    Electricity Bill Module Development
    19 Posts 3 Posters 5.6k Views 3 Watching
      SopaMaruchan
      Hi there!
      I’m developing a new module for a Magic Mirror to display Electricity Bill data but I’m struggling with something. The thing is that I consume an API which requires Bearer Token as an authentication to retrieve the data. I handle it using a node_helper file, but the thing is that I only get to display the data on the console but not visually on screen: 3001fe30-5cfb-4a4a-923e-f6c58e949e3e-image.png
      How can I send that data from node_helper to my MMM-CFE and place it on a meter element?
      MMM-CFE:
      node_helper:
      Thought of socketNotification but I couldn’t figure it out, any ideas?
        sdetweil @SopaMaruchan
        @SopaMaruchan get data from API
        let’s call the object foo
        then
        this.sendSocketNotification(“fribble”, foo)
        then on the module side
          receiveSocketNotification(code, data){
                  if(code === 'fribble'){
                         this.savePointer = data
                         this.updateDom()
        then
              getDom(){
                       //  use  this.savePonter
          SopaMaruchan @sdetweil
          @sdetweil I named my retreived data as “foo” and then used sendSocketNotification as you previously told me but I got this as output:
          I did it this way on my node_helper file (Highlighted the lines I added):
          Did I missed anything?
          S 2 Replies Last reply
            @SopaMaruchan ah, so much fun!
            you are inside the callback of the request,so ‘this’ I pointing to some request object and not the node_helper instance…
            sooooo
            before request(…
            add
            let self = this
            and change this. to self.
            object oriented programming is tricky
              @SopaMaruchan and {foo} is unnecessary
              you could just use
              res.body
              it’s the same stuff, why waste memory w a new pointer only being used once
              (same w info there too)
                @sdetweil Hahahaha true that!
                Kinda fixed it guided by your recommendations but the thing is that I’m still getting the same output: 098fca99-2a82-4ccd-8758-b81dcaedc3b6-image.png
                Here the code:
                  @SopaMaruchan hm…
                  sample from one of my modules
                  self.sendSocketNotification("SLEEP_HIDE")
                    hmm, actually it does help. I’ll be testing around and tell you when I get it to work!
                    Anyways your help was a huge pilar to keep myself going with this, much thanks brother💝
                      SopaMaruchan @SopaMaruchan
                      Does it help if I tell you that I got everything on my onstart function of the node_helper file?
                      S S 2 Replies Last reply
                        @SopaMaruchan never done it in start.
                        I usually wait til the module sends it’s 1st request
                          @SopaMaruchan I’m realizing that my my receiveSocketNotification is not being triggered on my MM-Module file:
                          I logged some text after calling receiveSocketNotification function but there’s no output on console.
                          node_helper:
                          S mumblebajM 4 Replies Last reply
                            @SopaMaruchan if the send fails like that, not sent
                              @SopaMaruchan
                              let self=this
                              has to be inside the getBill() function
                              otherwise it could be set wrong…
                                @SopaMaruchan maybe for debug
                                inside the request() callback function,
                                do a
                                console.log(JSON.stringify(self, null,2))
                                to see what ‘this’ was pointing to
                                  @sdetweil it’s indeed pointing to my module. Here’s the output: 55021cd9-1c10-46c3-8a9d-5de1e97674a1-image.png
                                  and the huge LOG ends with the last 2 arguments: null & 2 e2503443-14c0-45ad-9614-37a9392997c0-image.png
                                    @SopaMaruchan
                                    problem is that the sockets are not connected at start time. so the sendSocketNotification is a no-op.
                                    u need wait til the module sends a socket message
                                    the module config is not visible to the node_helper, so the module has to send it over/down…
                                    • mumblebajM
                                      mumblebaj Module Developer @SopaMaruchan
                                      @SopaMaruchan Maybe the below example would help or serve as a guide to see if you may have the send call in the wrong place.
                                      module.exports = NodeHelper.create ({
                                          start: function() {
                                              console.log('Starting node_helper for module: ' + this.name)
                                          getLights: async function(payload) {
                                              var url = "http://" + payload.bridgeip + "/api/" + payload.userid + "/" + payload.lightsOrGroups;
                                              var response = await fetch(url)
                                              if (!response.status == 200) {
                                                  console.error(`Error retrieving data: ${response.statusCode} ${response.statusText}`)
                                                  return;
                                              var result = await response.json()
                                              this.sendSocketNotification("lightsorgroups", result)
                                        sdetweil @mumblebaj
                                        @mumblebaj he is calling from start:
                                        but sockets not setup yet.
                                        he really needs to wait til the module sends the 1st notification down ( what we use to send config info from module to helper)
                                        mumblebajM 1 Reply Last reply
                                        • mumblebajM
                                          mumblebaj Module Developer @sdetweil
                                          @sdetweil Ah, hopefully he caught that and changes it.
