    Hello-Lucy using Adafruit Voice Bonnet
    24 Posts 2 Posters 5.5k Views 2 Watching
      sdetweil @sinbad339
      @sinbad339 said in Hello-Lucy using Adafruit Voice Bonnet:
        microphone: "1,0",
      so arecord says card 2,0
       arecord -l
      **** List of CAPTURE Hardware Devices ****
      card 2: seeed2micvoicec [seeed-2mic-voicecard], device 0: bcm2835-i2s-wm8960-hifi wm8960-hifi-0 [bcm2835-i2s-wm8960-hifi wm8960-hifi-0]
      Subdevices: 1/1
      Subdevice #0: subdevice #0
      so it should be
       microphone: "2,0",
        sinbad339 @sdetweil
        @sdetweil said in Hello-Lucy using Adafruit Voice Bonnet:
        so it should be
        microphone: “2,0”,
        Thanks for replying. This config is what I had when I posted. As I mentioned, I’ve tried “0,0”, “1,0”, and “2,0”; all result in the microphone error.
          sdetweil @sinbad339
          @sinbad339 can u try this
          arecord -D default -q  -r 16000 -c 1 -t wav -f S16_LE >test.wav
          the replace default with
          arecord -D hw:2,0  -q -r 16000 -c 1 -t wav -f S16_LE >test.wav
            sinbad339 @sdetweil
            With MM running, if I issue
            I get a good .wave file that I can play.
            With MM still running, specifying the hw explicitly results in an error.
            arecord -D hw:2,0  -q -r 16000 -c 1 -t wav -f S16_LE >test2.wav
            arecord: main:830: audio open error: Device or resource busy
            pi@Magic:~/MagicMirror/config $ arecord -l
              Subdevices: 0/1
              sdetweil @sinbad339
              ok, so MM is using that device
              while mm is running do
              ps -ef | grep arec
              u should see the arecord process and the parms passed
              from one of my apps that uses arecord
              arecord -D default -q -r 16000 -c 1 -t wav -f S16_LE -
              the trailing dash means stream content to stdout (which is captured by the upstream library)
                @sinbad339
                arecord -D default
                the question is, what is ‘default’
                  sinbad339 @sdetweil
                  So the arecord -l lists card2 as my expected capture device (seeed-2mic-voicecard). I find it interesting that it enumverates as #2 with no #0 or #1.
                  Anyway, I ran your ps command; not sure what this output means (as I’m sure you’re aware by now, I’m a Noob on Linux).
                  ps -ef | grep arec
                  pi        1953  1927  0 11:04 pts/0    00:00:00 grep --color=auto arec
                    sdetweil @sinbad339
                    @sinbad339 hm…
                    should have used arecord…
                    try
                    ps -ef | grep rec
                    (there are only 2 apps… arecord or rec )
                    the output from ps
                    user that started process
                    the process id
                    the parent process id +
                    (i don’t know, 0)
                    the time the process was started
                    (i don’t know, pts/ )
                    how much cpu time has been used since started, in seconds
                    the string used to start the process, pgm name and then parms
                      sinbad339 @sdetweil
                      ps -ef | grep rec
                      root        76     2  0 11:02 ?        00:00:00 [vchiq-recy/0]
                      pi        2320  1927  0 11:24 pts/0    00:00:00 grep --color=auto rec
                      Not sure what vchiq-recy is…
                      But no arec or arecord.
                        sdetweil @sinbad339
                        well, that explains the error…
                        you did run the installation dependencies script, right?
                        cd Hello-Lucy/installers
                        bash dependencies.sh
                          sinbad339 @sdetweil
                          Yes, I did run it. Its been a while, and I remember warning about depreciated versions, but nothing that I thought could be an issue. OK to run it again?
                            sdetweil @sinbad339
                            OK to run it again?
