    MM Config check goes bad
    14 Posts 2 Posters 4.8k Views 2 Watching
      sdetweil @HALPi-Thousand
      @halpi-thousand what position is it configured for? I don’t see it on screen.
      • H Offline
        HALPi-Thousand @sdetweil
        @sdetweil said in MM Config check goes bad:
        Exactly the problem, it doesn’t show up. It’s set up for upper left, last in line so it should be below the holidays and above the Earth. I copy/pasted right from your page instructions, and I kept an eye out for that bit with the missing bracket error I made in that other thing, so I figure it should be happy. Except for some reason it isn’t. I have no idea what it could be.
          @halpi-thousand you did the npm install in the module folder, right?
          can u look at where u start mm
          npm start or
          if pm2, then
          pm2 logs–lines=50
          • H Offline
            Well, whatever I did, it worked enough to get the message about the QR code where it should be. Now to see if I can actually get the webpage to behave as well.
