    Magic mirror not starting
    19 Posts 3 Posters 5.5k Views 3 Watching
    • Z Offline
      zolabus
      Hi all,
      it’s some days that my magic mirror seems not to start.
      The OS starts correctly but when mm should start I can see only a white flash and nothing else…
      I can access via ssh.
      Any idea?
      • Z Offline
        zolabus @zolabus
        @zolabus Hi all after all I found a couple of modules causing the issue…
        I started from a standard config file and added the modules one by one.
        Now I have my magic mirror back
          sdetweil @zolabus
          @zolabus need to see the messages from start
          Z 1 Reply Last reply Reply Quote 0
          • Z Offline
            zolabus @sdetweil
            @sdetweil I do not have any messages…only a white flash then blank monitor
              sdetweil @zolabus
              @zolabus on the pi you issue
              npm start
              or pm2 start MagicMirror
              that is where u look for messages,
              not on the mirror screen
              you should see stuff like
              ~/MagicMirror$ npm start
              > magicmirror@2.17.1 start /home/pi/MagicMirror
              [30.12.2021 17:00.28.545] [LOG]   Starting MagicMirror: v2.17.1
              [30.12.2021 17:00.28.546] [LOG]   Loading config ...
              [30.12.2021 17:00.28.547] [LOG]   Loading module helpers ...
              [30.12.2021 17:00.28.547] [LOG]   trying to load module=alert
              [30.12.2021 17:00.28.547] [LOG]   No helper found for module: alert.
              [30.12.2021 17:00.28.548] [LOG]   trying to load module=clock
              [30.12.2021 17:00.28.548] [LOG]   No helper found for module: clock.
              [30.12.2021 17:00.28.548] [LOG]   trying to load module=calendar
              [30.12.2021 17:00.28.574] [LOG]   Initializing new module helper ...
              [30.12.2021 17:00.28.574] [LOG]   Module helper loaded: calendar
              [30.12.2021 17:00.28.574] [LOG]   trying to load module=compliments
              [30.12.2021 17:00.28.574] [LOG]   No helper found for module: compliments.
              [30.12.2021 17:00.28.574] [LOG]   trying to load module=MMM-Config
              [30.12.2021 17:00.28.625] [LOG]   Initializing new module helper ...
              [30.12.2021 17:00.28.625] [LOG]   Module helper loaded: MMM-Config
              [30.12.2021 17:00.28.626] [LOG]   trying to load module=MMM-WunderGround-PWS-Observations
              [30.12.2021 17:00.28.672] [LOG]   Initializing new module helper ...
              [30.12.2021 17:00.28.672] [LOG]   Module helper loaded: MMM-WunderGround-PWS-Observations
              [30.12.2021 17:00.28.672] [LOG]   trying to load module=MMM-Carousel
              [30.12.2021 17:00.28.672] [LOG]   No helper found for module: MMM-Carousel.
              [30.12.2021 17:00.28.672] [LOG]   trying to load module=MMM-TimeTreeEvent
              [30.12.2021 17:00.28.723] [LOG]   Initializing new module helper ...
              [30.12.2021 17:00.28.723] [LOG]   Module helper loaded: MMM-TimeTreeEvent
              [30.12.2021 17:00.28.723] [LOG]   trying to load module=MMM-SleepWake
              [30.12.2021 17:00.28.723] [LOG]   handler helper in init
              [30.12.2021 17:00.28.723] [LOG]   Module helper loaded: MMM-SleepWake
              [30.12.2021 17:00.28.724] [LOG]   All module helpers loaded.
              [30.12.2021 17:00.28.735] [LOG]   Starting server on port 8090 ...
              [30.12.2021 17:00.28.736] [WARN]  You're using a full whitelist configuration to allow for all IPs
              [30.12.2021 17:00.28.738] [LOG]   Server started ...
              • Z Offline
                zolabus @sdetweil
                @sdetweil pi@magicmirror:~/MagicMirror $ npm start
                Fontconfig warning: “/etc/fonts/fonts.conf”, line 100: unknown element “blank”
                [01.01.2022 11:39.38.805] [LOG] Starting MagicMirror: v2.17.1
                [01.01.2022 11:39.38.821] [LOG] Loading config …
                [01.01.2022 11:39.38.846] [LOG] Loading module helpers …
                [01.01.2022 11:39.38.853] [LOG] No helper found for module: alert.
                [01.01.2022 11:39.38.927] [LOG] Initializing new module helper …
                [01.01.2022 11:39.38.932] [LOG] Module helper loaded: updatenotification
                [01.01.2022 11:39.38.937] [LOG] No helper found for module: clock.
