    Calendar has stopped working
    23 Posts 2 Posters 7.9k Views 2 Watching
      Jonsar
      Calendar has stopped working. Updated to latest version. Have been using Outlook Calendar for a few years with no issues. Calendar is stuck on “Loading…”
      Error messages:
      [2022-09-18 17:35:15.966] [ERROR] No toISOString function in curr.start //Microsoft/Utc:20220930T133000
      [2022-09-18 17:35:15.967] [ERROR] No toISOString function in curr.recurrenceid //Microsoft/Utc:20220930T133000
      [2022-09-18 17:35:15.972] [ERROR] No toISOString function in curr.recurrenceid //Microsoft/Utc:20221001T133000
      [2022-09-18 17:35:17.277] [ERROR] Whoops! There was an uncaught exception…
      [2022-09-18 17:35:17.278] [ERROR] TypeError: event.start.getFullYear is not a function
      at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:285:33
      at Array.forEach (:null:null)
      at Request._callback (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:91:25)
      at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
      at Request.emit (events.js:210:5)
      at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1154:10)
      at Gunzip. (/home/pi/MagicMirror/node_modules/request/request.js:1076:12)
      at Object.onceWrapper (events.js:299:28)
      at Gunzip.emit (events.js:215:7)
      at endReadableNT (_stream_readable.js:1183:12)
      at processTicksAndRejections (internal/process/task_queues.js:80:21)
      Thoughts?
        sdetweil @Jonsar
        @Jonsar how did u update to the latest release?
          Jonsar @sdetweil
          @sdetweil I followed the posted instructions
            Jonsar
              sdetweil @Jonsar
              @Jonsar so, did the git pull succeed?
              do a
              git status
              in the MagicMirror folder
              and
              grep version package.json
                Jonsar @sdetweil
                @sdetweil I reinstalled and I am up to date. The error I get now is could not fetch calendar Error: forbidden. at NodeHelper.checkFetchStatus (/home/pi/MagicMirror/js/node_helper.js:121:9)
                at processTicksAndRejections (node:internal/process/task_queues:96:5)
                  sdetweil @Jonsar
                  @Jonsar if u put the url in a browser, does it download the ics file?
                  there was a forced change to the Google urls for calendars a while back
                    Jonsar @sdetweil
                    @sdetweil No, it doesn’t. It gets stuck on Preparing to download. Is there a workaround?
                    Found this somewhere. Does it help?
                    Bottom line was that the following lines needed to be added into the request.
                    myHttpWebRequestOutlook.UserAgent = “SmileCRM”;
                    myHttpWebRequestOutlook.AuthenticationLevel =System.Net.Security.AuthenticationLevel.None;
                      sdetweil @Jonsar
                      @Jonsar if u can’t download in a normal browser we can’t get it either.
                        Jonsar @sdetweil
                        @sdetweil Sorry. I can with the html version. The error I get now is this:
                        RangeError: Invalid time value
                        at Date.toISOString (:null:null)
                        at /home/pi/MagicMirror/modules/default/calendar/calendarutils.js:314:28
                        at Object.filterEvents (/home/pi/MagicMirror/modules/default/calendar/calendarutils.js:142:24)
                        at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:74:29
                          sdetweil @Jonsar
                          @Jonsar said in Calendar has stopped working:
                          what does that mean? does it download the ics file or not?
                          not view the cal in the web,… that is the embedded version, we need the raw data…
                            sdetweil @Jonsar
                            @Jonsar ok, lets turn on debugging
                            change config.js
                            logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                            to
                            logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
                            then start mm like this
                            cd ~/MagicMirror
                            npm  start >somefile.txt 2>&1
                            wait til the error,
                            ctrl-q to stop MM
                            then edit the somefile.txt
                            error should be at the bottom
                              Jonsar @sdetweil
                              @sdetweil Thanks for all your help.
                              These are the last 4 or so entries. It seems that it’s trying to pick up entries from 2021 and then comes across an old entry that it can’t parse.
