    Hello-Lucy using Adafruit Voice Bonnet
    24 Posts 2 Posters 5.7k Views 2 Watching
      sdetweil @sinbad339
      @sinbad339 said in Hello-Lucy using Adafruit Voice Bonnet:
      With MM still running, specifying the hw explicitly results in an error.
      ok, so MM is using that device
      while mm is running do
      ps -ef | grep arec
      u should see the arecord process and the parms passed
      from one of my apps that uses arecord
      arecord -D default -q -r 16000 -c 1 -t wav -f S16_LE -
      the trailing dash means stream content to stdout (which is captured by the upstream library)
        @sinbad339
        arecord -D default
        the question is, what is ‘default’
          sinbad339 @sdetweil
          So the arecord -l lists card2 as my expected capture device (seeed-2mic-voicecard). I find it interesting that it enumverates as #2 with no #0 or #1.
          Anyway, I ran your ps command; not sure what this output means (as I’m sure you’re aware by now, I’m a Noob on Linux).
          ps -ef | grep arec
          pi        1953  1927  0 11:04 pts/0    00:00:00 grep --color=auto arec
            sdetweil @sinbad339
            @sinbad339 hm…
            should have used arecord…
            try
            ps -ef | grep rec
            (there are only 2 apps… arecord or rec )
            the output from ps
            user that started process
            the process id
            the parent process id +
            (i don’t know, 0)
            the time the process was started
            (i don’t know, pts/ )
            how much cpu time has been used since started, in seconds
            the string used to start the process, pgm name and then parms
              sinbad339 @sdetweil
              ps -ef | grep rec
              root        76     2  0 11:02 ?        00:00:00 [vchiq-recy/0]
              pi        2320  1927  0 11:24 pts/0    00:00:00 grep --color=auto rec
              Not sure what vchiq-recy is…
              But no arec or arecord.
                sdetweil @sinbad339
                well, that explains the error…
                you did run the installation dependencies script, right?
                cd Hello-Lucy/installers
                bash dependencies.sh
                  sinbad339 @sdetweil
                  Yes, I did run it. Its been a while, and I remember warning about depreciated versions, but nothing that I thought could be an issue. OK to run it again?
                    sdetweil @sinbad339
                    OK to run it again?
                    i don’t think there is a need
                    add debug:true to the module config section
                    module:
                        config:  {
                            debug:true,
                       .... whatever else was there
                    and then
                    pm2 stop all
                    npm start >somefile.txt
                    when error reported
                    alt-spacebar, n to minimize mm
                    ctrl-c to stop mm
                    and look at somefile.txt
                      sinbad339 @sdetweil
                      WELL, now it seems to work. Running from command line w/ debug, I don’t get microphone with ERROR, and if I say “Hello Lucy”, it prompts for a command, then does it, and issues the “ding”. I’ve done this three times now, and its worked every time. Here’s the debug outout:
                      > magicmirror@2.18.0 start /home/pi/MagicMirror
                      [05.01.2022 11:55.24.384] [LOG]   Starting MagicMirror: v2.18.0
                      [05.01.2022 11:55.24.394] [LOG]   Loading config ...
                      [05.01.2022 11:55.24.404] [LOG]   Loading module helpers ...
                      [05.01.2022 11:55.26.860] [LOG]   Initializing new module helper ...
                      [05.01.2022 11:55.26.864] [LOG]   Module helper loaded: Hello-Lucy
                      [05.01.2022 11:55.26.866] [LOG]   All module helpers loaded.
                      [05.01.2022 11:55.27.040] [LOG]   Starting server on port 8081 ...
                      [05.01.2022 11:55.27.066] [LOG]   Server started ...
                      [05.01.2022 11:55.27.069] [LOG]   Connecting socket for: Hello-Lucy
                      [05.01.2022 11:55.27.071] [LOG]   Starting module helper: Hello-Lucy
                      [05.01.2022 11:55.27.073] [LOG]   Sockets connected & modules started ...
                      [05.01.2022 11:55.27.482] [LOG]   Launching application.
                      [05.01.2022 11:55.37.133] [LOG]   Hello-Lucy has recognized: ALL IS THE
                      [05.01.2022 11:56.16.829] [LOG]   Hello-Lucy has recognized: NINE
                        sinbad339
                        The difference is how MM is started. If I do it the manual way, the microphone works (with or without debug enabled). If MM does its normal autostart, using mm.sh that includes DISPLAY=:0 npm start, then the microphone doesn’t work.
                          sdetweil @sinbad339
                          how is that done? pm2 or did u do some other setup
                          sounds like mm is not running as user but as root?
                            sinbad339 @sdetweil
                            I followed the instructions from https://www.magicmirrorcentral.com/complete-raspberry-pi-magic-mirror-tutorial/.
                            It included
                            type in the following command:
                            pm2 startup
                            A different command will appear. Run that command also.
                            Now create a shell script for startup. Open up the built-in text editor on the Pi by typing in:
                            cd ~
                            nano mm.sh
                            The lower line basically means, “open up a file called mm.sh in the nano text editor.”
                            When the text editor has opened, add this to the mm.sh file:
                            Make your shiny new script executable by typing in:
                            chmod +x mm.sh
                            Now start up Magic Mirror and make it start up on boot:
                            pm2 start mm.sh
                            pm2 save
                            Now, reboot your Pi by typing in
                            sudo reboot
                              sdetweil @sinbad339
                              @sinbad339 hm… my install script does all that.
                              mm.sh already exists in the installers folder.
                              try my fixuppm2.sh from here
                                sinbad339 @sdetweil
                                Let me start by saying I really appreciate your help with this. You’ve given me a lot of your time, and clearly I couldn’t have made any progress without you. Thank you.
                                Running your fixupppm2 script fixes the microphone on a restart, but then there is no speaker output. If I stop MM, then manually restart it with npm start, the mic and speaker work fine, as before the fixup.
                                  sdetweil @sinbad339
                                  @sinbad339 that makes no sense to me.
                                  could u start it w pm2, and then ps -ef >somefile.txt
                                  and email me thevfile some file.txt
                                  same userid as here at gmail.
                                  I want to see if there is some permissions problem
                                  oh, check the file contents to make sure no userid or password is exposed. shouldn’t be but u never know.
                                    sinbad339 @sdetweil
                                    Just sent it…
                                      sinbad339
                                      Just sent two additional files; one where the speaker worked, and one where it didn’t. As I explained in the email, this is an intermittent issue and it doesn’t matter how MM is started.
                                        sdetweil @sinbad339
                                        @sinbad339 i replied
                                          sinbad339
                                          Well, I gave up on the Adafruit Voice Bonnet, and instead installed a USB microphone with output (Samson GoMic). Now, mic and speakers work every time whether MM/Hello-Lucy starts up automatically at boot, or if I start it using npm start.
                                          I’ll probably mark it resolved, even thought the fundamental issue is not.
                                          A BIG thanks to @sdetweil for all of his patience and help.
