    MMM-WiFiPassword
    8 Posts 2 Posters 2.0k Views 2 Watching
      Anthony Project Sponsor
      Hello everyone. I hope you are all well. I have a problem with the MMM-WiFiPassword module. I installed it but it does not seem to work. When I am scanning the QR code nothing happens. I have also change my password so is does not have any special cahracters as the author recomends but still nothing. I hope someone can help me with this. Here is my config:
            module: 'MMM-WiFiPassword',
            position: "top_center",
                //See 'Configuration options' for more information.
                header: "WiFi",
                network: "VODAFONE_7402",
                password: "***********",
                showNetwork: true, // Display network name
                showPassword: false, // Display password
                showAuthType: false,
      Also after playing around with my custom.css for exact positioning I noticed a very big delay on the MM start up. It takes more than 1 minute with black screen and more than 2 minutes to load all modules. I know that probably it has nothing to do with my custom.css but it happened after I changed some things to figure out the desired position of the module. If anyone has any idea what is causing this delay please share it. Thank you in advance.
        sdetweil @Anthony
        @Anthony don’t know, but for debugging, if u set the showxxx parns to true, do they show?
        then try different positions
          Anthony Project Sponsor @sdetweil
          @sdetweil I don’t think it work. I set debug to true and after restart I did not find any debug log and beside that my network name and my password was shown below the module. I don’t know. Maybe I will try uninstall it and reinstall it and see how it goes. Thank you for your answer though.
            sdetweil @Anthony
            @Anthony so the network name and password showed…
            that means the module executed
            don’t know if it has debug:true support
            did u try moving to a different position?
              @sdetweil In fact I just did and 2 minutes now I have black screen
              S A 2 Replies Last reply Reply Quote 0
                sdetweil @Anthony
                @Anthony whatever you changed, change back…
                  Anthony Project Sponsor @Anthony
                  @sdetweil it has debug:true support. Here is the original js cinfig file
                  Module.register("MMM-WiFiPassword", {
                    defaults: {
                  	  qrSize: 125,
                  	  colorDark: "#000",
                  	  colorLight: "#fff",
                  	  authType: "WPA", // WEP, WPA, NONE
                  	  network: "REQUIRED", // Your Network ID
                  	  password: "REQUIRED", // Your Network Password
                  	  header: "Local WiFi Details", // Default heading
                  	  hiddenId: false, // Whether your Network ID is hidden
                  	  layoutVertical: true, // Whether to display in vertical (true), or horizontal (false) mode.
                  	  showPassword: true, // Display password
                  	  showAuthType: true, // Dispay authentication type
                  	  debug: false
                  I know it reads my network and password right because if i copy paste them after scan to a notebook the text is correct. I even tried to change the scan application but same result. When I choose to connect to the scaned network nothing happens.
                    @sdetweil I manage to change its position from top_center to botom_right but same result again
