    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 57.6k Views 4 Watching
      sdetweil @pastormingle
      @pastormingle I would open another topic here on calendarext not showing as this topic says carousel
      • P Offline
        pastormingle @sdetweil
        @sdetweil Thanks Sam… It seems to be an issue with mmm-google task and the order you call the calendarext from mmm-carousel. It needs to be first on the list if you are using a slide mode on the carousel… Not sure yet why the mmm-googletask is causing it to fail… Thanks for all the help Sam… I’m adding this just in case someone else comes along with the same issue…
          @pastormingle just for clarity
          "It needs to be first on the list "
          which module needs to be 1st? (it)
          • P Offline
            @sdetweil the “MMM-CalendarExt” needs to be first…
            • P Offline
              pastormingle
              I am still having issues with my weather app using it with carousel. When it rotates back to weather I only get a thumbnail of the radar… Do you know of any fix to that?
                @pastormingle what weather module?
                I do not know the answer. don’t use carousel
                • 6
                • 7
                • 8
                • 9
                • 10
                • 10 / 10
