    New weather module (weather forecast)
    1 Posts 1 Posters 1.2k Views 2 Watching
    • O Offline
      OberfragGER
      I changed the default weatherforecast to weather like described in the official docu. It didnt load the forecast.
      What can i change?
      My config.js:
            module: 'weather',
            position: 'top_right',
            header: 'Wetter Vorhersage für',
      		type: 'forecast',
              locationID: '2945498',
              appid: '9401ca284xxxxxxxx48a208ac'
      This seems to be the error:
      0|MagicMir | [13.01.2022 13:42.39.124] [ERROR] MagicMirror will not quit, but it        might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [13.01.2022 13:42.39.124] [ERROR] If you think this really is an is        sue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/iss        ues
      0|MagicMir | [13.01.2022 13:42.39.128] [ERROR] Whoops! There was an uncaught exc        eption...
      0|MagicMir | [13.01.2022 13:42.39.129] [ERROR] TypeError: Cannot read properties        of undefined (reading 'type')
      0|MagicMir |     at Timeout.fetchStandings [as _onTimeout] (/home/pi/MagicMirror        /modules/MMM-Formula1/node_helper.js:48:57)
      0|MagicMir |     at listOnTimeout (node:internal/timers:557:17)
      0|MagicMir |     at processTimers (node:internal/timers:500:7)
      0|MagicMir | [13.01.2022 13:42.39.129] [ERROR] MagicMirror will not quit, but it        might be a good idea to check why this happened. Maybe no internet connection?
      0|MagicMir | [13.01.2022 13:42.39.130] [ERROR] If you think this really is an is        sue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/iss        ues
      0|MagicMir | [1293:0113/134506.677270:ERROR:command_buffer_proxy_impl.cc(292)] G        PU state invalid after WaitForTokenInRange.
      0|MagicMir | [940:0113/134507.415223:ERROR:gpu_process_host.cc(968)] GPU process        exited unexpectedly: exit_code=139
      0|MagicMir | [1293:0113/135506.957531:ERROR:command_buffer_proxy_impl.cc(292)] G        PU state invalid after WaitForTokenInRange.
      0|MagicMir | [940:0113/135507.713471:ERROR:gpu_process_host.cc(968)] GPU process        exited unexpectedly: exit_code=139
      0|MagicMir | [1293:0113/140025.310512:ERROR:command_buffer_proxy_impl.cc(292)] G        PU state invalid after WaitForTokenInRange.
      0|MagicMir | [940:0113/140028.204170:ERROR:gpu_process_host.cc(968)] GPU process        exited unexpectedly: exit_code=139
