    MMM-News and BBC
    40 Posts 4 Posters 13.1k Views 4 Watching
      sdetweil @DarrenHill
      @DarrenHill said in MMM-News and BBC:
        source: [Object],
      its in there
        DarrenHill @MMRIZE
        @MMRIZE said in MMM-News and BBC:
        @DarrenHill
        Ok, I found something. I don’t know why, but your result has “articles.source.Name” instead of “articles.source.name” that makes this error.
        Anything I can do to overcome that?
        No idea why I’m getting different API returns to you guys…?
          @DarrenHill @MMRIZE
          also doesn’t get ‘content’ or ‘description’, so those will fail too…
            DarrenHill @sdetweil
            I tried to register for a new api key, but when I tried it told me that they don’t support the UK (where I am) so I wonder if that somehow has something to do with it.
            This has obviously changed since I first registered, and given I’m getting some response from the API it is at least partially working, but besides that I have no idea…
            • mumblebajM Offline
              mumblebaj Module Developer @DarrenHill
              @DarrenHill Hi. Apologies for the late reply. I am on a different timezone than the other guys.
              I would suggest using MMM-NewsAPI. The same API key that you are using with MMM-News will work.
                DarrenHill @mumblebaj
                @mumblebaj - Thanks, no need to apologise.
                I tried the other module, and it also doesn’t show anything besides it’s “News” header title.
                The config I tried was:
                            module: "MMM-NewsAPI",
                            header: "News",
                            position: "bottom_center",
                                apiKey : "<my API key>",
                                domains: "bbc.co.uk",
                                language: "en"
                And also I tried replacing the domains: with sources: “bbc-news” and that gave the same results.
                There’s nothing in the logs, aside from confirming that the module is loading (as can be seen from the displayed title too).
                S mumblebajM 3 Replies Last reply Reply Quote 0
                  @DarrenHill from the doc
                  Add DEBUG Handling.
                  Only add debug: true to the config section if you are experiencing issues and require more information to find issues.
                    @DarrenHill domins or sources must be inside the much more complex query section of the config
                    see the doc
                                        query: {
                                                country: "",
                                                category: "",
                                                q: "",
                                                qInTitle: "",
                                                sources: "",
                                                domains: "cnn.com,nytimes.com,news24.com",
                                                excludeDomains: "",
                                                language: ""
                      @DarrenHill MMM-NewsAPI has a whole lot more configs. See below sample.
                                              header: "news",
                                             //  disabled: true,
                                              position: "bottom_bar",
                                              pages: {"sport": "bottom_bar"},
                                                      apiKey: <api-key>,
                                                      type: "horizontal",
                                                      choice: "everything",
                                                      pageSize: 20,
                                                      sortBy: "publishedAt",
                                                      drawInterval: 1000*30,
                                                      templateFile: "template.html",
                                                      fetchInterval: 1000*60*60,
                                                      query: {
                                                              country: "",
                                                              category: "",
                                                              q: "",
                                                              qInTitle: "",
                                                              sources: "",
                                                              excludeDomains: "",
                                                              language: ""
                      D S 2 Replies Last reply Reply Quote 0
                        @mumblebaj - Thanks for the support, and for both modules.
                        Unfortunately that gives me a headline in Spanish (I think) about Apple iPhone 14 with “undefined” below it.
                        I also tried your everything example configs from your GH page and got a similar layout (headline and undefined).
                        I’m beginning to think NewsAPI itself is screwed for me unfortunately, so we may be onto a loser here regardless of module.
                        • 3 / 4
