    Google Calendar
    17 Posts 3 Posters 5.6k Views 3 Watching
    • L
      louise
      I had everything working til I put this in…what’s wrong?
      "https://calendar.google.com/calendar/ical/jan.christeuuooen58%40gmail.com/public/basic.ics
      • L
        louise @MMRIZE
        @mmrize Yes it is public. It does seem to work now.
          sdetweil @louise
          @louise could u show the config for the cal module
          also any messages where u start mm…
          L 1 Reply Last reply
          • L
            louise @sdetweil
            			header: "",
            						symbol: "calendar-check",
            						url: https://calendar.google.com/calendar/ical/jan.christtuuooen58%40gmail.com/public/basic.ics
            					} // <- this was missing
              sdetweil @louise
              @louise the actual url has to be in quotes
              you should never post something with personal info, that works… change some characters at least
              • L
                louise @sdetweil
                @sdetweil Thanks, I suppose I should of that of the privacy thing.
                S 3 Replies Last reply
                  sdetweil @louise
                  @louise and any messages from where u start mm?
                  npm start or pm2
                  if pm2 the pm2 logs --lines=50
                    sdetweil @louise
                    @louise said in Google Calendar:
                    i edited the cal url in both posts
                      sdetweil @louise
                      @louise also you were missing a close brace after the url definition, which needs quotes
                      the config.js rules
                      the thing to the left of : does not need quotes
                      the thing to the RIGHT of : does NOT need quotes IF it is trye or false, or a number 10, 123.4567… or { or [
                      otherwise if the thing to the right of contains letter (http://… fred, 124somefile) then it must be enclosed in quotes,
                      single of double doesn’t matter, long as both ends are the same
                      • L
                        louise @sdetweil
                        @sdetweil pm2
                        I copied the sample calendar module, it works. Then the ONLY thing I changed is the google link, didn’t touch any of the brackets or commas or quotations etc. Still didn’t work. Don’t get it, it worked yesterday.
                        The weather current and forecast work as does the clock, just not the calendar.
                        Yesterday, the clock and weather didn’t work but the calendar did. I copied from my calendar bak file in the config.js file and it doesn’t work.
                          sdetweil @louise
                          @louise what does “doesn’t” work mean
                          cal shows no events?
                          or MM shows black screen?
                          also, still waiting for the messages from npm start time
                          you should see something like this (your url of course)
                           Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                          and
                          Calendar-Fetcher: Broadcasting 10 events.
                          • L
                            louise @sdetweil
                            No events showed up. npm start time is the same as it was. No I never saw the message, but I was wasn’t looking.
                            With the US Holidays, that comes up. When I put in the google calendar info I get the npm run config:check which says the json can’t parse
                            S 2 Replies Last reply
                              sdetweil @louise
                              @louise show the messages,.,
                              npm start >somefile.txt
                              wait til no events
                              ctrl-c
                              then u can edit somefile.txt to look at the messages emitted by startup
                              search for ‘fetcher’
                                sdetweil @louise
                                @louise
                                and did you put the quotes around it as i mentioned before, and be careful, the default line has }
                                way out at the end… don’t delete that…
                                the npm run will tell you the line where it detect the problem, but the line that CAUSED the problem is usually the line before
                                on your prior post of the config, I noticed a missing } as well as the quotes around the URL…
                                see your prior post, which I edited
                                • L
                                  louise @sdetweil
                                  @sdetweil Yes, I made sure the quotes were there. Also, like I said I was VERY careful not to mess with anything outside the quotes.
                                  Not sure on the pm start >somefile.txt
                                  wait til no events
                                  ctrl-c
                                  is it pm start>somefile.txt in the terminal window?
                                    sdetweil @louise
                                    @louise yes, everything is in the terminal window
                                    all commands are in the terminal window
                                    again, copy paste the { to } of the calendar module config from the failing config.js and the error message from the cconfig:check
                                    (and junk up the actual url text so its not valid)
                                      MMRIZE
                                      Maybe it could be another reason;
                                      Confirm whether your calendar is public
                                      Unless you check this, your ical URL won’t be accessed. Try your URL in the browser. If it shows 404 error, this might be the reason.
                                      • L
                                        louise @MMRIZE
