nest-status access token
17 Posts 4 Posters 3.6k Views 4 Watching
  • T Offline
    tanvir586
    Hi guys I’m having a new problem, it freeze after couple of hours. If I restart my magicmirror then it works fine then again after few hours it freeze again. Any solution?
    X 1 Reply Last reply Mar 12, 2022, 10:05 PM Reply Quote 0
    • X Offline
      xadamxk @tanvir586
      @tanvir586 Does your entire mirror freeze or just the module? When you say freeze, does the screen turn black or does every module just stop updating?
      T 1 Reply Last reply Mar 12, 2022, 10:42 PM Reply Quote 0
      • T Offline
        tanvir586 @xadamxk
        @xadamxk … just my nest module. Everything else working fine.
        • X Offline
          xadamxk
          @tanvir586 Hard to say what the problem might be without having access to your device. If you read the console output of the magic mirror, or run in server only mode, you might be able to read the logs for any errors associated with the module.
          T 1 Reply Last reply Mar 13, 2022, 1:41 PM Reply Quote 0
          • T Offline
            tanvir586 @xadamxk
            @xadamxk this is my error log…
            [13.03.2022 13:12.50.413] [ERROR] Whoops! There was an uncaught exception…
            [13.03.2022 13:12.50.431] [ERROR] TypeError: Cannot read properties of undefined (reading ‘statusCode’)
            at Request._callback (/home/pi/MagicMirror/modules/mmm-nest-status/node_helper.js:16:22)
            at self.callback (/home/pi/node_modules/request/request.js:185:22)
            at Request.emit (node:events:394:28)
            at Request.onRequestError (/home/pi/node_modules/request/request.js:877:8)
            at ClientRequest.emit (node:events:394:28)
            at TLSSocket.socketErrorListener (node:_http_client:447:9)
            at TLSSocket.emit (node:events:394:28)
            at emitErrorNT (node:internal/streams/destroy:157:8)
            at emitErrorCloseNT (node:internal/streams/destroy:122:3)
            at processTicksAndRejections (node:internal/process/task_queues:83:21)
            [13.03.2022 13:12.50.438] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [13.03.2022 13:12.50.439] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            X 1 Reply Last reply Apr 10, 2022, 9:37 PM Reply Quote 0
            • X Offline
              xadamxk @tanvir586
              @tanvir586 Apologies for the late reply, I think the notification of your reply was eaten.
              https://github.com/michael5r/mmm-nest-status/blob/master/node_helper.js#L18
              Looks like the response from the API isn’t returning the expected response. There are several things it could be but it’s hard to know for sure. If you open your configuration file, do you have a custom updateInterval set? If not, add this:
              "updateInterval": 240000
              This will change the update interval from 2 to 4 minutes, which might help your issue. Give this a try and let me know if it works better for you.
              T 1 Reply Last reply Apr 11, 2022, 10:38 PM Reply Quote 0
              • T Offline
                tanvir586 @xadamxk
                @xadamxk Hi mate thanks for replying. Im using module refresher now and it refresh my module every few hours. I don’t see any errors after start using it.
