    Hello-Lucy using Adafruit Voice Bonnet
    24 Posts 2 Posters 5.2k Views 2 Watching
      sdetweil @sinbad339
      @sinbad339 said in Hello-Lucy using Adafruit Voice Bonnet:
      OK to run it again?
      i don’t think there is a need
      add debug:true to the module config section
      module:
          config:  {
              debug:true,
         .... whatever else was there
      and then
      pm2 stop all
      npm start >somefile.txt
      when error reported
      alt-spacebar, n to minimize mm
      ctrl-c to stop mm
      and look at somefile.txt
        sinbad339 @sdetweil
        WELL, now it seems to work. Running from command line w/ debug, I don’t get microphone with ERROR, and if I say “Hello Lucy”, it prompts for a command, then does it, and issues the “ding”. I’ve done this three times now, and its worked every time. Here’s the debug outout:
        > magicmirror@2.18.0 start /home/pi/MagicMirror
        [05.01.2022 11:55.24.384] [LOG]   Starting MagicMirror: v2.18.0
        [05.01.2022 11:55.24.394] [LOG]   Loading config ...
        [05.01.2022 11:55.24.404] [LOG]   Loading module helpers ...
        [05.01.2022 11:55.26.860] [LOG]   Initializing new module helper ...
        [05.01.2022 11:55.26.864] [LOG]   Module helper loaded: Hello-Lucy
        [05.01.2022 11:55.26.866] [LOG]   All module helpers loaded.
        [05.01.2022 11:55.27.040] [LOG]   Starting server on port 8081 ...
        [05.01.2022 11:55.27.066] [LOG]   Server started ...
        [05.01.2022 11:55.27.069] [LOG]   Connecting socket for: Hello-Lucy
        [05.01.2022 11:55.27.071] [LOG]   Starting module helper: Hello-Lucy
        [05.01.2022 11:55.27.073] [LOG]   Sockets connected & modules started ...
        [05.01.2022 11:55.27.482] [LOG]   Launching application.
        [05.01.2022 11:55.37.133] [LOG]   Hello-Lucy has recognized: ALL IS THE
        [05.01.2022 11:56.16.829] [LOG]   Hello-Lucy has recognized: NINE
          sinbad339
          The difference is how MM is started. If I do it the manual way, the microphone works (with or without debug enabled). If MM does its normal autostart, using mm.sh that includes DISPLAY=:0 npm start, then the microphone doesn’t work.
            sdetweil @sinbad339
            how is that done? pm2 or did u do some other setup
            sounds like mm is not running as user but as root?
              sinbad339 @sdetweil
              I followed the instructions from https://www.magicmirrorcentral.com/complete-raspberry-pi-magic-mirror-tutorial/.
              It included
              type in the following command:
              pm2 startup
              A different command will appear. Run that command also.
              Now create a shell script for startup. Open up the built-in text editor on the Pi by typing in:
              cd ~
              nano mm.sh
              The lower line basically means, “open up a file called mm.sh in the nano text editor.”
              When the text editor has opened, add this to the mm.sh file:
              Make your shiny new script executable by typing in:
              chmod +x mm.sh
              Now start up Magic Mirror and make it start up on boot:
              pm2 start mm.sh
              pm2 save
              Now, reboot your Pi by typing in
              sudo reboot
                sdetweil @sinbad339
                @sinbad339 hm… my install script does all that.
                mm.sh already exists in the installers folder.
                try my fixuppm2.sh from here
                  sinbad339 @sdetweil
                  Let me start by saying I really appreciate your help with this. You’ve given me a lot of your time, and clearly I couldn’t have made any progress without you. Thank you.
                  Running your fixupppm2 script fixes the microphone on a restart, but then there is no speaker output. If I stop MM, then manually restart it with npm start, the mic and speaker work fine, as before the fixup.
                    sdetweil @sinbad339
                    @sinbad339 that makes no sense to me.
                    could u start it w pm2, and then ps -ef >somefile.txt
                    and email me thevfile some file.txt
                    same userid as here at gmail.
                    I want to see if there is some permissions problem
                    oh, check the file contents to make sure no userid or password is exposed. shouldn’t be but u never know.
                      sinbad339 @sdetweil
                      Just sent it…
                        sinbad339
                        Just sent two additional files; one where the speaker worked, and one where it didn’t. As I explained in the email, this is an intermittent issue and it doesn’t matter how MM is started.
                          sdetweil @sinbad339
                          @sinbad339 i replied
                            sinbad339
                            Well, I gave up on the Adafruit Voice Bonnet, and instead installed a USB microphone with output (Samson GoMic). Now, mic and speakers work every time whether MM/Hello-Lucy starts up automatically at boot, or if I start it using npm start.
                            I’ll probably mark it resolved, even thought the fundamental issue is not.
                            A BIG thanks to @sdetweil for all of his patience and help.
