    Default Calendar
    6 Posts 2 Posters 1.1k Views 2 Watching
    • plainbrokeP Offline
      plainbroke
      I have not changed anything, no upgrades ect.
      This is the public Holiday calendar I use. url: “https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics”,
      I am getting the nothing to show message.
      My private calendar which gets me a ics file download when I paste it in a browser is not showing up either. I ssh into and vnc this pi4 8gb. The only thing that changed was I had a power supply failing (causing the lightning bolt to show up.) So I replaced that with a new 3.5 amp power supply.
      Everthing was fine for a couple days and then all the sudden no more calendars. Is this to do with Google forcing 2 stage authentication on everyone? I had to get a special password for my gmail to show up. Wondering if this is the same type issue? If so how do I put in a username and password in my config.js for the calendars? Dad blasted Google needs to leave well enough alone… :angry_face:
        plainbroke @plainbroke
        Well I bit the bullet and reinstalled MM and all my modules. I use the MM-buckup module, it does a really good job of reinstalling all the different modules I have installed. I just have to copy over the modules from backup that I have multiples of… So far everything is working as it should except CalendarExt3 …
        The default calendar is broadcasting CalendarExt3 just is not listing evidently…
        That and I still need to resize openweather…
          sdetweil @plainbroke
          @plainbroke yes 2 stage auth messes things up. u have to get a different url
          plainbrokeP 1 Reply Last reply Reply Quote 0
            plainbroke @sdetweil
            Please expand on the new URL. I went to my google account and regenerated a new private url but not sure how to do that on a public url like the holidays one.
            Is there a way to put in the username and new password like in gmail that I am overlooking?
              @plainbroke the generated url is different after you turn on 2 factor as I recall, for both public and secret ics links
                Thanks for the clarification, I will go back and make sure I have the 2 part verification turned on and try it again…
                Thank You
