    Hello-Lucy using Adafruit Voice Bonnet
    24 Posts 2 Posters 5.8k Views 2 Watching
      sinbad339
      I’m trying to bring up Hello-Lucy on a “new” Magic Mirror. I’m running on a Pi 3B+, and installed the Adafruit Voice Bonnet for audio.
      I can do
      arecord --format cd --duration 7 --channels 1 test2.wav
      then
      aplay test2.wav
      and I hear the recording from the Voice Bonnet speaker. I don’t have to specify he device for these to work.
      When I list my audio devices, I get:
      pi@Magic:~/MagicMirror/config $ aplay -l
      **** List of PLAYBACK Hardware Devices ****
      card 0: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
      Subdevices: 8/8
      Subdevice #0: subdevice #0
      Subdevice #1: subdevice #1
      Subdevice #2: subdevice #2
      Subdevice #3: subdevice #3
      Subdevice #4: subdevice #4
      Subdevice #5: subdevice #5
      Subdevice #6: subdevice #6
      Subdevice #7: subdevice #7
      card 1: vc4hdmi [vc4-hdmi], device 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
      Subdevices: 1/1
      card 2: seeed2micvoicec [seeed-2mic-voicecard], device 0: bcm2835-i2s-wm8960-hifi wm8960-hifi-0 [bcm2835-i2s-wm8960-hifi wm8960-hifi-0]
      Subdevices: 1/1
      pi@Magic:~/MagicMirror/config $ arecord -l
      **** List of CAPTURE Hardware Devices ****
      Subdevices: 1/1
      Card 2 for both play and capture is the Voice Bonnet.
      When I restart MMM with Hello-Lucy, I hear the default greeting, but always get the microphone shown with ERROR. Even though the lists indicate card 2, I’ve tried 0 and 1 since card 2 is the only thing listed, but still no microphone.
      Here’s my config.js file:
      /* Magic Mirror Config Sample
      • By Michael Teeuw https://michaelteeuw.nl
      • MIT Licensed.
      let config = {
      address: “localhost”, // Address to listen on, can be:
      // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
      // - “0.0.0.0”, “::” to listen on any interface
      // Default, when address config is left out or empty, is “localhost”
      port: 8081,
      basePath: “/”, // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
          useHttps: false,                // Support HTTPS or not, default "false" will use HTTP
          httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
          httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
          language: "en",
          locale: "en-US",
          timeFormat: 24,
          units: "imperial",
                  disabled: false,
                  module: "Hello-Lucy",
                  position: "top_center",
                      keyword: 'HELLO LUCY',              // keyword to activate listening for a command/sentence
                      timeout: 15,                        // timeout listening for a command/sentence
                      standByMethod: 'DPMS',              // 'DPMS' = anything else than RPi or 'PI'
                      microphone: "1,0",                  // run "arecord -l" card # and device # mine is "0,0"
                      sounds: ["1.mp3", "11.mp3"],        // welcome sound at startup. Add several for a random greetings
                      confirmationSound: "ding.mp3",      // name and extension of sound file
                      startHideAll: true,                 // All modules start as hidden EXCEPT PAGE ONE
                      // *** Page One is your default startup page *** This overrides startHideAll: true,
                      pageOneModules: ["Hello-Lucy","MMM-EasyPix"],                     // default modules to show on page one/startup
                      pageTwoModules: ["Hello-Lucy", "MMM-BMW-DS", "MMM-EventHorizon"], // modules to show on page two
                      pageThreeModules: ["Hello-Lucy", "MMM-Lunartic"],                 // modules to show on page three
                      pageFourModules: ["Hello-Lucy", "MMM-PC-Stats"],                  // modules to show on page four
                      pageFiveModules: ["Hello-Lucy", "MMM-Searchlight"],               // modules to show on page five
                      pageSixModules: ["Hello-Lucy", "MMM-NOAA3"],                      // modules to show on page six
                      pageSevenModules: ["Hello-Lucy", "MMM-Recipe"],                   // modules to show on page seven
                      pageEightModules: ["Hello-Lucy", "MMM-rfacts"],                   // modules to show on page eight
                      pageNineModules: ["Hello-Lucy", "MMM-History"],                   // modules to show on page nine
                      pageTenModules: ["Hello-Lucy", "MMM-HardwareMonitor"]             // modules to show on page ten
      if (typeof module !== “undefined”) {module.exports = config;}
      Any help would be appreciated.
        sinbad339
        Well, I gave up on the Adafruit Voice Bonnet, and instead installed a USB microphone with output (Samson GoMic). Now, mic and speakers work every time whether MM/Hello-Lucy starts up automatically at boot, or if I start it using npm start.
