    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 73.1k Views 4 Watching
      pastormingle @sdetweil
      @sdetweil npm ERR! missing script: start
      npm ERR! /home/pi/.npm/_logs/2021-12-14T23_05_21_577Z-debug.log
      P 1 Reply Last reply
        pastormingle @pastormingle
        @pastormingle ```
        magicmirror@2.16.0 start /home/pi/MagicMirror
        ./run-start.sh $1
        [14.12.2021 17:06.53.311] [LOG] Starting MagicMirror: v2.16.0
        [14.12.2021 17:06.53.315] [LOG] Loading config …
        [14.12.2021 17:06.53.322] [LOG] Loading module helpers …
        [14.12.2021 17:06.53.324] [LOG] No helper found for module: alert.
        [14.12.2021 17:06.54.616] [LOG] Initializing new module helper …
        [14.12.2021 17:06.54.618] [LOG] Module helper loaded: MMM-GoogleTasks
        [14.12.2021 17:06.54.753] [LOG] Initializing new module helper …
        [14.12.2021 17:06.54.753] [LOG] Module helper loaded: updatenotification
        [14.12.2021 17:06.54.754] [LOG] No helper found for module: weather.
        [14.12.2021 17:06.54.755] [LOG] No helper found for module: clock.
        [14.12.2021 17:06.54.756] [LOG] No helper found for module: MMM-Carousel.
        [14.12.2021 17:06.54.756] [LOG] No helper found for module: MMM-RAIN-MAP.
        [14.12.2021 17:06.55.135] [LOG] Initializing new module helper …
        [14.12.2021 17:06.55.136] [LOG] Module helper loaded: MMM-PaprikaMenu
        [14.12.2021 17:06.55.236] [LOG] Initializing new module helper …
        [14.12.2021 17:06.55.237] [LOG] Module helper loaded: calendar
        [14.12.2021 17:06.55.238] [LOG] No helper found for module: calendar_monthly.
        [14.12.2021 17:06.55.238] [LOG] No helper found for module: helloworld.
        [14.12.2021 17:06.55.577] [LOG] Initializing new module helper …
        [14.12.2021 17:06.55.577] [LOG] Module helper loaded: MMM-CalendarExt
        [14.12.2021 17:06.55.580] [LOG] Initializing new module helper …
        [14.12.2021 17:06.55.581] [LOG] Module helper loaded: MMM-ip
        [14.12.2021 17:06.55.581] [LOG] All module helpers loaded.
        [14.12.2021 17:06.55.694] [LOG] Starting server on port 8080 …
        [14.12.2021 17:06.55.708] [LOG] Server started …
        [14.12.2021 17:06.55.709] [LOG] Connecting socket for: MMM-GoogleTasks
        [14.12.2021 17:06.55.710] [LOG] Starting node helper for: MMM-GoogleTasks
        [14.12.2021 17:06.55.710] [LOG] Connecting socket for: updatenotification
        [14.12.2021 17:06.55.711] [LOG] Connecting socket for: MMM-PaprikaMenu
        [14.12.2021 17:06.55.712] [LOG] Starting node_helper for module [MMM-PaprikaMenu]
        [14.12.2021 17:06.55.712] [LOG] Connecting socket for: calendar
        [14.12.2021 17:06.55.713] [LOG] Starting node helper for: calendar
        [14.12.2021 17:06.55.713] [LOG] Connecting socket for: MMM-CalendarExt
        [14.12.2021 17:06.55.714] [LOG] Connecting socket for: MMM-ip
        [14.12.2021 17:06.55.715] [LOG] Starting module helper: MMM-ip
        [14.12.2021 17:06.55.715] [LOG] Available network interface types: lo, wlan0
        [14.12.2021 17:06.55.716] [LOG] Sockets connected & modules started …
        [14.12.2021 17:06.55.995] [LOG] Launching application.
        [14.12.2021 17:06.58.663] [LOG] Create new calendarfetcher for url: http://outlook.office365.com/owa/calendar/f2033a09d654825a9290ce3ec9657585490405428856/calendar.ics - Interval: 50000
        [14.12.2021 17:06.58.696] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/pastormike%40htni.org/private-34995d14cf5e15efc8bd68f680c508e3/basic.ics - Interval: 50000
        [14.12.2021 17:06.58.766] [LOG] TASKS SERVICE ALREADY RUNNING, DONT NEED TO AUTHENTICATE AGAIN
        [14.12.2021 17:06.58.884] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/pastorcharlotte%40htni.org/private-448bd900cdd3f7155/basic.ics - Interval: 50000
        [14.12.2021 17:06.59.198] [INFO] Calendar-Fetcher: Broadcasting 6 events.
        [14.12.2021 17:06.59.540] [INFO] Calendar-Fetcher: Broadcasting 2 events.
        [14.12.2021 17:06.59.674] [LOG] MMM-PaprikaMenu: Week starts: 2021-12-13, next week starts: 2021-12-20
        [14.12.2021 17:06.59.696] [LOG] MMM-PaprikaMenu: Waiting on 0 Paprika recipe calls.
        [14.12.2021 17:06.59.697] [LOG] MMM-PaprikaMenu: All recipe queries returned.
        [14.12.2021 17:07.02.676] [LOG] Shutting down server…
        [14.12.2021 17:07.02.678] [LOG] Stopping module helper: MMM-GoogleTasks
        [14.12.2021 17:07.02.679] [LOG] Stopping module helper: updatenotification
        [14.12.2021 17:07.02.680] [LOG] Stopping module helper: MMM-PaprikaMenu
        [14.12.2021 17:07.02.682] [LOG] Stopping module helper: calendar
        [14.12.2021 17:07.02.683] [LOG] Stopping module helper: MMM-CalendarExt
        [14.12.2021 17:07.02.684] [LOG] Stopping module helper: MMM-ip
          @pastormingle no errors but still not displaying the calendar…
            sdetweil @pastormingle
            @pastormingle is the screen black?
            no. then the fix from before is ok.
            I don’t know anything about that module itself
              @sdetweil no it’s not blacked out it is displaying the other module like the clock but nothing on the calendar…
                @pastormingle I would open another topic here on calendarext not showing as this topic says carousel
                  @sdetweil Thanks Sam… It seems to be an issue with mmm-google task and the order you call the calendarext from mmm-carousel. It needs to be first on the list if you are using a slide mode on the carousel… Not sure yet why the mmm-googletask is causing it to fail… Thanks for all the help Sam… I’m adding this just in case someone else comes along with the same issue…
                    @pastormingle just for clarity
                    "It needs to be first on the list "
                    which module needs to be 1st? (it)
                      @sdetweil the “MMM-CalendarExt” needs to be first…
                        pastormingle
                        I am still having issues with my weather app using it with carousel. When it rotates back to weather I only get a thumbnail of the radar… Do you know of any fix to that?
                          @pastormingle what weather module?
                          I do not know the answer. don’t use carousel
                          • 5 / 5
