    New Weather Module - Migration
    Scheduled Pinned Locked Moved Forum
    19 Posts 4 Posters 4.7k Views 4 Watching
    • C Offline
      Canguingo @sdetweil
      @sdetweil said in New Weather Module - Migration:
      @Canguingo you are just changing the label of the apikey value in config.js
      this is how my config.js looks like
      module: “weather”,
      disabled: false, //false, true
      position: “top_right”,
      header: “Weervoorspelling”,
      type: “forecast”,
      locationID: “454545”, //id my location
      apiKey: “abcde12345abcde12345abcde12345ab” //this is the old appi that i had
      so i need a new apiKey or with the old one is ok?
      S D 2 Replies Last reply Reply Quote 0
        sdetweil @Canguingo
        @Canguingo well, there are more new parms…
        provider
        and type (as they collapsed current and forecast into the same module now)
        see https://docs.magicmirror.builders/modules/weather.html#configuration-options
        C 2 Replies Last reply Reply Quote 0
        • C Offline
          Canguingo @sdetweil
          provider
          so what do i have to do?
            sdetweil @Canguingo
            @Canguingo i dpn’t know exactly… read the doc and check to see if you have all the required parms…
            • C Offline
              Canguingo @sdetweil
              provider
              my question is: Do I need a new apiKey or with the value of the old appi is enough?
              if you don’t know the answer or don’t know how to explain it, I thank you a lot, but please leave space for someone who actually can help.
              thank in advance.
              JerryPJ 1 Reply Last reply Reply Quote 0
              • JerryPJ Offline
                JerryP @Canguingo
                @Canguingo
                I’dint use a new key. The old one was working fine.
                After I update the Mirror to 2.19 and change the config.
                  DarrenHill @Canguingo
                  @Canguingo said in New Weather Module - Migration:
                  Is that really your actual key, or did you just put that as a redaction of your actual key?
                  Just to ask a basic question, as that doesn’t look like a valid key to me.
                  As the others have noted, all you should need to do is change the module name and swap the key label from appid: to apiKey: , The key value itself is valid for both.
                  D C 2 Replies Last reply Reply Quote 0
                    DarrenHill @DarrenHill
                    For reference, this is one of the entries in my config.js (I use the module twice, once for now and once for forecast):
                                module: "weather",
                                    type: "current",
                                    locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                    apiKey: "#####f59935f34cea0bf3c1aa82#####",
                                    units: "metric",
                                    degreeLabel: true,
                                    showHumidity: true,
                                    tableClass: "medium"
                    Where the #'s in the apiKey are actually other letters and numbers (full key redacted).
                    • C Offline
                      Canguingo @DarrenHill
                      @DarrenHill said in New Weather Module - Migration:
                      Many thanks Darren,
                      That’s a dummy key not the real one. I managed to get it running.
                      The issue was (for the record):
                      Mistaken “apiKey” for “appi”
                      Missing ‘currentweather’ part which has also been replaced by the new module. So the code was wrong and missing a calling a module that does not exist anymore.
                      Again many thanks!!
