    Hello-Lucy using Adafruit Voice Bonnet
    24 Posts 2 Posters 5.7k Views 2 Watching
      sdetweil @sinbad339
      @sinbad339 hm…
      should have used arecord…
      try
      ps -ef | grep rec
      (there are only 2 apps… arecord or rec )
      the output from ps
      pi        1953  1927  0 11:04 pts/0    00:00:00 grep --color=auto arec
      user that started process
      the process id
      the parent process id +
      (i don’t know, 0)
      the time the process was started
      (i don’t know, pts/ )
      how much cpu time has been used since started, in seconds
      the string used to start the process, pgm name and then parms
        sinbad339 @sdetweil
        ps -ef | grep rec
        root        76     2  0 11:02 ?        00:00:00 [vchiq-recy/0]
        pi        2320  1927  0 11:24 pts/0    00:00:00 grep --color=auto rec
        Not sure what vchiq-recy is…
        But no arec or arecord.
          sdetweil @sinbad339
          @sinbad339 said in Hello-Lucy using Adafruit Voice Bonnet:
          well, that explains the error…
          you did run the installation dependencies script, right?
          cd Hello-Lucy/installers
          bash dependencies.sh
            sinbad339 @sdetweil
            Yes, I did run it. Its been a while, and I remember warning about depreciated versions, but nothing that I thought could be an issue. OK to run it again?
              sdetweil @sinbad339
              OK to run it again?
              i don’t think there is a need
              add debug:true to the module config section
              module:
                  config:  {
                      debug:true,
                 .... whatever else was there
              and then
              pm2 stop all
              npm start >somefile.txt
              when error reported
              alt-spacebar, n to minimize mm
              ctrl-c to stop mm
              and look at somefile.txt
                sinbad339 @sdetweil
                WELL, now it seems to work. Running from command line w/ debug, I don’t get microphone with ERROR, and if I say “Hello Lucy”, it prompts for a command, then does it, and issues the “ding”. I’ve done this three times now, and its worked every time. Here’s the debug outout:
                > magicmirror@2.18.0 start /home/pi/MagicMirror
                [05.01.2022 11:55.24.384] [LOG]   Starting MagicMirror: v2.18.0
                [05.01.2022 11:55.24.394] [LOG]   Loading config ...
                [05.01.2022 11:55.24.404] [LOG]   Loading module helpers ...
                [05.01.2022 11:55.26.860] [LOG]   Initializing new module helper ...
                [05.01.2022 11:55.26.864] [LOG]   Module helper loaded: Hello-Lucy
                [05.01.2022 11:55.26.866] [LOG]   All module helpers loaded.
                [05.01.2022 11:55.27.040] [LOG]   Starting server on port 8081 ...
                [05.01.2022 11:55.27.066] [LOG]   Server started ...
                [05.01.2022 11:55.27.069] [LOG]   Connecting socket for: Hello-Lucy
                [05.01.2022 11:55.27.071] [LOG]   Starting module helper: Hello-Lucy
                [05.01.2022 11:55.27.073] [LOG]   Sockets connected & modules started ...
                [05.01.2022 11:55.27.482] [LOG]   Launching application.
                [05.01.2022 11:55.37.133] [LOG]   Hello-Lucy has recognized: ALL IS THE
                [05.01.2022 11:56.16.829] [LOG]   Hello-Lucy has recognized: NINE
                  sinbad339
                  The difference is how MM is started. If I do it the manual way, the microphone works (with or without debug enabled). If MM does its normal autostart, using mm.sh that includes DISPLAY=:0 npm start, then the microphone doesn’t work.
                    sdetweil @sinbad339
                    how is that done? pm2 or did u do some other setup
                    sounds like mm is not running as user but as root?
                      sinbad339 @sdetweil
                      I followed the instructions from https://www.magicmirrorcentral.com/complete-raspberry-pi-magic-mirror-tutorial/.
                      It included
                      type in the following command:
                      pm2 startup
                      A different command will appear. Run that command also.
                      Now create a shell script for startup. Open up the built-in text editor on the Pi by typing in:
                      cd ~
                      nano mm.sh
                      The lower line basically means, “open up a file called mm.sh in the nano text editor.”
                      When the text editor has opened, add this to the mm.sh file:
                      Make your shiny new script executable by typing in:
                      chmod +x mm.sh
                      Now start up Magic Mirror and make it start up on boot:
                      pm2 start mm.sh
                      pm2 save
                      Now, reboot your Pi by typing in
                      sudo reboot
                        sdetweil @sinbad339
                        @sinbad339 hm… my install script does all that.
                        mm.sh already exists in the installers folder.
                        try my fixuppm2.sh from here
                          sinbad339 @sdetweil
                          Let me start by saying I really appreciate your help with this. You’ve given me a lot of your time, and clearly I couldn’t have made any progress without you. Thank you.
                          Running your fixupppm2 script fixes the microphone on a restart, but then there is no speaker output. If I stop MM, then manually restart it with npm start, the mic and speaker work fine, as before the fixup.
                            sdetweil @sinbad339
                            @sinbad339 that makes no sense to me.
                            could u start it w pm2, and then ps -ef >somefile.txt
                            and email me thevfile some file.txt
                            same userid as here at gmail.
                            I want to see if there is some permissions problem
                            oh, check the file contents to make sure no userid or password is exposed. shouldn’t be but u never know.
                              sinbad339 @sdetweil
                              Just sent it…
                                sinbad339
                                Just sent two additional files; one where the speaker worked, and one where it didn’t. As I explained in the email, this is an intermittent issue and it doesn’t matter how MM is started.
                                  sdetweil @sinbad339
                                  @sinbad339 i replied
                                    sinbad339
                                    Well, I gave up on the Adafruit Voice Bonnet, and instead installed a USB microphone with output (Samson GoMic). Now, mic and speakers work every time whether MM/Hello-Lucy starts up automatically at boot, or if I start it using npm start.
                                    I’ll probably mark it resolved, even thought the fundamental issue is not.
                                    A BIG thanks to @sdetweil for all of his patience and help.
