    Hello-Lucy using Adafruit Voice Bonnet
    24 Posts 2 Posters 4.5k Views 2 Watching
      sinbad339 @sdetweil
      @sdetweil said in Hello-Lucy using Adafruit Voice Bonnet:
      so it should be
      microphone: “2,0”,
      Thanks for replying. This config is what I had when I posted. As I mentioned, I’ve tried “0,0”, “1,0”, and “2,0”; all result in the microphone error.
        sdetweil @sinbad339
        @sinbad339 can u try this
        arecord -D default -q  -r 16000 -c 1 -t wav -f S16_LE >test.wav
        the replace default with
        arecord -D hw:2,0  -q -r 16000 -c 1 -t wav -f S16_LE >test.wav
          sinbad339 @sdetweil
          With MM running, if I issue
          I get a good .wave file that I can play.
          With MM still running, specifying the hw explicitly results in an error.
          arecord -D hw:2,0  -q -r 16000 -c 1 -t wav -f S16_LE >test2.wav
          arecord: main:830: audio open error: Device or resource busy
          pi@Magic:~/MagicMirror/config $ arecord -l
          **** List of CAPTURE Hardware Devices ****
          card 2: seeed2micvoicec [seeed-2mic-voicecard], device 0: bcm2835-i2s-wm8960-hifi wm8960-hifi-0 [bcm2835-i2s-wm8960-hifi wm8960-hifi-0]
            Subdevices: 0/1
            Subdevice #0: subdevice #0
            sdetweil @sinbad339
            @sinbad339 said in Hello-Lucy using Adafruit Voice Bonnet:
            ok, so MM is using that device
            while mm is running do
            ps -ef | grep arec
            u should see the arecord process and the parms passed
            from one of my apps that uses arecord
            arecord -D default -q -r 16000 -c 1 -t wav -f S16_LE -
            the trailing dash means stream content to stdout (which is captured by the upstream library)
              @sinbad339
              arecord -D default
              the question is, what is ‘default’
                sinbad339 @sdetweil
                So the arecord -l lists card2 as my expected capture device (seeed-2mic-voicecard). I find it interesting that it enumverates as #2 with no #0 or #1.
                Anyway, I ran your ps command; not sure what this output means (as I’m sure you’re aware by now, I’m a Noob on Linux).
                ps -ef | grep arec
                pi        1953  1927  0 11:04 pts/0    00:00:00 grep --color=auto arec
                  sdetweil @sinbad339
                  @sinbad339 hm…
                  should have used arecord…
                  try
                  ps -ef | grep rec
                  (there are only 2 apps… arecord or rec )
                  the output from ps
                  user that started process
                  the process id
                  the parent process id +
                  (i don’t know, 0)
                  the time the process was started
                  (i don’t know, pts/ )
                  how much cpu time has been used since started, in seconds
                  the string used to start the process, pgm name and then parms
                    sinbad339 @sdetweil
                    ps -ef | grep rec
                    root        76     2  0 11:02 ?        00:00:00 [vchiq-recy/0]
                    pi        2320  1927  0 11:24 pts/0    00:00:00 grep --color=auto rec
                    Not sure what vchiq-recy is…
                    But no arec or arecord.
                      sdetweil @sinbad339
                      well, that explains the error…
                      you did run the installation dependencies script, right?
                      cd Hello-Lucy/installers
                      bash dependencies.sh
                        sinbad339 @sdetweil
                        Yes, I did run it. Its been a while, and I remember warning about depreciated versions, but nothing that I thought could be an issue. OK to run it again?