                [01.01.2022 11:39.40.614] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'digest-fetch ’
                Require stack:
                • /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
                • /home/pi/MagicMirror/modules/default/calendar/node_helper.js
                • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/mai n.js
                [01.01.2022 11:39.40.623] [LOG] Loading module helpers …
                [01.01.2022 11:39.40.631] [LOG] No helper found for module: alert.
                [01.01.2022 11:39.40.637] [LOG] Initializing new module helper …
                [01.01.2022 11:39.40.642] [LOG] Module helper loaded: updatenotification
                [01.01.2022 11:39.40.646] [LOG] No helper found for module: clock.
                [01.01.2022 11:39.40.658] [ERROR] App threw an error during load
                [01.01.2022 11:39.40.687] [ERROR] Error: Cannot find module ‘digest-fetch’
                Require stack:
                • at Module._resolveFilename (internal/modules/cjs/loader.js:798:15)
                  at Function…/lib/common/reset-search-paths.ts.Module._resolveFilename (elec tron/js2c/browser_init.js:7718:16)
                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/modul e-alias/index.js:49:29)
                  at Module._load (internal/modules/cjs/loader.js:691:27)
                  at Function.Module._load (electron/js2c/asar.js:748:26)
                  at Module.require (internal/modules/cjs/loader.js:853:19)
                  at require (internal/modules/cjs/helpers.js:74:18)
                  at Object. (/home/pi/MagicMirror/modules/default/calendar/calenda rfetcher.js:12:16)
                  at Module._compile (internal/modules/cjs/loader.js:968:30)
                  at Object.Module._extensions…js (internal/modules/cjs/loader.js:986:10)
                  [01.01.2022 11:39.40.706] [ERROR] Whoops! There was an uncaught exception…
                  [01.01.2022 11:39.40.728] [ERROR] Error: Cannot find module ‘digest-fetch’
                  Require stack:
                  at Object.Module._extensions…js (internal/modules/cjs/loader.js:986:10) {
                  code: ‘MODULE_NOT_FOUND’,
                  requireStack: [
                  ‘/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js’,
                  ‘/home/pi/MagicMirror/modules/default/calendar/node_helper.js’,
                  ‘/home/pi/MagicMirror/js/app.js’,
                  ‘/home/pi/MagicMirror/js/electron.js’,
                  ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/ main.js’,
                  undefined
                  [01.01.2022 11:39.40.754] [ERROR] MagicMirror will not quit, but it might be a g ood idea to check why this happened. Maybe no internet connection?
                  [01.01.2022 11:39.40.761] [ERROR] If you think this really is an issue, please o pen an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [01.01.2022 11:39.41.576] [LOG] Launching application.
                  [01.01.2022 11:39.41.658] [WARN] (electron) The default value of app.allowRende rerProcessReuse is deprecated, it is currently “false”. It will change to be “t rue” in Electron 9. For more information please check https://github.com/electr on/electron/issues/18397
                  sdetweil @zolabus
                  @zolabus edited
                  see the comments below…
                  • karsten13K Offline
                    karsten13 @sdetweil
                    in this case I don’t think it is the problem you mentioned with the link.
                    digest-fetch is a core dependency, so he may forgot to run npm install in the mm folder. Or if it’s an old installation which is suddenly not working anymore this is may caused by a corrupt SD Card.
                      sdetweil @karsten13
                      @karsten13 ok, got it… I agree…
                      • Z Offline
                        zolabus @sdetweil
                        @sdetweil run npm install with this output
                        npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I’ll try to do my best with it!
                        npm WARN deprecated core-js@2.6.12: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^2.3.2 (node_modules/jest-haste-map/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                        npm ERR! path /home/pi/MagicMirror/node_modules/ical
                        npm ERR! code EISGIT
                        npm ERR! git /home/pi/MagicMirror/node_modules/ical: Appears to be a git repo or submodule.
                        npm ERR! git Refusing to remove it. Update manually,
                        npm ERR! git or move it out of the way first.
                        npm ERR! /home/pi/.npm/_logs/2022-01-01T16_16_01_042Z-debug.log
                          sdetweil @zolabus
                          @zolabus we don’t use ical anymore. weird, do
                          rm -rf node_modules
                          npm install
                          • Z Offline
                            zolabus @sdetweil
                            @sdetweil same problem…
                              sdetweil @zolabus
                              @zolabus
                              this folder does not exist in the latest release
                              and if u deleted the node_modules folder (per the prior instructions) it should not exist on your system either
                              do
                              grep version ~/MagicMirror/package.json
                              karsten13K Z 2 Replies Last reply Reply Quote 0
                                karsten13 @sdetweil
                                @sdetweil may he should delete package-lock.json too
                                S Z 2 Replies Last reply Reply Quote 0
                                  sdetweil @karsten13
                                  @karsten13 true…
                                  • Z Offline
                                    zolabus @sdetweil
                                    @sdetweil said in Magic mirror not starting:
                                    “version”: “2.17.1”,
                                    • Z Offline
                                      zolabus @karsten13
                                      @karsten13 done…
                                      My log now is
                                      [03.01.2022 09:56.26.101] [LOG] Starting MagicMirror: v2.17.1
                                      [03.01.2022 09:56.26.130] [LOG] Loading config …
                                      [03.01.2022 09:56.26.156] [LOG] Loading module helpers …
                                      [03.01.2022 09:56.26.166] [LOG] No helper found for module: alert.
