    MMM-GooglePhotos - Reaching quota but don't know why
    8 Posts 3 Posters 1.2k Views 2 Watching
      bhaules
      I had this configuration for more than a year and recently re-installed Magic Mirror and all the modules.
      This is my GooglePhotos config:
       226           module: "MMM-GooglePhotos",
       227           position: "fullscreen_below",
       228           config: {
       229                 albums: ["FamilyPhotos"], // Set your album name. like ["My wedding", "family share", "Travle to Paris"]
       230                 updateInterval: 1000 * 60 *2, // minimum 10 seconds.
       231                 scanInterval:1000*60*10
       232                 sort: "random", // "old", "random"
       233                 uploadAlbum: null, // Only album created by `create_uploadable_album.js`.
       234                 condition: {
       235                     fromDate: null, // Or "2018-03", RFC ... format available
       236                     toDate: null, // Or "2019-12-25",
       237                     minWidth: null, // Or 400
       238                     maxWidth: null, // Or 8000
       239                     minHeight: null, // Or 400
       240                     maxHeight: null, // Or 8000
       241                     minWHRatio: null,
       242                     maxWHRatio: null,
       243                     // WHRatio = Width/Height ratio ( ==1 : Squared Photo,   < 1 : Portraited Photo, > 1 : Landscaped Photo)
       244                 },
       245                 showWidth: 1080, // These values will be used for quality of downloaded photos to show. real size to show in your MagicMirror region is recommended.
       246                 showHeight: 1920,
       247                 timeFormat: "DD MMM YYYY HH:mm", // Or `relative` can be used.
       248               debug: true,
       249               }
       250         },
      When I go to the MagicMirror-out.log I get:
       267546 [19.12.2021 10:58.04.127] [LOG]   [GPHOTOS] Getting album list
       267547 [19.12.2021 10:58.04.137] [LOG]   [GPHOTOS:AUTH] Token is alive.
       267548 [19.12.2021 10:58.04.143] [LOG]   [GPHOTOS:CORE] Getting Album info chunks.
       267549 [19.12.2021 10:58.04.807] [LOG]   [GPHOTOS:CORE] Error: Request failed with status code 429
       267550 [19.12.2021 10:59.04.127] [LOG]   [GPHOTOS] Starting Initialization
       267551 [19.12.2021 10:59.04.134] [LOG]   [GPHOTOS] Getting album list
       267552 [19.12.2021 10:59.04.143] [LOG]   [GPHOTOS:AUTH] Token is alive.
       267553 [19.12.2021 10:59.04.146] [LOG]   [GPHOTOS:CORE] Getting Album info chunks.
       267554 [19.12.2021 10:59.05.781] [LOG]   [GPHOTOS:CORE] Error: Request failed with status code 429
      When I go to MagicMirror-error.log I get:
       212039 [19.12.2021 10:59.05.786] [ERROR] (node:25894) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To         terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 6)
       212040 [19.12.2021 11:00.05.787] [ERROR] (node:25894) UnhandledPromiseRejectionWarning: Error: Request failed with status code 429
       212041     at createError (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/createError.js:16:15)
       212042     at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/settle.js:17:12)
       212043     at IncomingMessage.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/adapters/http.js:236:11)
       212044     at IncomingMessage.emit (events.js:327:22)
       212045     at endReadableNT (internal/streams/readable.js:1327:12)
       212046     at processTicksAndRejections (internal/process/task_queues.js:80:21)
      What I found about this error was this page from the forum: https://forum.magicmirror.builders/topic/14871/mmm-googlephotos-unhandled-promise-rejection/8 but I can’t seem to figure out how am I getting too may requests as I should be below that number with a request every 5 minutes.
