start time is the same as it was. No I never saw the message, but I was wasn’t looking.
      With the US Holidays, that comes up. When I put in the google calendar info I get the npm run config:check which says the json can’t parse
        sdetweil @louise
        @louise show the messages,.,
        npm start >somefile.txt
        wait til no events
        ctrl-c
        then u can edit somefile.txt to look at the messages emitted by startup
        search for ‘fetcher’
          sdetweil @louise
          @louise
          and did you put the quotes around it as i mentioned before, and be careful, the default line has }
          way out at the end… don’t delete that…
          the npm run will tell you the line where it detect the problem, but the line that CAUSED the problem is usually the line before
          on your prior post of the config, I noticed a missing } as well as the quotes around the URL…
          see your prior post, which I edited
          • L Offline
            louise @sdetweil
            @sdetweil Yes, I made sure the quotes were there. Also, like I said I was VERY careful not to mess with anything outside the quotes.
            Not sure on the pm start >somefile.txt
            wait til no events
            ctrl-c
            is it pm start>somefile.txt in the terminal window?
              sdetweil @louise
              @louise yes, everything is in the terminal window
              all commands are in the terminal window
              again, copy paste the { to } of the calendar module config from the failing config.js and the error message from the cconfig:check
              (and junk up the actual url text so its not valid)
                MMRIZE
                Maybe it could be another reason;
                Confirm whether your calendar is public
                Unless you check this, your ical URL won’t be accessed. Try your URL in the browser. If it shows 404 error, this might be the reason.
                • L Offline
                  louise @MMRIZE
                  @mmrize Yes it is public. It does seem to work now.