                              {“type”:“VEVENT”,“params”:[],“uid”:“040000008200E00074C5B7101A82E0080000000093B227D5977DD701000000000000000010000000E1C248455EE3E241BFC9D2FBFB730A57”,“summary”:“Materials Due - MunichRe - Speaking & Writing Communication Skills”,“start”:$
                              [18.09.2022 22:22.12.572] [DEBUG] start: Tue Sep 21 2021 09:00:00 GMT-0400 (Eastern Daylight Time)
                              [18.09.2022 22:22.12.573] [DEBUG] end:: Tue Sep 21 2021 09:30:00 GMT-0400 (Eastern Daylight Time)
                              [18.09.2022 22:22.12.573] [DEBUG] duration: 1800000
                              [18.09.2022 22:22.12.573] [DEBUG] title: Materials Due - MunichRe - Speaking & Writing Communication Skills
                              [18.09.2022 22:22.12.574] [DEBUG] Processing entry…
                              [18.09.2022 22:22.12.574] [DEBUG] Event:
                              {“type”:“VEVENT”,“params”:[],“uid”:“040000008200E00074C5B7101A82E00800000000EBF569C6329CD7010000000000000000100000007A6D0A4DBF5A8C43863B8DBA1D58CFC5”,“summary”:“DIANA - Calendly”,“start”:“2021-09-21T17:30:00.000Z”,“datetype”:“date-time”,$
                              [18.09.2022 22:22.12.575] [DEBUG] start: Tue Sep 21 2021 13:30:00 GMT-0400 (Eastern Daylight Time)
                              [18.09.2022 22:22.12.575] [DEBUG] end:: Tue Sep 21 2021 15:00:00 GMT-0400 (Eastern Daylight Time)
                              [18.09.2022 22:22.12.576] [DEBUG] duration: 5400000
                              [18.09.2022 22:22.12.576] [DEBUG] title: DIANA - Calendly
                              [18.09.2022 22:22.12.577] [DEBUG] Processing entry…
                              [18.09.2022 22:22.12.577] [DEBUG] Event:
                              {“type”:“VEVENT”,“params”:[],“rrule”:{“_cache”:{“all”:false,“before”:[],“after”:[],“between”:[]},“origOptions”:{“tzid”:“undefined”,“dtstart”:“2021-09-21T22:30:00.000Z”,“freq”:2,“until”:“2021-11-23T23:30:00.000Z”,“interval”:1,“byweekday”:$
                              [18.09.2022 22:22.12.578] [DEBUG] start: Tue Sep 21 2021 18:30:00 GMT-0400 (Eastern Daylight Time)
                              [18.09.2022 22:22.12.578] [DEBUG] end:: Tue Sep 21 2021 21:30:00 GMT-0400 (Eastern Daylight Time)
                              [18.09.2022 22:22.12.579] [DEBUG] duration: 10800000
                              [18.09.2022 22:22.12.579] [DEBUG] title: Sarah ASL 1C (Units 7-9)
                              [18.09.2022 22:22.12.580] [DEBUG] Search for recurring events between: Sun Sep 18 2022 22:22:12 GMT-0400 (Eastern Daylight Time) and Sun Sep 17 2023 23:59:59 GMT-0400 (Eastern Daylight Time)
                              [18.09.2022 22:22.12.598] [DEBUG] Title: Sarah ASL 1C (Units 7-9), with dates: [null,null,null,null,null,null,null,null,null,null]
                              [18.09.2022 22:22.12.598] [DEBUG] event.recurrences: [object Object]
                              [18.09.2022 22:22.12.604] [ERROR] Calendar Error. Could not fetch calendar: https://outlook.office365.com/owa/calendar/4d70fc7a1bf94d5ab75018902050b8f9@tssg.ca/34612ac6511e4af9824700a66f879c90976 RangeError:$
                                sdetweil @Jonsar
                                hm… i fixed that problem last year…
                                  Jonsar @sdetweil
                                  @sdetweil Your help is greatly appreciated. It really is a great feature we constantly use for the family to keep everyone informed. If you can suggest a fix, that would be awesome.
                                    sdetweil @Jonsar
                                    @Jonsar looking at it… no idea yet
                                      sdetweil @Jonsar
                                      @Jonsar ok, fun time… MS screws us again
                                      they changed the format of the timezone reporting…lovely
                                      not our code, but the calendar parser we use (that I fixed the last 2 times)
                                      workaround
                                      cd ~/MagicMirror/node_modules/node-ical
                                      nano ical.js , scroll down to line 120
                                      delete the whole line and paste in the new one (cursor has to be on that line to paste it there)
                                      change this (line 120 is the code, 119 is the comment)
                                        // If this is the custom timezone from MS Outlook
                                        if (tz === 'tzone://Microsoft/Custom' ) {
                                      to this
                                        if (tz === 'tzone://Microsoft/Custom' || tz === 'Customized Time Zone' || tz.startsWith('tzone://Microsoft/')) {
                                      also need to fix our code
                                      cd ~/MagicMirror/modules/default/calendar
                                      nano calendarutils.js
                                      change this , line 518
                                      	getIanaTZFromMS: function (msTZName) {
                                      		// Get hash entry
                                      to this
                                      		if(msTZName ==='Customized Time Zone'){
                                      			return moment.tz.guess()
                                      		// Get hash entry
                                      J S 2 Replies Last reply Reply Quote 0
                                        Jonsar @sdetweil
                                        @sdetweil said in Calendar has stopped working:
                                        Thanks for this. It didn’t exactly work. It definitely got further than before but I ended up with this error.
                                        Invalid time value
                                          sdetweil @Jonsar
                                          @Jonsar can u show me the cal event data in the logs right before the error?
                                            || tz === ‘Customized Time Zone’
                                            I see there were two place in ical.js
                                            and there is a timezone like this
                                            ‘Customized Time Zone 1’
                                            so this will fail
                                            change to this
                                             tz.startsWith('Customized Time Zone')
                                            in all three places … 2 in node ical.j one in caldendarutils.js
