    MM Config check goes bad
    14 Posts 2 Posters 5.7k Views 2 Watching
      sdetweil @HALPi-Thousand
      @halpi-thousand said in MM Config check goes bad:
        	module: 'MMM-BinaryClock',
        	position:"lower_third",
      this is missing a } for the config: {
      H 1 Reply Last reply Reply Quote 1
      • H Offline
        HALPi-Thousand @sdetweil
        That helps, thanks.
        Why doesn’t Geany tell me these things? Granted, I’m only getting started learning about this, and maybe I missed something somewhere but I would think that at least for little stuff - missing parentheses and so forth - it could manage to tell me what’s missing.
        Or is it that it probably did, and I just didn’t notice?
          Geany
          it did report, that somewhere further down it lost the structure
          deducing where it was caused is a fun time project.
          I wrote a module for this kind of problem, that presents a form. no more config editing
          funny it’s called MMM-Config!
          https://github.com/sdetweil/MMM-Config
          • H Offline
            @sdetweil said in MM Config check goes bad:
            Geany
            :astonished_face: And just like that, you’re my new best MagicMirror friend - I’ve been wanting something like this to make working on this stuff easier. Love this idea. Looks like it should be a fair bit more Newb-friendly than fiddling around in the config file tends to be.
            One thing: it apparently requires the Pi IP address and Port ID. The IP address wasn’t a problem, but I don’t know where or what to look for to get the Port ID. Or did I just miss something somewhere?
            Thanks again
              @halpi-thousand if you use showQR:true
              then there will be a qr code to use from outside
              the default port on mm is 8080
              the doc (readme.md) says what link to use if not using the qr code
              • H Offline
                Right, the link where you substitute the IP and Port for that one part
                http://MM_IP_Address:MM_Port/modules/MMM-Config/review
                I tried the Pi’s IP and Port 8080, and got this error:
                Unable to connect
                Firefox can’t establish a connection to the server
                at 192.168.1.13:8080.
                The site could be temporarily unavailable or
                too busy. Try again in a few moments.
                If you are unable to load any pages, check
                your computer’s network connection.
                • If your computer or network is protected by
                a firewall or proxy, make sure that Firefox is
                permitted to access the Web.
                I also tried adding in that ShowQR: true line; it didn’t give me a QR.
                Any ideas where I might be getting it wrong?
                  @halpi-thousand if the mm config says
                  address:“localhost”,
                  the Only apps INSIDE the pi can connect
                  if u want to connect from outside the pi (phone, tablet, ??? )
                  then u have to change address and ipWhitelist
                  to allow outside machines anto connect
                  it’s showQR not ShowQR
                  case matters in MagicMirror, everywhere
                  • H Offline
                    I checked, and it’s set up as localhost. That shouldn’t be a problem, this one isn’t headless. Two displays and a wireless keyboard/trackpad.
                    Also, showQR is correct spelling and case.
                      @halpi-thousand what position is it configured for? I don’t see it on screen.
                      • H Offline
                        Exactly the problem, it doesn’t show up. It’s set up for upper left, last in line so it should be below the holidays and above the Earth. I copy/pasted right from your page instructions, and I kept an eye out for that bit with the missing bracket error I made in that other thing, so I figure it should be happy. Except for some reason it isn’t. I have no idea what it could be.
                          @halpi-thousand you did the npm install in the module folder, right?
                          can u look at where u start mm
                          npm start or
                          if pm2, then
                          pm2 logs–lines=50
                          • H Offline
                            Well, whatever I did, it worked enough to get the message about the QR code where it should be. Now to see if I can actually get the webpage to behave as well.
