    MMM-CalendarExt - Black Screen
    4 Posts 2 Posters 886 Views 2 Watching
    • P Offline
      popashack
      I am a newbie so here goes
      I took the standard parameters and utilizing one calendar I get no errors but a black screen. I am utilizing wallpaper and some other things. What am I missing?
      The config.js is below.
      Thanks.
      			module: 'MMM-CalendarExt',
      			position: "bottom_left", //anywhere. It is not related to real position of view
      			config: { // Read below
      			  system: {
      				show: ['daily'],
      				locale: 'nl-NL',
      				fullDayEventLocalize: 1,
      				redrawInterval: 60000, //minimum 60000
      			  defaultView: {
      			  dateFormat: "D MMM",
      			  fullDayEventDateFormat: "D MMM",
      			  oneLineEvent:0,
      			  overflowRolling: 1,
      			  overflowHeight: 400,
      			  overflowDuration: 5,
      			  weekdayFormat: 'dddd',
      				url: "https://calendar.google.com/calendar/ical/abc...gmail.com/public/basic.ics"
      S P 2 Replies Last reply Reply Quote 0
        sdetweil @popashack
        @popashack see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
        • P Offline
          popashack @popashack
          @popashack
          Sam,
          Blacks screens are still occurring.
          Can you share a minimum setup for MMM-CalendarExt or MMM-CalendarExt2 that works, even with a default ical? This is really all I am trying to do is put all my todos and calendars in front of me. I decided to try with Google and todoist. Both work, but I really need to see a week at a time and this still black screens with no error with the script above.
          I plan to add outlook and google task later, but both seem like more of a challenge.
          Thanks.
          Carl
            sdetweil @popashack
            @popashack if u get black screen you must check and redo the commands for each module
            start by disabling the modules u added
            add
            disabled: true
            after the
            module:
            line in config .J’s
            verify no black screen
            enable one module
            disabled: false
            test.
            if black screen fix
            then repeat
