    working module Raspberry Pi 4 and PIR?
    Scheduled Pinned Locked Moved Forum
    13 Posts 8 Posters 5.2k Views 8 Watching
      DariBer @hpgraphia
      @hpgraphia
      how does your config.js file look like for that module?
      Would you be kind and show it?
      • E Offline
        eracerhead
        I’ve done this by putting a relay directly in the backlight circuit. Connect the PIR to 5V and a gpio pin, and the relay to 5V and another GPIO pin. Use wiring pi and a simple bash script to get the state of the PIR and energize/de-energize the relay appropriately. It’s really simpler than it sounds and requires little to no knowledge of electronics.
        You need to first install wiring-pi
        sudo wget https://project-downloads.drogon.net/wiringpi-latest.deb
        sudo dpkg -i wiringpi-latest.deb
        Here’t the script I run at startup to control it - works great.
        #!/bin/bash
        # Runs in the background to switch backlight on or off
        # depending upon the state of the PIR motion sensor.
        # Usage: nohup backlightd [-r|-f] 0<&- &>/dev/null &
        # 	-r log on loghost
        #	-f log locally (default)
        # Set as configured
        PIR=18		# GPIO BCM number of PIR sensor
        BACKL=15	# GPIO BCM number of backlight relay
        OFF_DEL=60	# Minimum number of seconds to keep backlight om
        ON_DEL=2	# Minimum number of seconds to keep backlight off
        TIMO=3600	# Maximum number of seconds to wait for edge event
        # Set for local policies
        PRIO=local.info 		# if using rsyslog set priority
        TAG=backlightd			# and tag to use on loghost
        LOGFILE=/var/log/backlightd.log	# if using local syslog file
        PATH=/bin:/usr/bin
        # error handling
        xit() { rlog "Line $1 Err $2 - $3  - exiting"; exit "$2"; }
        die() { rlog "Exit signal received - exiting"; exit 0; }
        # logging
        case $1 in
        	-r) rlog() { /usr/bin/logger -p "${PRIO}" -t "${TAG}" "$1"; } ;;
        	 *) rlog() { /bin/echo "$1" >>"${LOGFILE}" ; } ;;
        esac
        cd / || xit $LINENO $? "Cannot cd to / ?!?"
        reset(){
        	# reset gpio pins, set initial conditions
        	gpio edge "$PIR" both \
        		|| xit $LINENO $? "Cannot set edge GPIO$PIR"
        	gpio export "$BACKL" out \
        		|| xit $LINENO $? "Cannot set export GPIO$BACKL"
        	PIR_STATE=$(gpio -g read "$PIR") \
        		|| xit $LINENO $? "Cannot read GPIO$PIR"
        	gpio -g write "$BACKL" "$PIR_STATE" \
        		|| xit $LINENO $? "Cannot write to GPIO$BACKL"
        trap reset SIGUSR1
        trap die   SIGTERM
        reset
        while true
        do
        	timeout "$TIMO" gpio -g wfi "$PIR" both ; STAT=$?
        	if [ "$STAT" -eq 124 ]; then
        		rlog "gpio wfi timed out after ${TIMO}s - respawning"
        		STAT=0
        	fi
        	[ "$STAT" ] || xit $LINENO $STAT "gpio wfi terminated abnormally"
        		|| xit $LINENO $? "Cannot write GPIO$PIR"
        	if [ "$PIR_STATE"  ]
        		then sleep "$ON_DEL"
        		else sleep "$OFF_DEL"
        	fi
        done
        • pugslyP Offline
          pugsly @DariBer
          @DariBer Please see this document… this is how I use my PIR to turn off the screen when no one is in front of it.
          https://www.thedigitalpictureframe.com/pir-motion-sensor-raspberry-pi-digital-picture-frame/
