    SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
    8 Posts 2 Posters 13.7k Views 2 Watching
    • L
      lif
      I am running MM on a Raspberry Pi 4
      with the following modules running
      MMM-Tools
      MMM-CurrencyE£xchange
      MMM-Flights
      weatherforecast
      weather
      clock
      calendar
      currentweather
      alert
      MM hangs anything from 1 day to a week or so of running and the only error I can find in the log is:
      0|mm | [14945:0820/131715.652433:ERROR:shared_image_manager.cc(228)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
      0|mm | [14945:0820/131715.713158:ERROR:shared_image_manager.cc(228)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
      0|mm | [14945:0820/131715.731016:ERROR:shared_image_manager.cc(228)] SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.
      0|mm | [20.08.2022 13:19.08.245] [INFO]
      Anyone any idea what module could be causing this? and how do I fix it?
      Thanks in advance
        sdetweil @lif
        @lif said in SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.:
        which version of pi are you using, show results of
        uname -a
        a work around do
        cd ~/MagicMirror
        nano package.json
        change the line that looks like this
        		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
        to this
        		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron --disable-gpu js/electron.js",
        ctrl-o
        to save the file
        ctrl-x to exit nano
        and try restarting magicmirror
        • L
          lif @sdetweil
          Thank you very much
          uname -a
          Linux MagicMirror 5.15.32-v8+ #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022 aarch64 GNU/Linux
          a work around do
          cd ~/MagicMirror
          nano package.json
          to this
          ctrl-o
          to save the file
          ctrl-x to exit nano
          Done, I’ll tell you in a week or so if it’s worked :-)
          • L
            lif @lif
            It’s held for 7 days, so thank you very much.
              sdetweil @lif
              @lif
              aarch64 GNU/Linux
              ah 64 bit mode…
              • L
                lif @sdetweil
                @sdetweil said in SharedImageManager::ProduceSkia: Trying to Produce a Skia representation from a non-existent mailbox.:
                @lif
                aarch64 GNU/Linux
                ah 64 bit mode…
                Does that make much of a difference?
                  sdetweil @lif
                  @lif yes… currently 64 bit mode is sketchy in my opinion
                  • L
                    lif @sdetweil
                    OK
                    • J johndeluxe referenced this topic on
