    Hello-Lucy using Adafruit Voice Bonnet
    24 Posts 2 Posters 4.4k Views 2 Watching
      sdetweil @sinbad339
      @sinbad339 said in Hello-Lucy using Adafruit Voice Bonnet:
      But no arec or arecord.
      well, that explains the error…
      you did run the installation dependencies script, right?
      cd Hello-Lucy/installers
      bash dependencies.sh
        sinbad339 @sdetweil
        Yes, I did run it. Its been a while, and I remember warning about depreciated versions, but nothing that I thought could be an issue. OK to run it again?
          sdetweil @sinbad339
          OK to run it again?
          i don’t think there is a need
          add debug:true to the module config section
          module:
              config:  {
                  debug:true,
             .... whatever else was there
          and then
          pm2 stop all
          cd ~/MagicMirror
          npm start >somefile.txt
          when error reported
          alt-spacebar, n to minimize mm
          ctrl-c to stop mm
          and look at somefile.txt
            sinbad339 @sdetweil
            WELL, now it seems to work. Running from command line w/ debug, I don’t get microphone with ERROR, and if I say “Hello Lucy”, it prompts for a command, then does it, and issues the “ding”. I’ve done this three times now, and its worked every time. Here’s the debug outout:
            > magicmirror@2.18.0 start /home/pi/MagicMirror
            [05.01.2022 11:55.24.384] [LOG]   Starting MagicMirror: v2.18.0
            [05.01.2022 11:55.24.394] [LOG]   Loading config ...
            [05.01.2022 11:55.24.404] [LOG]   Loading module helpers ...
            [05.01.2022 11:55.26.860] [LOG]   Initializing new module helper ...
            [05.01.2022 11:55.26.864] [LOG]   Module helper loaded: Hello-Lucy
            [05.01.2022 11:55.26.866] [LOG]   All module helpers loaded.
            [05.01.2022 11:55.27.040] [LOG]   Starting server on port 8081 ...
            [05.01.2022 11:55.27.066] [LOG]   Server started ...
            [05.01.2022 11:55.27.069] [LOG]   Connecting socket for: Hello-Lucy
            [05.01.2022 11:55.27.071] [LOG]   Starting module helper: Hello-Lucy
            [05.01.2022 11:55.27.073] [LOG]   Sockets connected & modules started ...
            [05.01.2022 11:55.27.482] [LOG]   Launching application.
            [05.01.2022 11:55.37.133] [LOG]   Hello-Lucy has recognized: ALL IS THE
            [05.01.2022 11:56.16.829] [LOG]   Hello-Lucy has recognized: NINE
              sinbad339
              The difference is how MM is started. If I do it the manual way, the microphone works (with or without debug enabled). If MM does its normal autostart, using mm.sh that includes DISPLAY=:0 npm start, then the microphone doesn’t work.
                sdetweil @sinbad339
                how is that done? pm2 or did u do some other setup
                sounds like mm is not running as user but as root?
                  sinbad339 @sdetweil
                  I followed the instructions from https://www.magicmirrorcentral.com/complete-raspberry-pi-magic-mirror-tutorial/.
                  It included
                  type in the following command:
                  pm2 startup
                  A different command will appear. Run that command also.
                  Now create a shell script for startup. Open up the built-in text editor on the Pi by typing in:
                  cd ~
                  nano mm.sh
                  The lower line basically means, “open up a file called mm.sh in the nano text editor.”
                  When the text editor has opened, add this to the mm.sh file:
                  cd ~/MagicMirror
                  Make your shiny new script executable by typing in:
                  chmod +x mm.sh
                  Now start up Magic Mirror and make it start up on boot:
                  pm2 start mm.sh
                  pm2 save
                  Now, reboot your Pi by typing in
                  sudo reboot
                    sdetweil @sinbad339
                    @sinbad339 hm… my install script does all that.
                    mm.sh already exists in the installers folder.
                    try my fixuppm2.sh from here
                      sinbad339 @sdetweil
                      Let me start by saying I really appreciate your help with this. You’ve given me a lot of your time, and clearly I couldn’t have made any progress without you. Thank you.
                      Running your fixupppm2 script fixes the microphone on a restart, but then there is no speaker output. If I stop MM, then manually restart it with npm start, the mic and speaker work fine, as before the fixup.
                        sdetweil @sinbad339
                        @sinbad339 that makes no sense to me.
                        could u start it w pm2, and then ps -ef >somefile.txt
                        and email me thevfile some file.txt
                        same userid as here at gmail.
                        I want to see if there is some permissions problem
                        oh, check the file contents to make sure no userid or password is exposed. shouldn’t be but u never know.
                        • 2 / 3