      In the evenings though the Google Photos module seems to start working. Last night it worked from about 8PM to about 2AM:
      263628 [19.12.2021 02:01.29.956] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4230
       263629 [19.12.2021 02:01.31.057] [LOG]   en
       263630 [19.12.2021 02:01.31.937] [LOG]   NOAA3 weather updated.. next update in 1 hour
       263631 [19.12.2021 02:01.33.091] [LOG]   en
       263632 [19.12.2021 02:01.33.590] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4270
       263633 [19.12.2021 02:01.34.612] [LOG]   NOAA3 weather updated.. next update in 1 hour
       263634 [19.12.2021 02:01.35.775] [LOG]   en
       263635 [19.12.2021 02:01.36.816] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4319
       263636 [19.12.2021 02:01.37.552] [LOG]   NOAA3 weather updated.. next update in 1 hour
       263637 [19.12.2021 02:01.38.690] [LOG]   en
       263638 [19.12.2021 02:01.40.010] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4369
       263639 [19.12.2021 02:01.40.261] [LOG]   NOAA3 weather updated.. next update in 1 hour
       263640 [19.12.2021 02:01.41.418] [LOG]   en
       263641 [19.12.2021 02:01.42.818] [LOG]   NOAA3 weather updated.. next update in 1 hour
       263642 [19.12.2021 02:01.43.235] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4419
       263643 [19.12.2021 02:01.44.146] [LOG]   en
       263644 [19.12.2021 02:01.45.877] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4468
       263645 [19.12.2021 02:01.45.912] [LOG]   NOAA3 weather updated.. next update in 1 hour
       263646 [19.12.2021 02:01.47.045] [LOG]   en
       263647 [19.12.2021 02:01.48.018] [LOG]   Notification: GET_SOLAR Payload: [object Object]
       263648 [19.12.2021 02:01.48.421] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4518
       263649 [19.12.2021 02:01.48.595] [LOG]   NOAA3 weather updated.. next update in 1 hour
       263650 [19.12.2021 02:01.50.022] [LOG]   en
       263651 [19.12.2021 02:01.50.694] [LOG]   starting network connection testing
       263652 [19.12.2021 02:01.51.086] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4568
       263653 [19.12.2021 02:01.52.585] [LOG]   [GPHOTOS] Start Album scanning
       263654 [19.12.2021 02:01.52.596] [LOG]   [GPHOTOS] Prepping to get photo list from 'FamilyPhotos'
       263655 [19.12.2021 02:01.52.602] [LOG]   [GPHOTOS:AUTH] Token is alive.
       263656 [19.12.2021 02:01.52.605] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  0
       263657 [19.12.2021 02:01.54.347] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4615
       263658 [19.12.2021 02:01.54.845] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  45
       263659 [19.12.2021 02:01.56.918] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4659
       263660 [19.12.2021 02:01.58.438] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  91
       263661 [19.12.2021 02:01.59.317] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4702
       263662 [19.12.2021 02:02.01.182] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  140
       263663 [19.12.2021 02:02.01.943] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4749
       263664 [19.12.2021 02:02.03.825] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  187
       263665 [19.12.2021 02:02.05.659] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4798
       263666 [19.12.2021 02:02.06.479] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  234
       263667 [19.12.2021 02:02.09.398] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4847
       263668 [19.12.2021 02:02.09.927] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  276
       263669 [19.12.2021 02:02.11.982] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4897
       263670 [19.12.2021 02:02.13.361] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  325
       263671 [19.12.2021 02:02.15.614] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4946
       263672 [19.12.2021 02:02.17.021] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  375
       263673 [19.12.2021 02:02.19.028] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  4995
       263674 [19.12.2021 02:02.20.643] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  420
       263675 [19.12.2021 02:02.21.314] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  5044
       263676 [19.12.2021 02:02.22.998] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  468
       263677 [19.12.2021 02:02.23.433] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  5094
       263678 [19.12.2021 02:02.26.387] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  515
       263679 [19.12.2021 02:02.26.760] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  5143
       263680 [19.12.2021 02:02.32.390] [INFO]  Calendar-Fetcher: Broadcasting 15 events.