                            i don’t think there is a need
                            add debug:true to the module config section
                            module:
                                config:  {
                                    debug:true,
                               .... whatever else was there
                            and then
                            pm2 stop all
                            npm start >somefile.txt
                            when error reported
                            alt-spacebar, n to minimize mm
                            ctrl-c to stop mm
                            and look at somefile.txt
                              sinbad339 @sdetweil
                              WELL, now it seems to work. Running from command line w/ debug, I don’t get microphone with ERROR, and if I say “Hello Lucy”, it prompts for a command, then does it, and issues the “ding”. I’ve done this three times now, and its worked every time. Here’s the debug outout:
                              > magicmirror@2.18.0 start /home/pi/MagicMirror
                              [05.01.2022 11:55.24.384] [LOG]   Starting MagicMirror: v2.18.0
                              [05.01.2022 11:55.24.394] [LOG]   Loading config ...
                              [05.01.2022 11:55.24.404] [LOG]   Loading module helpers ...
                              [05.01.2022 11:55.26.860] [LOG]   Initializing new module helper ...
                              [05.01.2022 11:55.26.864] [LOG]   Module helper loaded: Hello-Lucy
                              [05.01.2022 11:55.26.866] [LOG]   All module helpers loaded.
                              [05.01.2022 11:55.27.040] [LOG]   Starting server on port 8081 ...
                              [05.01.2022 11:55.27.066] [LOG]   Server started ...
                              [05.01.2022 11:55.27.069] [LOG]   Connecting socket for: Hello-Lucy
                              [05.01.2022 11:55.27.071] [LOG]   Starting module helper: Hello-Lucy
                              [05.01.2022 11:55.27.073] [LOG]   Sockets connected & modules started ...
                              [05.01.2022 11:55.27.482] [LOG]   Launching application.
                              [05.01.2022 11:55.37.133] [LOG]   Hello-Lucy has recognized: ALL IS THE
                              [05.01.2022 11:56.16.829] [LOG]   Hello-Lucy has recognized: NINE
                                sinbad339
                                The difference is how MM is started. If I do it the manual way, the microphone works (with or without debug enabled). If MM does its normal autostart, using mm.sh that includes DISPLAY=:0 npm start, then the microphone doesn’t work.
                                  sdetweil @sinbad339
                                  how is that done? pm2 or did u do some other setup
                                  sounds like mm is not running as user but as root?
                                    sinbad339 @sdetweil
                                    I followed the instructions from https://www.magicmirrorcentral.com/complete-raspberry-pi-magic-mirror-tutorial/.
                                    It included
                                    type in the following command:
                                    pm2 startup
                                    A different command will appear. Run that command also.
                                    Now create a shell script for startup. Open up the built-in text editor on the Pi by typing in:
                                    cd ~
                                    nano mm.sh
                                    The lower line basically means, “open up a file called mm.sh in the nano text editor.”
                                    When the text editor has opened, add this to the mm.sh file:
                                    Make your shiny new script executable by typing in:
                                    chmod +x mm.sh
                                    Now start up Magic Mirror and make it start up on boot:
                                    pm2 start mm.sh
                                    pm2 save
                                    Now, reboot your Pi by typing in
                                    sudo reboot
                                      sdetweil @sinbad339
                                      @sinbad339 hm… my install script does all that.
                                      mm.sh already exists in the installers folder.
                                      try my fixuppm2.sh from here
                                        sinbad339 @sdetweil
                                        Let me start by saying I really appreciate your help with this. You’ve given me a lot of your time, and clearly I couldn’t have made any progress without you. Thank you.
                                        Running your fixupppm2 script fixes the microphone on a restart, but then there is no speaker output. If I stop MM, then manually restart it with npm start, the mic and speaker work fine, as before the fixup.
                                          sdetweil @sinbad339
                                          @sinbad339 that makes no sense to me.
                                          could u start it w pm2, and then ps -ef >somefile.txt
                                          and email me thevfile some file.txt
                                          same userid as here at gmail.
                                          I want to see if there is some permissions problem
                                          oh, check the file contents to make sure no userid or password is exposed. shouldn’t be but u never know.
                                            sinbad339 @sdetweil
                                            Just sent it…
