    Screen turning off
    16 Posts 3 Posters 4.7k Views 3 Watching
      sdetweil @N6NG
      @N6NG no need for external if you use pir
      mode is hide( hides all modules or shows all modules.) doesn’t turn off monitor
      • BKeyportB Online
        BKeyport Module Developer @N6NG
        @N6NG the trick is to keep the monitor active enough to fool it into not triggering it’s eco feature.
        • N6NGN Offline
          N6NG
          @BKeyport and how would you do that?
          N6NGN 1 Reply Last reply Reply Quote 0
          • N6NGN Offline
            N6NG @N6NG
            @N6NG I get an error from the line that looks like this.
            on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
            which is line 47 which shows this error.
            [ERROR] Line 47 column 19: Parsing error: Unexpected token /
            That’s the / in front of the home/pi/MagicMirror…
            Can’t see why that would be a problem.
              sdetweil @N6NG
              @N6NG you are not using a camera, so u don’t need that
              the PIR module should signal user_presence, true
              and then sleep wake will show the modules ,
              user_presence, false, plus the timeout will hide the modules
              • N6NGN Offline
                N6NG @sdetweil
                @sdetweil Thanks Sam… I’ll give it a try…