                                      [03.01.2022 09:56.26.238] [LOG] Initializing new module helper …
                                      [03.01.2022 09:56.26.243] [LOG] Module helper loaded: updatenotification
                                      [03.01.2022 09:56.26.246] [LOG] No helper found for module: clock.
                                      [03.01.2022 09:56.27.074] [LOG] Initializing new module helper …
                                      [03.01.2022 09:56.27.078] [LOG] Module helper loaded: calendar
                                      [03.01.2022 09:56.28.016] [LOG] Initializing new module helper …
                                      [03.01.2022 09:56.28.020] [LOG] Module helper loaded: MMM-GooglePhotos
                                      [03.01.2022 09:56.29.319] [LOG] Initializing new module helper …
                                      [03.01.2022 09:56.29.323] [LOG] Module helper loaded: MMM-DarkSkyForecast
                                      [03.01.2022 09:56.29.407] [LOG] Initializing new module helper …
                                      [03.01.2022 09:56.29.409] [LOG] Module helper loaded: newsfeed
                                      [03.01.2022 09:56.29.412] [LOG] No helper found for module: compliments.
                                      [03.01.2022 09:56.29.427] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’
                                      Require stack:
                                      • /home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js
                                      [03.01.2022 09:56.29.432] [LOG] Loading module helpers …
                                      [03.01.2022 09:56.29.439] [LOG] No helper found for module: alert.
                                      [03.01.2022 09:56.29.442] [LOG] Initializing new module helper …
                                      [03.01.2022 09:56.29.444] [LOG] Module helper loaded: updatenotification
                                      [03.01.2022 09:56.29.447] [LOG] No helper found for module: clock.
                                      [03.01.2022 09:56.29.450] [LOG] Initializing new module helper …
                                      [03.01.2022 09:56.29.454] [LOG] Module helper loaded: calendar
                                      [03.01.2022 09:56.29.459] [LOG] Initializing new module helper …
                                      [03.01.2022 09:56.29.462] [LOG] Module helper loaded: MMM-GooglePhotos
                                      [03.01.2022 09:56.29.467] [LOG] Initializing new module helper …
                                      [03.01.2022 09:56.29.470] [LOG] Module helper loaded: MMM-DarkSkyForecast
                                      [03.01.2022 09:56.29.473] [LOG] Initializing new module helper …
                                      [03.01.2022 09:56.29.475] [LOG] Module helper loaded: newsfeed
                                      [03.01.2022 09:56.29.478] [LOG] No helper found for module: compliments.
                                      [03.01.2022 09:56.29.487] [ERROR] App threw an error during load
                                      [03.01.2022 09:56.29.497] [ERROR] Error: Cannot find module ‘request’
                                      Require stack:
                                      • at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
                                        at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
                                        at Module._load (internal/modules/cjs/loader.js:732:27)
                                        at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
                                        at Module.require (internal/modules/cjs/loader.js:959:19)
                                        at require (internal/modules/cjs/helpers.js:88:18)
                                        at Object. (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node _helper.js:11:15)
                                        at Module._compile (internal/modules/cjs/loader.js:1078:30)
                                        at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10)
                                        [03.01.2022 09:56.29.503] [ERROR] Whoops! There was an uncaught exception…
                                        [03.01.2022 09:56.29.526] [ERROR] Error: Cannot find module ‘request’
                                        Require stack:
                                        at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10) {
                                        requireStack: [
                                        ‘/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js’,
                                        undefined
                                        [03.01.2022 09:56.29.545] [ERROR] MagicMirror will not quit, but it might be a g ood idea to check why this happened. Maybe no internet connection?
                                        [03.01.2022 09:56.29.548] [ERROR] If you think this really is an issue, please o pen an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        [03.01.2022 09:56.30.426] [LOG] Launching application.
                                      • Z Offline
                                        zolabus
                                        I saved all the modules I had installed…
                                        What else for a backup?
                                        What about a clean reinstallation?
                                        How can I delete everything? It’s enough if I delete the MagicMirror folder?
                                          sdetweil @zolabus
                                          @zolabus said in Magic mirror not starting:
                                          see
                                          • Z Offline
                                            zolabus @zolabus