       263681 [19.12.2021 02:02.32.949] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  5191
       263682 [19.12.2021 02:02.32.978] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  559
       263683 [19.12.2021 02:02.36.310] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  607
       263684 [19.12.2021 02:02.36.335] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  5240
       263685 [19.12.2021 02:02.39.673] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  5289
       263686 [19.12.2021 02:02.39.770] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  651
       263687 [19.12.2021 02:02.41.940] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  5338
       263688 [19.12.2021 02:02.42.876] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  696
       263689 [19.12.2021 02:02.45.429] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  5388
       263690 [19.12.2021 02:02.46.248] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  734
       263691 [19.12.2021 02:02.48.599] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  778
       263692 [19.12.2021 02:02.49.679] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  5438
       263693 [19.12.2021 02:02.50.705] [LOG]   [GPHOTOS:CORE] Error: Request failed with status code 429
       263694 [19.12.2021 02:02.52.221] [LOG]   [GPHOTOS:CORE] Indexing photos now. total:  5488
       263695 [19.12.2021 02:02.53.756] [LOG]   [GPHOTOS:CORE] Error: Request failed with status code 429
       263696 [19.12.2021 02:04.05.930] [LOG]   [GPHOTOS] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AFBm1_b84YissZJVOjwjMwQ-ztj7i-L_kjglXaMKSLMzhSWx5pqfSI_BDFFNToYwrOzJAQqcUPworEBaXfJVagYWNppK9g-0giQ_3iHKwGWnaT9CDBLUfAQP9gBRnTYouHAP-                    gI053J7hFAuWRv1y072K_dEL9K7Kipr5Inm5OoTnR4gPG6_Nq1y6hBoCFrAjJTOnsrdYlLJixbIm4bKgzdrGzQSxzt3zUolBG-1VBbhzurYmrY9AIt7o_NqPn8bdQZTpXVF7-D9MWT91yq7sH0yzkFmxqOz3qeaMr_VYnfs4eSaQOuDQQw80ZggI4KZlkxeCr8fTSVoCQ5oZaZwsirn6cFsAlFNkX1B8-mCm7TYnWYlJbEzeKkfMxqKVlBdERpmc-                   jXAl3Ip8FgrNGrgebzUnfzglYUkyWvWjZAnwVqCDzKCEVVHjAy1zxd94TiqV37uXmP8C3Sp-f4_lvCVkDSuk-X8NzosEKcStZRMJl0mxP75UnVfHHhlCql8AXncwmVstX5y2ftlqRuj499_LFKx6b_2Kkz-xC4OOJoUvy-        jSPVp1UiH0hMMLhhTwwi1X89jwCInvK9HwHHF3jE7lUs9NgmTcC0ffheLS0fYNcZ7OxLlV15SIPH60XdNYNM2OfWBajJtbFeDuMQmTx6WUx1QADfpa81DoAffv8jj7PRJ6U2Fv_scoNcN08IgbKt_DJjgVk67b69BtHJciymhmkSx8EWzeUFBMFwe3D0k6vcbnOssDMw96XTVZU5SGQKewYNIh7zOm_TD8EvI-PuWKwVDgOiESMuVynxNIRvlgggwSdu5HlSnq9-        HTQgwQOHx_v-N0ca99ULapd6=w1080-h1920
       263697 [19.12.2021 02:04.05.931] [LOG]   [GPHOTOS] num to ref:  8 , DesChunk:  8 , totalLength:  6228 , Pntr:  343
       263698 [19.12.2021 02:04.05.933] [LOG]   [GPHOTOS:AUTH] Token is alive.
      Looking at the logs what I found curious was that it seems that there are multiple streams of indexing happeing in paralel:
      I also went in my google api account and clicked around and found that I was going over my quota every day and probably my quota was reset at in the evening and fill it up by morning.