        I’ll probably mark it resolved, even thought the fundamental issue is not.
        A BIG thanks to @sdetweil for all of his patience and help.
          sdetweil @sinbad339
          @sinbad339 said in Hello-Lucy using Adafruit Voice Bonnet:
            microphone: "1,0",
          so arecord says card 2,0
           arecord -l
          Subdevices: 1/1
          so it should be
           microphone: "2,0",
            sinbad339 @sdetweil
            @sdetweil said in Hello-Lucy using Adafruit Voice Bonnet:
            so it should be
            microphone: “2,0”,
            Thanks for replying. This config is what I had when I posted. As I mentioned, I’ve tried “0,0”, “1,0”, and “2,0”; all result in the microphone error.
              sdetweil @sinbad339
              @sinbad339 can u try this
              arecord -D default -q  -r 16000 -c 1 -t wav -f S16_LE >test.wav
              the replace default with
              arecord -D hw:2,0  -q -r 16000 -c 1 -t wav -f S16_LE >test.wav
                sinbad339 @sdetweil
                With MM running, if I issue
                I get a good .wave file that I can play.
                With MM still running, specifying the hw explicitly results in an error.
                arecord -D hw:2,0  -q -r 16000 -c 1 -t wav -f S16_LE >test2.wav
                arecord: main:830: audio open error: Device or resource busy
                  Subdevices: 0/1
                  sdetweil @sinbad339
                  ok, so MM is using that device
                  while mm is running do
                  ps -ef | grep arec
                  u should see the arecord process and the parms passed
                  from one of my apps that uses arecord
                  arecord -D default -q -r 16000 -c 1 -t wav -f S16_LE -
                  the trailing dash means stream content to stdout (which is captured by the upstream library)
                    @sinbad339
                    arecord -D default
                    the question is, what is ‘default’
                      sinbad339 @sdetweil
                      So the arecord -l lists card2 as my expected capture device (seeed-2mic-voicecard). I find it interesting that it enumverates as #2 with no #0 or #1.
                      Anyway, I ran your ps command; not sure what this output means (as I’m sure you’re aware by now, I’m a Noob on Linux).
                      ps -ef | grep arec
                      pi        1953  1927  0 11:04 pts/0    00:00:00 grep --color=auto arec
                        sdetweil @sinbad339
                        @sinbad339 hm…
                        should have used arecord…
                        try
                        ps -ef | grep rec
                        (there are only 2 apps… arecord or rec )
                        the output from ps
                        user that started process
                        the process id
                        the parent process id +
                        (i don’t know, 0)
                        the time the process was started
                        (i don’t know, pts/ )
                        how much cpu time has been used since started, in seconds
                        the string used to start the process, pgm name and then parms
                          sinbad339 @sdetweil
                          ps -ef | grep rec
                          root        76     2  0 11:02 ?        00:00:00 [vchiq-recy/0]
                          pi        2320  1927  0 11:24 pts/0    00:00:00 grep --color=auto rec
                          Not sure what vchiq-recy is…
                          But no arec or arecord.
                            sdetweil @sinbad339
                            well, that explains the error…
                            you did run the installation dependencies script, right?
                            cd Hello-Lucy/installers
                            bash dependencies.sh
                              sinbad339 @sdetweil
                              Yes, I did run it. Its been a while, and I remember warning about depreciated versions, but nothing that I thought could be an issue. OK to run it again?
                                sdetweil @sinbad339
                                OK to run it again?
