    Default Calendar Module - Repeating calendar events with exceptions do not show
    3 Posts 2 Posters 874 Views 2 Watching
    • P Offline
      p1lspeda
      Platform: Raspberry Pi 3B+
      Node Version [ 0.12.13 or later ]:
      node -v v16.14.2
      MagicMirror Version [ V1 / V2-Beta ]: latest
      Description: Our recycling bin is emptied every 2 weeks. I can download an iCalendar (https://eb-mainz.de/wir-kommen-zu-ihnen/abfallkalender). Either as a list of single dates “Apple Kalender und alle anderen Kalenderprogramme mit Einzelterminen."
      or as recurring dates "MS Outlook, Google Kalender etc. mit Terminserien (nicht für Apple Kalender)”*
      I download the second (recurring dates) and import the file into an extra google calendar. This google calendar is displayed on my MagicMirror.
      Most dates show up fine, except for predefined exceptions within the downloaded ICS-file.
      Google Calendar handles the exceptions just fine (my phone, webbrowser etc show the pick-up dates as intended). My MM however seems to ignore the exceptions.
      For example:
      Wednesday 20.04.2022 would have been a regular, bi-weekly pickup date for the recycling bin, as Monday, 18.04.2022 was Easter-Monday (and a public holiday in Germany), the pickup date was changed to Thursday 21.04.2022.
      All my devices (except MM) showed Thursday, 21.04.2022 as the pick-up day. MM insisted is was Wednesday, 20.04.2022.
      The downloaded ICS-File contains the following:
      BEGIN:VCALENDAR
      PRODID:-//Grafik-Partner GmbH//Muellmax 7.0 MIMEDIR//EN
      VERSION:2.0
      METHOD:PUBLISH
      BEGIN:VEVENT
      DTSTART;VALUE=DATE:20220112
      DTEND;VALUE=DATE:20220113
      DESCRIPTION:Entsorgungsbetrieb der Stadt Mainz\n
      	Zwerchallee 24\n
      	55120 Mainz\n
      	\n
      	Telefon: +49 6131 12 34 56 (Abfallberatung)\n
      	Telefax: +49 6131 12 34 83\n
      	\n
      	Der Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt Mainz.
      RRULE:FREQ=WEEKLY;UNTIL=20230101T000000Z;
       INTERVAL=2;BYDAY=WE;WKST=MO
      RDATE;VALUE=DATE:
       20220421,
       20221006,
       20221103,
       20221229
      EXDATE;VALUE=DATE:
       **20220420**, <-- this the exception I'm talking about
       20221005,
       20221102,
       20221228
      TRANSP:TRANSPARENT
      SEQUENCE:0
      UID:16413062851@muellmax.de
      DTSTAMP:20220104T142445Z
      SUMMARY:EB Gelber Sack
      CLASS:PUBLIC
      CREATED:20211221T125452Z
      LAST-MODIFIED:20211221T125452Z
      URL:http://www.muellmax.de
      END:VEVENT
      END:VCALENDAR
      Steps to Reproduce:
      1. Download a calendar containing the pick-up dates from https://eb-mainz.de/wir-kommen-zu-ihnen/abfallkalender
        1.1) choose "MS Outlook, Google Kalender etc. mit Terminserien (nicht für Apple Kalender)"*
      2. Import it into google calendar as a seperate calendar
      3. Import this calendar into MM with default calendar module
      Expected Results:
      Identical entries in google calendar and MM
      Actual Results:
      MM doesn’t take exceptions, defined within the ICS-File into consideration
      Configuration:
                                      colored: false,
                                      coloredSymbolOnly: false,
                                      maximumEntries: 15,
                                                      url: 'xxx',
                                                      symbol: 'calendar', // BUNDESLIGA
                                                      url: 'xxx',
                                                      symbol: 'calendar', // GERMAN HOLIDAYS
                                                      url: 'xxx',
                                                      symbol: 'calendar', // MAIN GOOGLE CALENDAR
                                                      url: 'xxx',
                                                      symbol: 'calendar', // FORMULA 1 CALENDAR
                                                      url: 'https://calendar.google.com/calendar/ical/[thisisnoneofyourbusiness]group.calendar.google.com/private-[thisisnoneofyourbusiness]>
                                                      symbol: 'calendar', // EB MAINZ
                                                      url: 'xxx'
                                                      symbol: 'calendar', // PRO RUNDE
                                                      url: 'xxx'
                                                      symbol: 'calendar', // BUSINESS TRIPS
      Additional Notes:
      A simple workaround is to just download the calendar with single entries
      “Apple Kalender und alle anderen Kalenderprogramme mit Einzelterminen.” and import that one into google-calendar. That works perfectly. Nevertheless it seems as if the default MM-calendar module (and MMM-CalendarExt2 for that matter, same issue) can’t handle exceptions within ics-calendars with repeating entries.
      Hope this helps. It’s not a deal-breaker, just something I have noticed.
        sdetweil @p1lspeda
        @p1lspeda we use a library, node-ical, to parse the ics and present dates that fit within the next year based on the ics rules.
        • P Offline
          p1lspeda
          thanks for your reply.
          It seems node-ical has an issue with parsing EXDATE Info within the ICS file.
          https://github.com/jens-maus/node-ical/issues/167
          He has the same problem.
