    Clock format
    41 Posts 2 Posters 20.7k Views 2 Watching
      sdetweil @louise
      @louise said in Clock format:
      Would it be easier if I just started over?
      with what? ignore what is above
      • L Offline
        louise @sdetweil
        @sdetweil Just a new install of Magic Mirror, rename this as MagicMirror1 and do a new install.
          sdetweil @louise
          @louise no… u havent hurt anything… we can get back the changed files easy
          the design makes it so we can change the code whenever we need to (we own it) and your implementation is not impacted, and you also aren’t blocked from getting the quarterly updates (next one coming Jan 1) …
          if you think it would be easier for you, then sure ,rename the folder, use my script to install again
          and then migrate your source file changes to config.js
          but u can migrate the changes now, no harm …
          • L Offline
            louise @sdetweil
            deleted
              sdetweil @louise
              module: “clock”,
              position: “top_left”
              still didnt’ get the select all
              and this is the only part we needed
              module: “clock”,
              it has no config:{} section, so all the module defaults are used
              to change some setting here do
              module: “clock”,
              position: “top_left”,     // <-  add a comma (more stuff follows this line)
              config : {
                   timeFormat:24,
              in the setting above clock will use 24 hour format, even if the base is set to 12 hour format
              • L Offline
                louise @sdetweil
                @sdetweil Given a choice I would rather just have this figured out. Did I do right this time?
                  sdetweil @louise
                  @louise no
                  • L Offline
                    louise @sdetweil
                    @sdetweil frustrated yet?
                    It is my config.js
                    I know it says sample on top but it didn’t mess with any of that. I added in the disabled the compliment and newsfeed like u said so that worked.
                    I don’t understand apparently.
                      sdetweil @louise
                      @louise here
                      https://forum.magicmirror.builders/topic/15954/clock-format/18?_=1638300432581
                      the part of config.js is right, but the code block is wrong… and its doubled for some reason
                      when we ask for a module config, we don’t want the WHOLE config.js…
                      (also, there are private things in there, api keys, maybe passwords, … )
                      so we want as small as possible focused on A module usually
                      • L Offline
                        louise @sdetweil
                        @sdetweil So you are saying I should I this under the the area it says clock module?
                        config : {
                        timeFormat:24,
                        • 3 / 5