                                i don’t think there is a need
                                add debug:true to the module config section
                                module:
                                    config:  {
                                        debug:true,
                                   .... whatever else was there
                                and then
                                pm2 stop all
                                cd ~/MagicMirror
                                npm start >somefile.txt
                                when error reported
                                alt-spacebar, n to minimize mm
                                ctrl-c to stop mm
                                and look at somefile.txt
                                  sinbad339 @sdetweil
                                  WELL, now it seems to work. Running from command line w/ debug, I don’t get microphone with ERROR, and if I say “Hello Lucy”, it prompts for a command, then does it, and issues the “ding”. I’ve done this three times now, and its worked every time. Here’s the debug outout:
                                  > magicmirror@2.18.0 start /home/pi/MagicMirror
                                  [05.01.2022 11:55.24.384] [LOG]   Starting MagicMirror: v2.18.0
                                  [05.01.2022 11:55.24.394] [LOG]   Loading config ...
                                  [05.01.2022 11:55.24.404] [LOG]   Loading module helpers ...
                                  [05.01.2022 11:55.26.860] [LOG]   Initializing new module helper ...
                                  [05.01.2022 11:55.26.864] [LOG]   Module helper loaded: Hello-Lucy
                                  [05.01.2022 11:55.26.866] [LOG]   All module helpers loaded.
                                  [05.01.2022 11:55.27.040] [LOG]   Starting server on port 8081 ...
                                  [05.01.2022 11:55.27.066] [LOG]   Server started ...
                                  [05.01.2022 11:55.27.069] [LOG]   Connecting socket for: Hello-Lucy
                                  [05.01.2022 11:55.27.071] [LOG]   Starting module helper: Hello-Lucy
                                  [05.01.2022 11:55.27.073] [LOG]   Sockets connected & modules started ...
                                  [05.01.2022 11:55.27.482] [LOG]   Launching application.
                                  [05.01.2022 11:55.37.133] [LOG]   Hello-Lucy has recognized: ALL IS THE
                                  [05.01.2022 11:56.16.829] [LOG]   Hello-Lucy has recognized: NINE
                                    sinbad339
                                    The difference is how MM is started. If I do it the manual way, the microphone works (with or without debug enabled). If MM does its normal autostart, using mm.sh that includes DISPLAY=:0 npm start, then the microphone doesn’t work.
                                      sdetweil @sinbad339
                                      how is that done? pm2 or did u do some other setup
                                      sounds like mm is not running as user but as root?
                                        sinbad339 @sdetweil
                                        I followed the instructions from https://www.magicmirrorcentral.com/complete-raspberry-pi-magic-mirror-tutorial/.
                                        It included
                                        type in the following command:
                                        pm2 startup
                                        A different command will appear. Run that command also.
                                        Now create a shell script for startup. Open up the built-in text editor on the Pi by typing in:
                                        cd ~
                                        nano mm.sh
                                        The lower line basically means, “open up a file called mm.sh in the nano text editor.”
                                        When the text editor has opened, add this to the mm.sh file:
                                        cd ~/MagicMirror
                                        Make your shiny new script executable by typing in:
                                        chmod +x mm.sh
                                        Now start up Magic Mirror and make it start up on boot:
                                        pm2 start mm.sh
                                        pm2 save
                                        Now, reboot your Pi by typing in
                                        sudo reboot
                                          sdetweil @sinbad339
                                          @sinbad339 hm… my install script does all that.
                                          mm.sh already exists in the installers folder.
                                          try my fixuppm2.sh from here
                                            sinbad339 @sdetweil
                                            Let me start by saying I really appreciate your help with this. You’ve given me a lot of your time, and clearly I couldn’t have made any progress without you. Thank you.
                                            Running your fixupppm2 script fixes the microphone on a restart, but then there is no speaker output. If I stop MM, then manually restart it with npm start, the mic and speaker work fine, as before the fixup.
                                              sdetweil @sinbad339
                                              @sinbad339 that makes no sense to me.
                                              could u start it w pm2, and then ps -ef >somefile.txt
                                              and email me thevfile some file.txt
                                              same userid as here at gmail.
                                              I want to see if there is some permissions problem
                                              oh, check the file contents to make sure no userid or password is exposed. shouldn’t be but u never know.
