    Google Calendar
    17 Posts 3 Posters 5.1k Views 3 Watching
      sdetweil @louise
      @louise said in Google Calendar:
      I suppose I should of that of the privacy thing.
      i edited the cal url in both posts
        sdetweil @louise
        @louise also you were missing a close brace after the url definition, which needs quotes
        the config.js rules
        the thing to the left of : does not need quotes
        the thing to the RIGHT of : does NOT need quotes IF it is trye or false, or a number 10, 123.4567… or { or [
        otherwise if the thing to the right of contains letter (http://… fred, 124somefile) then it must be enclosed in quotes,
        single of double doesn’t matter, long as both ends are the same
        • L Offline
          louise @sdetweil
          @sdetweil pm2
          I copied the sample calendar module, it works. Then the ONLY thing I changed is the google link, didn’t touch any of the brackets or commas or quotations etc. Still didn’t work. Don’t get it, it worked yesterday.
          The weather current and forecast work as does the clock, just not the calendar.
          Yesterday, the clock and weather didn’t work but the calendar did. I copied from my calendar bak file in the config.js file and it doesn’t work.
            sdetweil @louise
            @louise what does “doesn’t” work mean
            cal shows no events?
            or MM shows black screen?
            also, still waiting for the messages from npm start time
            you should see something like this (your url of course)
             Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
            and
            Calendar-Fetcher: Broadcasting 10 events.
            • L Offline
              louise @sdetweil
              No events showed up. npm start time is the same as it was. No I never saw the message, but I was wasn’t looking.
              With the US Holidays, that comes up. When I put in the google calendar info I get the npm run config:check which says the json can’t parse
                sdetweil @louise
                @louise show the messages,.,
                npm start >somefile.txt
                wait til no events
                ctrl-c
                then u can edit somefile.txt to look at the messages emitted by startup
                search for ‘fetcher’
                  sdetweil @louise
                  @louise
                  and did you put the quotes around it as i mentioned before, and be careful, the default line has }
                  way out at the end… don’t delete that…
                  the npm run will tell you the line where it detect the problem, but the line that CAUSED the problem is usually the line before
                  on your prior post of the config, I noticed a missing } as well as the quotes around the URL…
                  see your prior post, which I edited
                  • L Offline
                    louise @sdetweil
                    @sdetweil Yes, I made sure the quotes were there. Also, like I said I was VERY careful not to mess with anything outside the quotes.
                    Not sure on the pm start >somefile.txt
                    wait til no events
                    ctrl-c
                    is it pm start>somefile.txt in the terminal window?
                      sdetweil @louise
                      @louise yes, everything is in the terminal window
                      all commands are in the terminal window
                      again, copy paste the { to } of the calendar module config from the failing config.js and the error message from the cconfig:check
                      (and junk up the actual url text so its not valid)
                        MMRIZE
                        Maybe it could be another reason;
                        Confirm whether your calendar is public
                        Unless you check this, your ical URL won’t be accessed. Try your URL in the browser. If it shows 404 error, this might be the reason.
                        • L Offline
                          louise @MMRIZE
                          @mmrize Yes it is public. It does seem to work now.