      Can anyone give me an idea why I’m going over my quota and how can I troubleshoot this?
        sdetweil @bhaules
        @bhaules do you have multiple mirrors running, or multiple browsers connected to mm?
          bhaules @sdetweil
          @sdetweil That was my thought as well.
          I initially tried re-installing MagicMirror using the official manual steps, configured PM2 and I couldn’t get it to work. I then used your script and that worked wonders :) Thank you for that.
          pi@MagicMirror2:~ $ pm2 start all
          [PM2] Applying action restartProcessId on app [all](ids: [ 0 ])
          [PM2] [MagicMirror](0) ✓
          [PM2] Process successfully started
          │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
          │ 0   │ MagicMirror    │ default     │ 2.17.1  │ fork    │ 2440     │ 0s     │ 1    │ online    │ 0%       │ 2.6mb    │ pi       │ disabled │
          I don’t have anything in crontab
          Where else can I check to see if there’s another instance running?
            sdetweil @bhaules
            @bhaules I meant from another machine, windows PC looking at the mm web page
              bhaules @sdetweil
              @sdetweil Not as far as I’m aware.
              My current setup is a rpi connected to a tv and that’s it.
              Is there a way to check to see if there are other external connections?
                sdetweil @bhaules
                @bhaules not that I am aware of
                what is the address: setting in config.js?
                if ,“localhost” then only apps inside the same machine can connect
                  bhaules @sdetweil
                  @sdetweil I really appreciate you giving your time to help me:
                  I have whitelisted in the past my local network ips to be able to connect to the MM instance (for troubleshooting). Not using it any more in any other browsers.
                   10 let config = {
                    11     address: "localhost",   // Address to listen on, can be:
                    12                             // - "localhost", "127.0.0.1", "::1" to listen on loopback interface
                    13                             // - another specific IPv4/6 to listen on a specific interface
                    14                             // - "0.0.0.0", "::" to listen on any interface
                    15                             // Default, when address config is left out or empty, is "localhost"
                    16     port: 8080,
                    17     basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                    18                     // you must set the sub path here. basePath must end with a /
                    19     ipWhitelist: ["::ff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1","10.1.1.142","::ffff:10.1.1.1/112","10.1.1.89",       "10.1.1.215"],
                    20     //ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],    // Set [] to allow all IP addresses
                    21                                                             // or add a specific IPv4 of 192.168.1.5 :
                    22                                                             // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"],
                    23                                                             // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format :
                    24                                                             // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"],
                    25
                    26     useHttps: false,        // Support HTTPS or not, default "false" will use HTTP
                    27     httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                    28     httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                    29
                    30     language: "en",
                    31     locale: "en-US",
                    32     logLevel: ["INFO", "LOG", "WARN", "ERROR"], // Add "DEBUG" for even more logging
                    33     timeFormat: 24,
                    34     units: "metric",
                    35     // serverOnly:  true/false/"local" ,
                    36     // local for armv6l processors, default
                    37     //   starts serveronly and then starts chrome browser
                    38     // false, default for all NON-armv6l devices
                    39     // true, force serveronly mode, because you want to.. no UI on this device
                  What I find curious is that it almost looks like there are 2 streams of indexing running in the same time:
                  other than looking at the PM2 not sure where else to look at to see if there is another instance running.
                  Although I haven’t changed the configuration, I have recently re-installed everything so I’m thinking it’s related to the re-install rather than the config:
                    MMRIZE @bhaules
                    @bhaules
                    Just memo;
                    It seems Indexing 50 photos took around 3~4 seconds. (It is too slower than I expect) 5000 photos will take 3000~4000 sec, = around 50 ~ 60minutes.
                    But your scanInterval is 10 minutes. It might be the reason? Before finishing the previous scanning cycle, a new cycle might begin.
                    As I mentioned earlier on github, scanning 5thousands photos every 10 minutes to show random 5 pictures in that 10 minutes, seems not so much efficient.
