    Magic mirror not starting
    19 Posts 3 Posters 4.3k Views 3 Watching
    • Z Offline
      zolabus @sdetweil
      @sdetweil same problem…
        sdetweil @zolabus
        @zolabus
         /home/pi/MagicMirror/node_modules/ical
        this folder does not exist in the latest release
        and if u deleted the node_modules folder (per the prior instructions) it should not exist on your system either
        do
        grep version ~/MagicMirror/package.json
        karsten13K Z 2 Replies Last reply Reply Quote 0
        • karsten13K Offline
          karsten13 @sdetweil
          @sdetweil may he should delete package-lock.json too
          S Z 2 Replies Last reply Reply Quote 0
            sdetweil @karsten13
            @karsten13 true…
            • Z Offline
              zolabus @sdetweil
              @sdetweil said in Magic mirror not starting:
              “version”: “2.17.1”,
              • Z Offline
                zolabus @karsten13
                @karsten13 done…
                My log now is
                pi@magicmirror:~/MagicMirror $ npm start
                magicmirror@2.17.1 start /home/pi/MagicMirror
                DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                Fontconfig warning: “/etc/fonts/fonts.conf”, line 100: unknown element “blank”
                [03.01.2022 09:56.26.101] [LOG] Starting MagicMirror: v2.17.1
                [03.01.2022 09:56.26.130] [LOG] Loading config …
                [03.01.2022 09:56.26.156] [LOG] Loading module helpers …
                [03.01.2022 09:56.26.166] [LOG] No helper found for module: alert.
                [03.01.2022 09:56.26.238] [LOG] Initializing new module helper …
                [03.01.2022 09:56.26.243] [LOG] Module helper loaded: updatenotification
                [03.01.2022 09:56.26.246] [LOG] No helper found for module: clock.
                [03.01.2022 09:56.27.074] [LOG] Initializing new module helper …
                [03.01.2022 09:56.27.078] [LOG] Module helper loaded: calendar
                [03.01.2022 09:56.28.016] [LOG] Initializing new module helper …
                [03.01.2022 09:56.28.020] [LOG] Module helper loaded: MMM-GooglePhotos
                [03.01.2022 09:56.29.319] [LOG] Initializing new module helper …
                [03.01.2022 09:56.29.323] [LOG] Module helper loaded: MMM-DarkSkyForecast
                [03.01.2022 09:56.29.407] [LOG] Initializing new module helper …
                [03.01.2022 09:56.29.409] [LOG] Module helper loaded: newsfeed
                [03.01.2022 09:56.29.412] [LOG] No helper found for module: compliments.
                [03.01.2022 09:56.29.427] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
                Require stack:
                • /home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js
                • /home/pi/MagicMirror/js/app.js
                • /home/pi/MagicMirror/js/electron.js
                • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/mai n.js
                [03.01.2022 09:56.29.432] [LOG] Loading module helpers …
                [03.01.2022 09:56.29.439] [LOG] No helper found for module: alert.
                [03.01.2022 09:56.29.442] [LOG] Initializing new module helper …
                [03.01.2022 09:56.29.444] [LOG] Module helper loaded: updatenotification
                [03.01.2022 09:56.29.447] [LOG] No helper found for module: clock.
                [03.01.2022 09:56.29.450] [LOG] Initializing new module helper …
                [03.01.2022 09:56.29.454] [LOG] Module helper loaded: calendar
                [03.01.2022 09:56.29.459] [LOG] Initializing new module helper …
                [03.01.2022 09:56.29.462] [LOG] Module helper loaded: MMM-GooglePhotos
                [03.01.2022 09:56.29.467] [LOG] Initializing new module helper …
                [03.01.2022 09:56.29.470] [LOG] Module helper loaded: MMM-DarkSkyForecast
                [03.01.2022 09:56.29.473] [LOG] Initializing new module helper …
                [03.01.2022 09:56.29.475] [LOG] Module helper loaded: newsfeed
                [03.01.2022 09:56.29.478] [LOG] No helper found for module: compliments.
                [03.01.2022 09:56.29.487] [ERROR] App threw an error during load
                [03.01.2022 09:56.29.497] [ERROR] Error: Cannot find module ‘request’
                Require stack:
                • at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
                  at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/modul e-alias/index.js:49:29)
                  at Module._load (internal/modules/cjs/loader.js:732:27)
                  at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
                  at Module.require (internal/modules/cjs/loader.js:959:19)
                  at require (internal/modules/cjs/helpers.js:88:18)
                  at Object. (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node _helper.js:11:15)
                  at Module._compile (internal/modules/cjs/loader.js:1078:30)
                  at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10)
                  [03.01.2022 09:56.29.503] [ERROR] Whoops! There was an uncaught exception…
                  [03.01.2022 09:56.29.526] [ERROR] Error: Cannot find module ‘request’
                  Require stack:
                  at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10) {
                  code: ‘MODULE_NOT_FOUND’,
                  requireStack: [
                  ‘/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js’,
                  ‘/home/pi/MagicMirror/js/app.js’,
                  ‘/home/pi/MagicMirror/js/electron.js’,
                  ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/ main.js’,
                  undefined
                  [03.01.2022 09:56.29.545] [ERROR] MagicMirror will not quit, but it might be a g ood idea to check why this happened. Maybe no internet connection?
                  [03.01.2022 09:56.29.548] [ERROR] If you think this really is an issue, please o pen an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [03.01.2022 09:56.30.426] [LOG] Launching application.
                • Z Offline
                  zolabus
                  I saved all the modules I had installed…
                  What else for a backup?
                  What about a clean reinstallation?
                  How can I delete everything? It’s enough if I delete the MagicMirror folder?
                  Z 1 Reply Last reply Reply Quote 0
                    sdetweil @zolabus
                    @zolabus said in Magic mirror not starting:
                    see
                    • Z Offline
                      zolabus @zolabus
                      @zolabus Hi all after all I found a couple of modules causing the issue…
                      I started from a standard config file and added the modules one by one.
                      Now I have my magic mirror back
