    MM Config check goes bad
    14 Posts 2 Posters 4.9k Views 2 Watching
    • H Offline
      HALPi-Thousand
      So, I wanted to get rid of the compliments module. I don’t mind a respectful computer, but I don’t care for the obsequious toadying and so forth. And I wanted to take a swing at adding modules.
      So, I went with MMM-BinaryClock. Simple, nothing too weird, what could possibly go wrong, right?
      Blank screens on MM, that’s what. I ran npm run config:check like it said I should. This is what it said:
      Your configuration file contains syntax errors :(
      [30.01.2022 14:11.12.180] [ERROR] Line 71 column 3: Parsing error: Unexpected token {
      I guess by column 3 it means the third tab out.
      Thing is, that’s exactly where it was with the compliments thing.
      Here’s what it was:
      	url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: "weather",
      Here it is after I changed it:
      			module: 'MMM-BinaryClock',
      			position:"lower_third",
      			module: "weather",
      I don’t see any difference between the two starts and ends. It has the same number of tab spaces as the previous one. I don’t see what the problem is. Granted, I don’t know a whole lot about this stuff.
      Here’s what the page wants:
      var config = {
                  position:"top_left",
      Obviously, a bit of a difference, but since in mine it isn’t the first one at the top, I didn’t figure that leaving out the stuff from the beginning should be a problem.
      So, any ideas on what the problem might be? I really don’t want to go through this every time I ad a module, because there are a few I;'ve got my eye on.
        sdetweil @HALPi-Thousand
        @halpi-thousand typically the error is reported on the line AFTER the actual error line
        unexpected token means 95% of the time, the line before should end with a comma, but does not
        see the two topics in my signature
          @halpi-thousand said in MM Config check goes bad:
          this is missing a } for the config: {
          H 1 Reply Last reply Reply Quote 1
          • H Offline
            HALPi-Thousand @sdetweil
            That helps, thanks.
            Why doesn’t Geany tell me these things? Granted, I’m only getting started learning about this, and maybe I missed something somewhere but I would think that at least for little stuff - missing parentheses and so forth - it could manage to tell me what’s missing.
            Or is it that it probably did, and I just didn’t notice?
              Geany
              it did report, that somewhere further down it lost the structure
              deducing where it was caused is a fun time project.
              I wrote a module for this kind of problem, that presents a form. no more config editing
              funny it’s called MMM-Config!
              https://github.com/sdetweil/MMM-Config
              • H Offline
                @sdetweil said in MM Config check goes bad:
                Geany
                :astonished_face: And just like that, you’re my new best MagicMirror friend - I’ve been wanting something like this to make working on this stuff easier. Love this idea. Looks like it should be a fair bit more Newb-friendly than fiddling around in the config file tends to be.
                One thing: it apparently requires the Pi IP address and Port ID. The IP address wasn’t a problem, but I don’t know where or what to look for to get the Port ID. Or did I just miss something somewhere?
                Thanks again
                  @halpi-thousand if you use showQR:true
                  then there will be a qr code to use from outside
                  the default port on mm is 8080
                  the doc (readme.md) says what link to use if not using the qr code
                  • H Offline
                    Right, the link where you substitute the IP and Port for that one part
                    http://MM_IP_Address:MM_Port/modules/MMM-Config/review
                    I tried the Pi’s IP and Port 8080, and got this error:
                    Unable to connect
                    Firefox can’t establish a connection to the server
                    at 192.168.1.13:8080.
                    The site could be temporarily unavailable or
                    too busy. Try again in a few moments.
                    If you are unable to load any pages, check
                    your computer’s network connection.
                    • If your computer or network is protected by
                    a firewall or proxy, make sure that Firefox is
                    permitted to access the Web.
                    I also tried adding in that ShowQR: true line; it didn’t give me a QR.
                    Any ideas where I might be getting it wrong?
                      @halpi-thousand if the mm config says
                      address:“localhost”,
                      the Only apps INSIDE the pi can connect
                      if u want to connect from outside the pi (phone, tablet, ??? )
                      then u have to change address and ipWhitelist
                      to allow outside machines anto connect
                      it’s showQR not ShowQR
                      case matters in MagicMirror, everywhere
                      • H Offline
                        I checked, and it’s set up as localhost. That shouldn’t be a problem, this one isn’t headless. Two displays and a wireless keyboard/trackpad.
                        Also, showQR is correct spelling and case.
